Question about Casio Office Equipment & Supplies
Display of my 100 MS calculator not working properly
  • Casio Master
  • 7,993 Answers
If the display is not working properly you cannot use the calculator. Better get another one.
Posted on Oct 19, 2013
When I try to make 100 + 10% answer is 111.11111... and not 110, How do i correct it?
best way to calculate percentages quickly is to multiply base number (100) by 1.xx (where xx is the percentage desired - here it would be 10 or just 1)
100*1.1=110
Works on every calculator every time.
Mar 03, 2015 | Casio MS-10VC 10-Digit Display Calculator,...
Casio ms-10vc, when I try to make "100 + 10%" answer is 111.11111.... Is not correct, how I can fix this?
Of course it won't give you the right answer, type 100x10% then add the product to 100.
Aug 01, 2014 | Casio MS-10VC Calculator
Doesn't work out percentage correctly
Dear Plz try this 100 X 45% then press + and u will get the ans 145.
Apr 17, 2013 | Casio MS-80TV Scientific Calculator
How do I calculate the precentage
Percent simply means "out of 100", so one half (ie 0.5) needs to be multiplied by 100 to give 50% (for example).
Your calculator may have a percentage function (usually on the equals sign but you will need to refer to the instructions to check how it works.
Nov 22, 2011 | Casio MS-80TV Scientific Calculator
MS-80TV AUTOMATICALLY ROUNDS UP TO 1 DECIMAL DIGIT
The [MODE] key can be used to select the modes described below.
Important! The following is a general explanation of Scientific Calculator modes. Note that your calculator may not include all of the modes described here.
1) Calculation Modes
Before performing a calculation, you first need to select the appropriate calculation mode.
COMP: Basic arithmetric calculations
(arithmetic operations, trigonometric functions, etc.)
COMPLEX: Complex number calculations
SD: Single-variable statistical calculations
(sample standard deviation, etc.)
LR or REG: Paired-variable statistical calculations
(linear regression statistical calculations, etc.)
BASE or BASE-n: Binary, octal, decimal, hexadecimal number system calculations
MAT: Matrix calculations (determinants, etc.)
VCT: Vector calculations
EQU: nth degree equations, simultaneous equations
2) Display Settings
Use these settings to control how calculation results are displayed.
Note that changing the Fix and Sci settings does not affect internal calculation results.
Norm: Exponential display format and cancels the currently configured Fix and Sci settings.
Fix: Specifies a fixed number of digits to the right of the decimal place.
Sci: Specifies a fixed number of significant digits.
3) Angle Unit Setting
(90°=?/2 radians=100 grads)
Deg: Degrees
Rad: Radians
Gra: Grads
4) Engineering Mode
Use this mode when you want to input and perform calculations using engineering symbols.
Please rate this response . .
Sep 08, 2009 | Casio MS-80TV Scientific Calculator
TI-82 display isn't fully working
This happens alot with calculators that have been in storage for a while, you can fix this by taking the batteries out and let it sit overnight.
May 05, 2009 | Texas Instruments TI-82 Calculator
My calculator will not let me add or subtract percentages.
I have a Casino MS-80S and yea, the percentage works different. As example to take 100 and subtract 10%, this is what I do: 100 X 10% - and then I get the answer 90 after I press the minus key. To add the percentage instead, 100 X 10% + will give me an answer of 110, after I press the plus key.
Apr 04, 2009 | Casio HR8TM Calculator
My casio MS-TE caculates 100+5%=105.26315,not
From CASIO FAQS:
Why do I get the wrong answer when doing a percent calculation?
Make sure that you are following the correct procedure.
Adding 10%: 200 [×] 10 [%] [+]
Subtract 10%: 200 [×] 10 [%] [-]
Mar 26, 2009 | Casio MS-80TE Calculator
Casio calculator MS-8TV
SETTING YOUR TAX RATE
you hold your set % button down for three seconds until set shows again, then hit tax rate button it shows your tax rate, change your tax rate then hit set your tax rate should be set.
cliff notes:
hold set% button
hit tax+ button
change the desired %
hit set done
Jun 11, 2007 | Casio MS-80TV Scientific Calculator
Open Questions:
19 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
