Question about GE Refrigerators
Ice maker water tube has ice in it - GE Refrigerators
    Problem Solver:
  • 11 Answers
Hi David, if you are finding that the ice maker fill tube is clogged with ice, you may have a defective water valve. Sometimes water valves leak small amounts of water and drip by drip it freezes when they enter the freezer compartment. Clean the iced up fill tube and if it happens again you will need to replace the valve. Good luck.
Posted on Nov 24, 2013
aborcass
  • 2651 Answers
SOURCE: Ice maker quit working
good sign its flashing , woth door open depress the left side flap oppiste the blinkin light. does the light then go solid red??? i fso its an indication that the electricl eye is operating ok .
theres a screw 1/4 in. along the right side underneath the icemaker itself, youll need to removeit and the cover its holding down. you can then slide the ice maker assy foward and out of machine,There will be another litle tab along loeft side uder ice maker youll need to depress to ppulll unit out. pry off the white cover from front of the ice maker assy itself and have a look at the main gear 2 in. round, is it broken off, or on its way top breaking( sometimes the tabs that hold it on to the ice maker module itself break preventing operation, if this is the case youll need to repalce the ice maker assy.
Posted on Oct 31, 2008
  • 42 Answers
SOURCE: NO WATER IN ICE MAKER
From what you've described, it sounds like you have a defective inlet water-valve.
I would remove your outside rear bottom panel; disconnect the 2 prong wires connected to your ice-maker water valve (blue with black solenoids) and check for continuity using an ohm-meter setting. If defective, replace. Whats' your model #?
Posted on Jan 26, 2009
farfield
  • 462 Answers
SOURCE: the fridge ice maker isn't getting water
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Check close to the end I have suggestions on how to stop or eliminate delivery tube freeze ups.
Does it make Ice OK?
If so the ice-water valve may be at fault if neither work.
Eliminate water filter or frozen line to reservoir.
Make sure you have water to water valve
Shut off water, remove line, open water line. Catch water in container and examine. Clean on particles let it flush out some more open and close til clean. Verify pressure and flow.
Still no water?
Check voltage with a volt meter at the fill valve behind the refrigerator.
Attach volt meter to the coil wire plug just insert probes into them. Then push the button on the door like your getting water. No volts? If has Ice maker pull off the other set of wires on water valve and recheck with door switch. Still no power? Problem in the ice - water door relay or control board.
If these check OK water valve is not opening when power applied replace water valve. Power shows good replace water valve.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You need an Ice maker book to tell you what it could be and what to look for.. Too many items to mention here.
I recommend if your problem is actually the ice maker itself get a new or rebuilt one. Too many things to detail to make sure it all works out in the end. However you might replace it and still have a problem. So here is a list of items to check external of the ice maker to eliminate what might be something else.
First lets see if we can eliminate some things:
Itemized as Temperature, Water, Water delivery… It is assumed the refrigerator has been running and not making ice and has remained on (NOT UNPLUGGED AND OFF) freezing as normal before starting any of these tests and observations. Other wise you will have to start over with the problem at hand before proceeding.
External of the ice maker:
1st Does the Freezer temp get down to 12'F? . The temp of the freezer has to be this cold or colder for the ice maker to work. Just because meat stays frozen (28’F and colder) doesn't mean it will freeze ice (12’F and colder) and dump it out. You have to know and record your findings to be objective and not subjective.
If not your problem may not be the ice maker at all. Eliminate it as a source of heat in the freezer. It’s plugged into the wall of the freezer and has a heater that warms the ice up to turn it loose for “harvest”. Unplug or remove it. Recheck the temp after ½ to 1 hour with the doors closed during this time. If its still not to temp your ice maker may be ok.
A lot of things can cause the temp of the freezer to stay high. But if this is the situation you need to look for a different problem before condemning and buying an Ice maker replacement
2nd Does it get water into the ice maker? If the water isn't getting to it you need to check the water delivery system, water supply, and water valve in the back.
The water delivery is easiest to check by shutting off the water removing the supply line and catching the water in a container with the valve open 1 to 2 rounds to flush out any particles and verify good flow and pressure, and makes sure when you turn it on you have clean water..
After you have eliminated this;
Next if your not getting water to the delivery tube and into the ice maker
1 of 2 things is stopping the water. Either its: 1 mechanical or 2 electrical in nature.
Mechanical
The easiest to look at is the obvious first. The water is not falling off the delivery tube? Look inside the freezer. Make sure the opening of the water delivery tube in back or side of the freezer is open and does not have ice or frost on it. Ice, here, can freeze and close off the delivery system. A common problem is lime or scale buildup, causing this ice to form. If the tube has this problem, defrost it with a hair dryer. Clean the tube with lime away or CLR. Re try it.
Posted on Mar 22, 2009
  • 351 Answers
SOURCE: Water supply tube keeps freezing off water supply.
its hard to tell but most likely the valve is not closing all the way. but it could be the ice maker calling for too much.... www.whirlpoolpartssurplus.com
Posted on Jun 23, 2009
  • 358 Answers
SOURCE: frigidaire refrigerator, ice maker
If the ice maker is doing the normal cycle and when calls for water doesn't get any,probably the fill tube to the ice maker is clogh with ice because the dual valve (solenoid) is leaking and this water freezes up clogging the fill tube , or the solenoid doesn't work ,in both cases it has to be replaced(it's located in the back of the refrigerator attached to the water supply line).
