Question about Kitchen Ranges
Amana arg7301 need to know why the oven/broiler would start to heat up even though the control knob is in off position
jsrock516
  • 5911 Answers
SOURCE: BROILER WONT COME ON
If your BAKE function works, but the BROIL does not come on, more than likely you have a bad igniter on your broiler. The igniter is a glow bar type that comes in two basic shapes. One is round, and one is square. The round type igniter should draw between 2.7 to 3.2 amps of current to be considered good, while the square type igniter will draw 3.2 to 3.7 amps. The reason it is important to mention this is because, it is not uncommon for an igniter to still glow. and be bad. The igniter is designed to draw the required amount of current in order for the gas valve to open. Once the valve opens, you have ignition. This is a designed safety feature that prevents free-flowing gas from accumulating without ignition. An easy way to check is to remove the broil cover and turn the broiler on to see if you have any activity out of the igniter. If the igniter does not glow at all, a resistance reading can easily determine if the igniter is bad. It should read avery low resistance if good. If the igniter glows, but the gas valve never opens, take a current reading. If you can provide me with your EXACT model number (located somewhere around the oven door/lower drawer opening, or on the back of the range) I can track down a part number for. I hope this information is helpful to you.
Posted on Jan 28, 2008
SOURCE: Hotpoint Gas oven doesn't light
Is the gas valve easy to replace on a gas oven?
Posted on Nov 19, 2008
SOURCE: Amana Model ARGS7650E Oven Problem
No matter that the igniter glows you must measure the current... If the current is less than 3.2 or 3.6 you must change it (this current is for the igniters with rectangular white base).The current to open the valve is the same that passed through the igniter so if it doesn't reach the proper value it will never open (or sometimes open sometimes not).Mine is not opening and the current is 2.9 so I'm going to replace it tomorrow.
Posted on Dec 26, 2008
SOURCE: Maytag MGR5775QDS oven wont heat.....
Replace the ignitor.  You will need remove the bottom plate (remove the two screws back corners).  And the disconnect the wiring from behind.  This little part will cost you approx. $100.
Posted on Feb 21, 2009
mindreader
  • 578 Answers
SOURCE: broiler works oven doesn't heat
Based on your description, the igniter is dead.
The broiler and the oven heat each have their own igniter. Look for the characteristic glow when the oven is turned on. If it is not visible, then you will need to replace the "OVEN" igniter...
Google the stove model for repair parts and locate the igniter. Not too hard to replace... directions are packed with the new igniter...
Posted on Jan 08, 2010
Trouble with an Amana oven
sounds like a bad valve that needs to be replaced. If that doesn't fix it let me know but 90% of the time this is the problem and the fix.
good luck and let me know if you have any other questions with this
Jun 06, 2008 | Amana RanARG7302 Gas Kitchen Range
Hello need help on my armani oven #arg7300LL oven and broiler do not go on?
Ok yes, it may be the thermostat.(It is the control and the tube that runs down inside the oven.) Give a few minutes and I'll post back....
Dec 22, 2007 | Amana RanARG7302 Gas Kitchen Range
When I turn the oven on, it goes into self-cleaning mode.
This sounds to me like your oven may need a new controller board. :(
Dec 14, 2009 | Washing Machines
Our Electric Amana Self Clean Oven, the broiler is not working? Help! The oven and stove top work just fine, but when we go to turn on the broiler the broiler doesn't come on, the selection buttons all...
canoyu physically inspect teh element for damage, perhaps its broken. or as wireleadingto the rearof elemnt has buntoff. you can check , but turn offpower first, the wires are always live
Feb 21, 2009 | Amana ARGS7650SS Gas Kitchen Range
Broiler not workig
The flame maybe not enough try to clean the gas nozzle at back potion of the oven , look for small wire to clean the clug by dust and rust , after cleaning test the flame , the burner will increase in flame .
Dec 24, 2007 | Amana ARGS7650SS Gas Kitchen Range
Kitchen Ranges Logo
37 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
