Question about Archos Gmini XS200 MP3 Player
I have a damaged screen and i can't seem to connect my device to the laptop (running windows 7).. any ideas?
How can I run windows 7 on my LAPTOP
You should chek if your laptop can run windows 7 so download Windows 7 upgrade advisor from Microsoft's Webpage
http://www.microsoft.com/en-us/download/details.aspx?id=20
If it can, find the drivers for your devices: LAN, audio, graphics, screen and any other device you might have.
If you get them, buy a windows 7 installation disk, install it. activate it and finish the isnstallation of your drivers.
Feb 20, 2015 | Computers & Internet
When i turn on my pc only blue screen display on my screen
Blue screens are typically caused by software errors in device drivers: in Windows systems by poorly written device drive , They can also be caused by physical hardware faults, such as faulty RAM memory or power supplies, overheating of components, or hardware which is run beyond its specification limits . On the other hand, registry damage,corrupted program and viruses are the major causes of computer blue screen,too. They can make our computer run into blue screen error and prevent us from working, studying or playing games online. Now, let's learn to fix blue screen error as follow steps together. You will find how easy it is to solve the problem.
Step 1.Burn a bootable CD/USB by Fix Genius for fixing blue screen error.
Step2.Change BIOS of the computer to boot from CDROM or USB Device Drive.
Step3.Fix blue screen of death with the created CD or USB easily.
Computer blue screen exists in kinds of windows system, and the solution is available for windows 7 blue screen, xp blue screen, vista blue screen and even windows 8 blue screen, etc. Laptop blue screen seems more likely to occur as its insufficient configurations. But it isn't real and if we can keep using our computer in a good way, they can both be health. After,blue screen of death is no longer a horrible disaster when it occurs to us, just use the methods above and we can solve the problem soon.
I hope you may solve your problem soon.By the way, the software is in Christmas promotion.
Oct 29, 2012 | Asus Eee 701Sd Notebook
A blue line in my asus laptop LCD
seems like the lcd screen is damaged for impact you may need to replace it (screen or the complete laptop easy to rescue your data or transfer to a new laptop good luck!
Aug 25, 2012 | ASUS X53urh11 X53u-rh11 15.6", Amd C60,...
I am running Windows 7 on my Laptop. How do I
Download windows Mobile device center, then connect your mobile phone to the computer using the USB cable, Under Mobile Device settings click on connection settings.
Download Windows Mobile Device center from http://www.microsoft.com/windowsmobile/en-us/downloads/microsoft/device-center-download.mspx
Apr 11, 2010 | HTC S710 Smartphone
Acer aspire 5100 windows 7 ~ keyboard, screen, dvd
The DVD ROM problem lies in the REGISTRY. I have the registry entries. I can email it to you. I have the same lappy running 7. It aint supported but that mean it don't work! :)
Feb 20, 2010 | Acer Aspire 5100 Notebook
Replaced old laptop with new HP-dv8t running Win 7 pro. Downloaded and installed HP Photosmart 2600 software for 64 bits. HP Solution Center says printer is not connected but I can print, scan. Under...
windows 7 install software for any printer automatically
i use hp 2100 and hp 1608 printers with windows 7 without installing their software
if your os is not recognizing the printer than you need to download theupdated software compatible with windows 7 of your printer
Feb 05, 2010 | Computers & Internet
Drop dell insp. 1501 on the floor power on but no screen and no noise. power stays on/dvd pop out that works but no screen and no hd light any ideas
seems yyour screen had been damaged, try to use monitior out vga connection from yor laptop to your pc screen by using FN+ the key which transfers your screen. if it works , then you are sure that your screen is damaged...check for lose connections and other possible damages that is visable..
Oct 24, 2009 | Gateway M305CRV Notebook
Non Disk error... Compaq HP NC6400 3 Gb ram 120 Gb S ata hdd toshiba 1.83 Ghz Intel Core _____________________ well everything happened as the lamp above our table in the living room fell on my laptop...
Check the boot sequence in BIOS and make sure that you no usb device connected to your computer and also try to change you Sata mode in BIOS and see if that works.
Jul 27, 2009 | HP Computers & Internet
Archos Gmini XS200 MP3 Player Logo
18 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
Jim Goldsmith
Jim Goldsmith
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