Posted on Aug 29, 2009
I have a kenmore coldspot model 51559101. The water dispenser is working and I can hear the motor for the ice maker but no ice....
Ice maker stopped making ice. For this problem you have check few things. First thing, is the water filling in the ice maker chamber and then ice maker not making ice? Or, the water is not filling in the ice maker chamber so it's not making ice. If the water is not filling in the ice maker chamber then it's clear that ice is not getting made due to no water in the chamber. For no water filling, the problem is either water supply valve turned off so water is not filling. Turn on the water supply and it will fill. But if the water supply is turned on then the other possibility is ice blockage in the water fill tube. There is a tube from which the water runs and enters the ice maker chamber. If this tube is blocked then water will not enter the chamber. The tube needs to be defrosted, by using hair dryer. This procedure melts the ice collected in the tube and water starts running again. But if water fill tube is completely clear and no ice blockage or any other blockage. Then other possibility is water valve. This water valve is for letting the water in the ice maker. The water valve open only for 7 seconds and in this time the water fills in the ice maker chamber and then water valve closes and the same procedure runs again in the next water filling cycle.------- The main valve on the back of the fridge section. This main valve lets the water enter the refrigerator .In most of the cases the fault is water valve . ------------- The other above possibilities which I gave you is water not filling in ice-maker chamber so it's not making ice. But now consider that water is filling in ice maker chamber but it's still not making ice. Then the problem is ice maker unit itself. This unit is controlled by main board. But in most cases if water is filling the ice maker but it's not making ice then its faulty ice maker unit. So see if the problem is water not entering the ice maker then the water fill tube is frosted by ice or the water valve is faulty. Replace the valve. ------------
You can get required parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks. Helpmech.
Jul 08, 2011 | Refrigerators
Smeg FA561X ice maker not making any ice. Water dispenser is fine and rest of fridge/freezer fine, just no ice in the ice storage part
ice maker stopped making ice. For this problem you have check few things. First thing, is the water filling in the ice maker chamber and then ice maker not making ice? Or, the water is not filling in the ice maker chamber so it's not making ice. If the water is not filling in the ice maker chamber then it's clear that ice is not getting made due to no water in the chamber. For no water filling, the problem is either water supply valve turned off so water is not filling. Turn on the water supply and it will fill. But if the water supply is turned on then the other possibility is ice blockage in the water fill tube. There is a tube from which the water runs and enters the ice maker chamber. If this tube is blocked then water will not enter the chamber. The tube needs to be defrosted, by using hair dryer. This procedure melts the ice collected in the tube and water starts running again. But if water fill tube is completely clear and no ice blockage or any other blockage. Then other possibility is water valve at the back of ice maker unit. This water valve is for letting the water in the ice maker. The water valve open only for 7 seconds and in this time the water fills in the ice maker chamber and then water valve closes and the same procedure runs again in the next water filling cycle.------- In most of the cases the fault is water valve at the back of ice maker section, on some refrigerators the valve is at the lower section. ------------- The above possibilities which I gave you is water not filling in ice-maker chamber so it's not making ice. But now consider that water is filling in ice maker chamber but it's still not making ice. Then the problem is ice maker unit itself. This unit is controlled by main board. But in most cases if water is filling the ice maker but it's not making ice then its faulty ice maker unit. So see if the problem is water not entering the ice maker then the water fill tube is frosted by ice or the water valve at the back of ice maker is faulty. Replace the valve. ------------
Jun 29, 2011 | Smeg FA561X Side by Side Refrigerator
My icemaker is not making ice. The water dispenser is working. Settings are fine, no ice at all in ice compartment. Filter light is not on. Ice maker button is in on position
Ice maker stopped making ice. For this problem you have check few things. First thing, is the water filling in the ice maker chamber and then ice maker not making ice? Or, the water is not filling in the ice maker chamber so it's not making ice. If the water is not filling in the ice maker chamber then it's clear that ice is not getting made due to no water in the chamber. For no water filling, the problem is either water supply valve turned off so water is not filling. Turn on the water supply and it will fill. But if the water supply is turned on then the other possibility is ice blockage in the water fill tube. There is a tube from which the water runs and enters the ice maker chamber. If this tube is blocked then water will not enter the chamber. The tube needs to be defrosted, by using hair dryer. This procedure melts the ice collected in the tube and water starts running again. But if water fill tube is completely clear and no ice blockage or any other blockage. Then other possibility is water valve at the back of ice maker unit. This water valve is for letting the water in the ice maker. The water valve open only for 7 seconds and in this time the water fills in the ice maker chamber and then water valve closes and the same procedure runs again in the next water filling cycle.------- In most of the cases the fault is water valve at the back of ice maker section, on some refrigerators the valve is at the lower section. ------------- The above possibilities which I gave you is water not filling in ice-maker chamber so it's not making ice. But now consider that water is filling in ice maker chamber but it's still not making ice. Then the problem is ice maker unit itself. This unit is controlled by main board. But in most cases if water is filling the ice maker but it's not making ice then its faulty ice maker unit. So see if the problem is water not entering the ice maker then the water fill tube is frosted by ice or the water valve at the back of ice maker is faulty. Replace the valve. ------------
