Question about Jet Tech Systems 24 in. 737 Free-standing Dishwasher
JET 737 DISHWASHER. IT WILL START AND RUN FOR ABOUT 2 MIN THEN JUST SIT THERE TILL I PUSH START AND THEN IT REPEATS.
Dishwasher shuts off during cycle
Since the troubleshooting and repair process is too lengthy to include here, please go to the following link: http://www.appliance411.com/service/repairmanual.shtml
to open [or download] the service / repair manual. It is free.
Scroll about half way down the page, in the left column, under Maytag products, select the Maytag / Jenn Air / Jet Clean II "Tall Tub" Dishwasher repair manual... it covers your model dishwasher..
It includes a troubleshooting guide as well repairing instructions
Best wishes on your project.
Dec 01, 2013 | Maytag MDB9600A Jetclean II Built-in...
After 20 mins water temp still not at 150 on my jet-tech 737 dushwasher.
The reason the temperature are going up is the heating system is defective. The thermostat on the booster (rinse) is not satisfied. First thing to verify is the contactor that is activated by the rinse thermostat. Often one of the wires on the contactor will burn.
Nov 20, 2013 | Jet Tech Systems 24 in. 737 Free-standing...
E1 on jet tech 737dp
The E1 error code only means the temperature probe is either defective or just disconnected. Check directly behind the thermometer with the error, there are two wires , one black and one red. gentle tug on them. if they dont pull out, the probe is more than like defective.
Oct 23, 2012 | JetTech Jet Tech 737 - Undercounter...
Dish soap is leaving a build up on the interior of the dishwasher
Hi. Run your hottest and longest cycle with no soap, no dishes and 2 cups of white vinegar. Also, run the hot water into the sink before starting the dishwasher. Once the sink water is as hot as it gets, then push the start on the dishwasher. J.
Jun 23, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
We have the Whirlpool Gold quiet partner III dishwasher and lately have noticed residue on the dishes after the cleaning cycle is complete. Where is the trap to clean?
Make sure your water is hot, at least 120deg f. Also, use least amount of soap you can get away with. Usually around 2 tablespoons for soft water. Use powdered soap not gel. Gel leaves a tiny residue each load and will clog up plumbing in dw after 4,5,or 6 years. Rinse agent such as Jet Dry is highly recommended.
Try the "Tang" trick. Orange Tang drink mix is mildly acidic. With an empty dishwasher, start and fill, then normal drain. On second fill, add a full jar of Tang then let the dishwasher run for a few minutes. Crack the door to stop the dishwasher and let it sit for several hours or overnight. Then close the door, push start and let the dw run through the remaining cycle. This will sometimes clean out the crud in the water lines.
Hope this helps! Ken
Jan 06, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Only thing the dishwasher will do is the cancel drain for 2 min.
This may help in your situation. The following link explains how you may be able to clear the blinking clean light problem:
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Now...keep in mind all dish washers are not alike and have different panel options. If you do not have the same set up as I have referenced, the tech sheet for your dishwasher will explain. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
Sometimes this can be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of which circuit is causing your problem. Again, refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this helps you solve your problem.
Sep 17, 2009 | Kenmore 24 in. 16352 / 16354 / 16359...
Dishwasher will not stop washing
The problem is the pressostat which is part of the water level system. Either the pressostat needs adjustment or replacement. the air trap at the back of the unit in the sump area may be loose or broken, this should be inspected. refer to http://www.mvpgroupcorp.com/jettech/737_exp_view.pdf .
Jan 15, 2009 | Jet Tech Systems 24 in. 737 Free-standing...
Water to dishwasher not hot enough
The 737 model could run on even lower temperature (80F). Given time, the unit will heat up the water. the trick is to give it time.
That model is made for commercial use, not really for residential. It will not fully drain every cycles. The important thing to keep in mind is to empty the dishwasher (turn it off, pull the stand-pipe out, and drain) every night and left empty. When you want to use the unit, put the plug back in and turn it on, wait 20 to 30 minutes and it should be ready.
Robert Marsolais
Jul 28, 2008 | Jet Tech Systems 24 in. 737 Free-standing...
Jet tech washer 737 dp
Ouch.
Before you start changing all sort of parts, correct your problem with the wires. You may have to change most of them, depending on how bad the chemical burned tru them.
A good cleaning is required because that soap is going to continue chewing on those wires.
You're right about a short causing other component failure. But first repair those wires
Robert Marsolais
Dec 19, 2007 | Jet Tech Systems 24 in. 737 Free-standing...
Jet Tech Systems 24 in. 737 Free-standing Dishwasher Logo
Top Jet Tech Systems Dishwashers Experts
Robert Marsolais
Robert Marsolais
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Jet Tech Systems Dishwasher Expert? Answer questions, earn points and help others
