Monitor problem not displaying screen on monitor
  • 7 more comments
  • 5117 Nov 26, 2007
    no screen display on my monitor! it just occured all of the sudden! but there is a green light, indicating the supply of power if just okay.
  • bejaie Jan 01, 2008
    my monitor is connected to the computer,the computer is on but the monitor wont turn on..the power button on the monitor doesnt even come on green or amber colored,it's as if it not connected at all..it worked just fine until I moved and reconnected everthing..Can someone please tell me what to do..Thank you.
  • joseki Jun 20, 2008
    Green light (Power) is on. No display (Black out) on screen. Tested with another monitor and it is OK - ie nothing to do with computer.
    Joe
  • Anonymous Jul 06, 2008
    computer does not display on x2gen monitor
    hooked up a samsung and it worked fine
    it is a battle every time the computer is turned off
    HELP
  • Anonymous Aug 08, 2008
    monitor does not power on no green light no amber light
  • chris 101 Nov 04, 2008
    the green light comes on and all but the image does not show
  • Anonymous Nov 09, 2008
    monitor was going on and off for a little while, but now will not turn on at all. have tried other computers and using as a secondary screen, but monitor still does not work. Power on monitor works, but screen is still black
  • kallrise77 Dec 18, 2008
    yes i have a same problem. power is there green light appeare but screen blank.(no display).
  • silverskull Jan 09, 2009
    I have two Samsung 710N monitors that just have the green light slowly flashing. It's not the computer - I'm on it right now with a different monitor - but it's such a waste to have two of them lying around and not working.
I know that this sounds crazy but I have the same problem with a 710v monitor. What works for me is turning off the monitor and then turning it back on. Then as soon as the monitor is on press and hold the "Auto" button. If it goes up to 20% and then goes black try it again. If you press it at the right time it will go all the way to 100% and it will stay on. You will probably have to do this every time you shut down your computer or after you leave it for a long time. It works for me so hopefully it will work for u.
Posted on Jan 11, 2009
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
1 check connector from monitor to computer. 2 video card in computer if any for loose or defective. 3 loose contact in monitor 4 problem in smps power supplyinside monitor. 5 if it is ok check horizontal section in monitor. 6 crt base or any connector loose.
Posted on Sep 27, 2007
SOURCE:
Samsung sa850t monitor right half of screen is solid blue
I think your Display monitor cable damage, or may be your motherboard display cheap damage, or your display driver problem create.
First of all you check your display driver or reinstall driver. Sec think used external VGA card or check it. If not solved then your monitor display section damage. So contact good monitor technician.
Thanks..
Feb 03, 2014 | Samsung SyncMaster Computers & Internet
My Samsung n120 screen is displaying only vertically - how do I go back to horiz display?
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
Feb 15, 2013 | Samsung N120-12GW Netbook
Change screen orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish. Hope this helps
b>
Dec 14, 2012 | Dell Computers & Internet
I updated my video driver and now on 17 inch monitor display is coming instead of full monitor display how can i make the screen back to full 19inch display
Go to the Control Panel and click on Display, the the Settings tab. then change the screen resolution to 1024 X 768 or higher resolution.
The higher the resolution the smaller the Icons will be but you will be able to display more information on the screen.
Jun 09, 2010 | LG L192WS LCD Monitor
Monitor will not display
Your display app controls that, try updating drivers/ software for graphics card on laptop.
Or press the monitor button (usually Fn + something) till it comes right
Aug 08, 2009 | Compaq Presario 705US Notebook
How do I rotate the screen when I rotate the Acer B203w
For Windows XP -- within the control panel, click on Display Icon and the following screen will appear. I have 2 monitors (Laptop and HP L1925 monitor). On the display properties screen, near the top of the screen, click on the “Settings” tab. When the “Settings” screen displays, select the “Advanced” button near the bottom of the screen.
The “Plug and Play Monitor …” screen will appear as shown below. From this screen, click on the “INTEL(R) Graphics Media Accelerator Driver for Mobile” tab near the top of the screen. Note: Tab stretches the full width of the screen.
The "Plug and Play Monitor ..." screen will change to show Intel Graphis Media Screen. From this screen click on the “Graphics Properties” button near the center of the screen.
The screen will change to show the graphics properties. Note, the screen actually comes up with “DISPLAY SETTING” selection (in dark Blue on the Left hand side of screen). To change Display settings click on the words “DISPLAY SETTINGS” (left side of screen) and the screen will switch to show Rotation options. On the top of the screen, select the “Monitor” you wish to change by clicking on “Monitor” button. Next make sure the “Enable Rotation” box is check on the right side of screen and then click on “90”. Your monitor should rotate at this point to portrait. A message will appear letting you confirm if you wish to keep this new setting. Specify yes to keep the new setting.
This should do the trick.
Joe Buus
Jan 29, 2009 | Computers & Internet
Monitor Problem
there may a dry solder inside monitor or signal cable may disconnected internally move it if display changs then cable is faulty replace it
Oct 22, 2008 | SAMTRON 55V 15" CRT Monitor
Screen ajustment
Hi stefan,
You can adjust manually using the OSD (on-screen display) menu of you monitor by pressing menu button. Other monitor OSDs cannot be accessed on single button but some combination of buttons but considering it can be accessed, please look for it. Try also changing the properties at Operating System GUID (graphics user interface display) Control Panel Display or your monitors display monitor application software. Try changing the frequencies and other special features like single screen or wide screen, etc..
Best regards,
Rosener
Jan 30, 2008 | Acer AL1716 17" LCD Monitor
Open Questions:
Computers & Internet Logo
721 people viewed this question
Ekse
Alun Cox
