Question about Black & Decker 14" Grass Hog Xp Trimmer/Edger
How to get spool out of cup from my blck and decker gh3000
Model gh3000 spool will not release for removal
follow this steps and fix it. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Oct 09, 2013 | Irons
How to feed a b
hello,, how to restring black & decker,worx,ryobi,sears cordless and corded trimmers,, turn trimmer upside down,make sure bottom is clean,, push in the two tabs and pull bottom piece out,,remove the black spool,remove any old line and make note how string is attached to spool,you will need 30ft.of # 65 line some stores has this pre packaged for your b&d, insert the lone in the grove or hole and follow the arrow on the spool,line should be wound, now to reinsert the spool make sure that the spool is lined up with the slot to slot on the out side cup also on the auto feed make sure that the small half moon inside clip is towards the center,put spool on making sure to get groves in the spool slot,and get line through hole.put on cap, on the auto feed the line comes out when you turn trimmer on, you should do good to go,hope this help,any comments welcome,thank you..
Feb 15, 2012 | Black & Decker Garden
How to restring
Remove the cup from the bottom of the unit. Press the 2 tabs and pull away from unit. replace spool found inside or refill with aftermarket line. Wind in direction of arrow.
Apr 18, 2010 | Black & Decker 14" Grass Hog Xp...
Is there someone wo can show me visually how to replac the strint
Remove cup from bottom of unit by depressing 2 detent tabs and pulling away from unit.
Replace empty spool with new full one or wind on aftermarket string. Wind in direction of
arrow on spool.
I have a black & decker gt701 strimmer. i recently replaced the line on the spool but now it wont feed, ??
arrow on spool. Make sure spool is seated on rachet firmly.
Apr 16, 2010 | Black & Decker Garden
How do i install a new trimmer line ie plastic cord that u put in the head of a nylon trimmer
For Black and Deckers: Remove cup from bottom of unit by depressing 2 detent tabs and pulling away from unit. Replace empty spool with new full one or wind on aftermarket string. Wind in direction of arrow on spool. Make sure spool is seated on rachet firmly.
Apr 15, 2010 | Garden
I need to rethread my lawn trimmer bobbin. I have a Best Garden lawn trimmer, which has a dual line bobbin. I would like to know how to rethread it as it was left to me empty. Thanks.
Apr 13, 2010 | Garden
How to restring back and decker grass hog
Apr 11, 2010 | Black & Decker 14" Grass Hog Xp...
I can't figure out how to replace my spool
MANUAL:
http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1
PARTS:
http://www.ereplacementparts.com/black-and-decker-grass-trimmer-parts-c-4167_9518.html
Mar 14, 2010 | Black & Decker 14" Grass Hog Xp...
Spool removal st4000 trimmer edger black&decker
Push the tabs tother and pull the cover off, the spool then just slides off http://www.blackanddecker.com/Productimages/PC_Graphics/PHOTOS/BDK/OUTDOOR_PRODUCTS/TOOLS/LARGE/4/ST4500_A4.jpg
Call ALM Manufacturing 01423 797208 for stockists of a new spool
May 31, 2009 | Black & Decker Garden
Black & Decker 14" Grass Hog Xp Trimmer/Edger Logo
16 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