May 16, 2011 | Kenmore Refrigerators
Ice maker stop working
Is ice maker not working, do you mean it has no power at all.Then its faulty control board.But if there is power to ice maker and its not making ice then its not board but it can be faulty valve.---------
Ice maker stopped making ice. For this problem you have check few things. First thing, is the water filling in the ice maker chamber and then ice maker not making ice? Or, the water is not filling in the ice maker chamber so it's not making ice. If the water is not filling in the ice maker chamber then it's clear that ice is not getting made due to no water in the chamber. For no water filling, the problem is either water supply valve turned off so water is not filling. Turn on the water supply and it will fill. But if the water supply is turned on then the other possibility is ice blockage in the water fill tube. There is a tube from which the water runs and enters the ice maker chamber. If this tube is blocked then water will not enter the chamber. The tube needs to be defrosted, by using hair dryer. This procedure melts the ice collected in the tube and water starts running again. But if water fill tube is completely clear and no ice blockage or any other blockage. Then other possibility is water valve at the back of ice maker unit. This water valve is for letting the water in the ice maker. The water valve open only for 7 seconds and in this time the water fills in the ice maker chamber and then water valve closes and the same procedure runs again in the next water filling cycle.------- For your information I will mention that there are two valves. One is the main valve the back of the fridge section. This main valve lets the water enter the refrigerator and other valve is at the back of ice-maker section. This other valve lets the water to enter the ice maker. In most of the cases the fault is water valve at the back of ice maker section. ------------- The other above possibilities which I gave you is water not filling in ice-maker chamber so it's not making ice. But now consider that water is filling in ice maker chamber but it's still not making ice. Then the problem is ice maker unit itself. This unit is controlled by main board. But in most cases if water is filling the ice maker but it's not making ice then its faulty ice maker unit. So see if the problem is water not entering the ice maker then the water fill tube is frosted by ice or the water valve at the back of ice maker is faulty. Replace the valve. ------------
May 12, 2011 | Whirlpool Refrigerators
My ice dispenser dispenses water but is not making ice.
May 03, 2011 | LG LRSC26920TT Side by Side Refrigerator
The ice maker is no longer filling with water
Apr 29, 2011 | KitchenAid (KSRD22FKST) Side by Side...
I have a side by side refrigerator and ice maker will not produce ice anymore
Apr 27, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker not producing any ice cubs
Apr 26, 2011 | Fisher and Paykel Active Smart® E522BR...
While we can get water dispensed from the door, the icemaker has stopped making ice.
Apr 26, 2011 | General Electric GSHF5KGX Side by Side...
Ice maker stopped making ice. Water line is hooked up and working. Just won't eject ice
Ice maker stopped making ice. For this problem you have check few things. First thing, is the water filling in the ice maker chamber and then ice maker not making ice? Or, the water is not filling in the ice maker chamber so it's not making ice. If the water is not filling in the ice maker chamber then it's clear that ice is not getting made due to no water in the chamber. For no water filling, the problem is either water supply valve turned off so water is not filling. Turn on the water supply and it will fill. But if the water supply is turned on then the other possibility is ice blockage in the water fill tube. There is a tube from which the water runs and enters the ice maker chamber. If this tube is blocked then water will not enter the chamber. The tube needs to be defrosted, by using hair dryer. This procedure melts the ice collected in the tube and water starts running again. But if water fill tube is completely clear and no ice blockage or any other blockage. Then other possibility is water valve at the back of ice maker unit. This water valve is for letting the water in the ice maker. The water valve open only for 7 seconds and in this time the water fills in the ice maker chamber and then water valve closes and the same procedure runs again in the next water filling cycle.------- For your information I will mention that there are two valves. One is the main valve the back of the fridge section. This main valve lets the water enter the refrigerator and other valve is at the back of ice-maker section. This other valve lets the water to enter the ice maker. In most of the cases the fault is water valve at the back of ice maker section. ------------- The other above possibilities which I gave you is water not filling in ice-maker chamber so it's not making ice. But now consider that water is filling in ice maker chamber but it's still not making ice. Then the problem is ice maker unit itself. This unit is controlled by main board. But in most cases if water is filling the ice maker but it's not making ice then its faulty ice maker unit. So see if the problem is water not entering the ice maker then the water fill tube is frosted by ice or the water valve at the back of ice maker is faulty. Replace the valve. ------------But if ice is getting made in the ice tray,but the ice is not ejecting out then there is blockage to the ice ejecting blade.May be some ice is got stuck below inside.Clear all ice frost collected under the ice chamber.And then see.---------------
Feb 21, 2011 | GE Refrigerators
Refrigerators Logo
66 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
