Question about Cell Phones
Cleartalk apn erased - Cell Phones
How do I find or enter a new apn number on my galaxy s6
  1. Go to Settings.
  2. Mobile Networks.
  3. Access Point Names.
Mar 15, 2017 | Samsung Cell Phones
Apn settings for cleartalk
Hemp I deleted my apn for cleartalk on my galaxy s7 does anyone have the settings???
Jun 24, 2016 | Cell Phones
APN for cleartalk flashed phone
Please contact your service provider, they will be able to help you out when it comes to service related concerns.
Jun 18, 2016 | Samsung Galaxy J1 J100M Unlocked GSM 4G...
Settings for apn are blank. what is my apn code
Hi Edward,
Here are the steps..
Internet Setup
Step 1: Enter Settings
Step 2: Select Wireless & Networks
Step 3: Select More...
Step 4: Select Mobile Networks
Step 5: Ensure Data Enabled is checked (enabled).
Step 6: Select Access Point Names
Step 7: Create a new APN (Select Menu, followed by New APN). Enter WIND Data as the name for the new APN. Under the headings APN enter internet.windmobile.ca (leave all other fields blank).
Step 8: Save the APN settings by selecting menu and then save.
Picture Messaging (MMS)
Step 7: Create a new APN (Select Menu, followed by New APN). Enter WIND MMS as the name for the new APN. Under the following information in the listed headings:
  • APN: mms.windmobile.ca
  • MMSC:http://mms.windmobile.ca
  • MMS Proxy: 74.115.197.70
  • MMS Port: 8080
  • MCC: 302
  • MNC: 490
  • APN Type: mms
  • Leave all other fields blank.
Android 2.1 to 2.3
Internet setup
Step 3: Select Mobile Networks
Step 4: Ensure Data Enabled is checked (enabled).
Step 5: Select Access Point Names
Step 6: Create a new APN (Access Point). Enter any name you would like to call your internet connection and the access point as internet.windmobile.ca (leave all other fields blank).
Picture Messaging (MMS) setup
Step 6: Create a new APN (Select Menu, followed by New APN). Enter WIND MMS as the name for the new APN. Under the following information in the listed headings:
  • MMSC: http://mms.windmobile.ca
  • MMS Port: 8080
  • MCC: 302
  • MNC: 490
  • APN Type: mms
May 10, 2016 | HTC 7 Surround T8788 Windows 7 Wm 3.8"...
Please my LG G4 dont have APN settings. How can I download it
Hi Yewande, Without knowing your internet provider I can't help you but you can find it by googling (APN settings for) + YOUR INTERNET PROVIDER.....CHEERS..
Apr 25, 2016 | LG G4
Samsung s4 I deleted the apn on accident how can I get them back
Every carrier uses its own APN Settings to get its 3G/4G LTE network working on an Android smartphone or tablet device. Now, these APN settings are usually "downloaded" automatically to your phone when you insert a SIM card. BUT, there are times where the APN are not selected automatically OR when the APN settings are not downloaded.
In those instances, your 3G/4G LTE data will not work but that can easily be fixed.
Step 1. First, browse your Settings menu and find the "Access Point Names" menu. This is usually under "Mobile Network Settings" or "More Mobile Networks" or "Mobile Networks" under Settings menu depending on the Android device used.
Step 2. Once you are in the APN Settings menu, first thing you should check it that the APN is on the correct one. If the correct APN is not checked (sometimes this happens), simply check ON the correct APN for your carrier. That will make your 3G/4G LTE data working right away.
Step 3. There are also times where the wrong APN is listed or there's simply no APNs listed. In these rare cases, you can simply add a new APN, hit the "+" button. 25264381-evzu5111kn4ie1titkzzffdn-4-2.jpg
Step 4. For APN setting, the "Name" can be anything. "APN" setting is the most important, usually you only have to fill this out for your phone to work.
Step 6. Hit "Save" when done.
Step 7. Next, make sure to select the new APN Setting you have saved. Within 5-30 seconds, your phone should start picking up 3G or 4G LTE signals and your data should be working again on the phon 25264381-evzu5111kn4ie1titkzzffdn-4-14.jpg
Nov 01, 2014 | Cell Phones
Di ako makapagfb using myphone Q19i...paano po b dapat gawin para makakonekta ako gamit ko ung cp n un? ty.
APN Settings for Globe, Smart, Sun, WeRoam Cellular
The following settings are applicable to Smart, Globe and Sun Cellular for their APN settings (Access Point Name). The settings should work with majority of smartphones in the market.
Postpaid APN: internet.globe.com.ph
Prepaid APN: http.globe.com.ph
APN Settings for Smart Bro
Postpaid APN: smartbro
Prepaid APN: smartbro
APN Settings for Smart Buddy, Smart Gold
APN: internet
APN Settings for Sun Cellular
Prepaid
APN (static): minternet
Authentication: PAP
IP address: dynamic
Postpaid
APN (static): fbband or minternet
Authentication: PAP
IP address: dynamic
APN Settings for PLDT WeRoam
Postpaid: WEROAMPLANor internet
Note: If you’re using a variety of postpaid or prepaid SIM cards in one dongle, make sure to create a Setting Profile for each SIM card so it’s easier to set the APN when switching SIM cards.
Leave all other settings blank or as is.
Mar 05, 2014 | Computers & Internet
Mobile network settings
Hi
To input settings/choose from presets...
Press Menu Button (The one with four small squares on it)Go through menu and tap "Settings"
Tap "Wireless and Networks"
Scroll to and tap "Mobile Networks"
Tap on "Access Point Names/APN's"
If your Network is not listed press
The Menu Button again (Four Small Squares)
and tap "New Apn"
You will obviously need the settings.
You can probably find these on your network providers website.
Most Service Providers offer a text setup service.
This will send a text message to your phone which you read and delete, then restart your phone and settings should be set up automatically.
Check your Networks website to see if this service is available.
I hope this helps!?!
Mar 10, 2012 | Sony Ericsson XPERIA X10 Cell Phone
My mms on my g2 isn't working.how do I fix it?
Settings => Wireless & network => Mobile Networks => Access Point Names.
Now, hopefully you have T-Mobile MMS. If you do, select the radio button next to it. If there isn't a radio button next to it, then select the name, erase the value for "APN type,", save the settings, and select the radio button.
If you don't have T-Mobile MMS at all, then create a new APN by first pressing "menu." The settings are as follows:
  • Name = T-Mobile MMS
  • APN = epc.tmobile.com
  • MMSC = http://mms.msg.eng.t-mobile.com/mms/wapenc
  • MCC = 310
  • MNC = 260
Any settings that I skipped should be left blank.
Nov 03, 2010 | HTC Reusable Screen Protector Hero /...
HAVE A FEW PROBLEMS WITH MY SIDEKICK 3
The only thing I can help you with is the data getting erased. Often If you don't have the sidekick package lots of data get's erased including your contacts.
Jan 02, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Cell Phones Logo
26 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
