Question about GE Refrigerator Freezer Air Duct Trim Part Wr17x10780
I FOUND A UNATTACHED PART IN MY FREEZER AND HAVE IDENTIFIED IT AS WR17X10780, aIR DUCT. wHERE DOES IT BELONG?
  • 3 Answers
Here are the pictures. The GE parts list sucks.
i FOUND A UNATTACHED PART IN MY FREEZER AND HAVE - found-unattached-part-in-freezer-sdaqj2a1bijzpvnps2lqi3aa-2-0.jpg
Posted on Mar 08, 2015
My Hotpoint Fridge/Freezer only works with the freezer at the bottom and the fridge is fed from the freezer via ducting to the fridge at the top ---- can anyone tell me why the freezer works perfectly and...
There has to be something restricting the air flow to the fridge. If the fan is running blowing cold air into the freezer, then it should be cooling the fridge too. Empty out the fridge and freezer and use a blow drier to blow hot air into the duct work. There could be an ice blockage not visible in the duct work.
Aug 15, 2014 | Hotpoint Refrigerators
THE RECORD DRAGS, THERE IS A SMALL BLACK BAND LYING INSIDE THE BOTTOM UNATTACHED WHERE DOES IT BELONG
thats the drive belt for the record [layer, it loops around the entire disc on the bottom plate and the small spindle that sticks up off the top of the motor drive
Jul 19, 2011 | Philco 841205 Turntable
The air vent keeps coming unattached from both the machine and the window vent
There's 4 things that could cause the problem:
1. The hose clamps are loose.
2. The duct hose(s) is over stretched.
3. The duct hose(s) is under stretched and water/humidity is accumulating in the slope of the hose,
creating unnecessary weight.
4. An obstruction in the hose(s) or exterior duct termination, causing back pressure in the hose
If you have any doubts about the proper installation of the hose duct, consult your Owner's Manual.
Hope this helps you troubleshoot and solve the problem..
Jul 11, 2011 | Maytag Heating & Cooling
Why condensation on out side of my freezer
This condition is telling your that your freezer insulation is deteriorated or even leaks causing outside air contact to your freezer. By visual check the leaks, if you found, laminated it by using HVAC insulation like duct tape, PU foam etc. For best is to replace all insulation of your freezer.
Regards
Jan 15, 2011 | Whirlpool 21.6 cu. ft. / 612 liter Chest...
The Freezer works, but the Fridge does not.
There could be block in the cold air duct which comes from the freeezer. Since your freezer is working fine there should not be major issues . Hence check for the duct to be blocked, reduce the settings for the fridge or if it is a common settting make the freezer settings to mid point. If no frost model check if the fan is working and blowing fine the cool air to the fridge area. If not open fromthe freezer and clearr the duct. This will solve your issue. Good day
Jul 31, 2010 | Dometic RM2852 Refrigerator
Cool compartment is not cold enough
Hi, Have you noticed an ice or frost build up at all in the freezer section. Is the freezer holding a zero to 5 above temp?
I will try to help you though this. please let me know.
Thanks
Vic
May 13, 2009 | Refrigerators
Fridge/Freezer combo - Freezer working fine but fridge is not
There is a duct between the freezer and refrigerator. Sometimes this duct blocks off with ice and won't allow airflow. Open your refrigerator door and check for air flow if there is none the duct needs to be defrosted. turn off freezer/ refrigerator and defrost.
Feb 24, 2009 | Hotpoint Freezers
Freezer working fine but fridge isn't
Either the damper that the air flows up through is closed or the return air flow vents are blocked with clear ice.
Do you feel the air come out all the way at the top of the duct assembly when the freezer door is opened (but it then stops when the door is closed)?
If so, then it sounds like your return air flow vents are clogged. These are located to the left and right of the duct assembly in the rear/bottom of the refrigerator section. Sometimes you may have to slowly pour hot water into these vents to get the clear ice to thaw. The water should go down into the freezer section behind the evaporator and then out the drain in the back.
If you do not get the air to flow out the top of the duct assembly then the damper is staying shut. This could be either a bad damper in the duct assembly or the main board my not be sending voltage to the damper. Hope this helps.
Dec 31, 2008 | LG LRFD22850ST French Door 22.4 Cu. Ft....
The freezer part works, but the refrigerator side is set on the coldest setting, but not cooling.
There are a lot of reports of this problem with this model. Some of the things to check are the coils in the freezer sextio to make sure they are not iced over. With the compressor running, push the freezer switch and make sure the fan at the back of the freezer compartment is working. There is a duct in the upper right that allows cold air from freezer into fridge, these often freeze up or the trap door spring falls off closing this passage. In the fridge side is a return air duct, I have seen some models where the factory left tape in this duct that reduces air flow. There is a possibility the bulb is staying on although this is remote.
In short this is a poorly designed product and there are a multitude of similar symptoms with different solutions.
Oct 17, 2008 | Jenn-Air JCD2389G Side by Side...
Freezer gasket is not snug
try heating seal gently with a hairdryer and reshaping seal
Oct 08, 2008 | Jenn-Air JCD2389G Side by Side...
GE Refrigerator Freezer Air Duct Trim Part Wr17x10780 Logo
47 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
