Vcr loads normal with cover off, wont load with cover on
  • Televison & ... Master
  • 5,487 Answers
You have either got a dodgy bit of solder that is moved when a screw or the cover goes on. Or the cover is pressing on something. You might be able to get it to act up, if it is pressing on something, by pressing down with your hands while loading a tape. Or getting someone else to do so.
Posted on Oct 25, 2013
I change the belt and now, I have a new problem. The cassette won't go inside the vcr. When I push the cassette, the motor won't start. If I shutdown and shuton the vcr, the cassette goes in and come...
It is possible that there is a fault in the INDETECT section of the cassette detection.
Normally this is triggered when the cassette is pushed into and if there is no detection the loading motor does not work nor the lock is moved to let the tray move on into the loading tray.
So when you put the VCR ON/OFF the detection motor works for a small period of time as a pre check which in the process allows the motor the load the cassette into the section but while it is inside the processor does not get the INDETECT or the IR END sensors to work thereby allows the rejection to be ejected out.
You will need to check the loading detect sensors and the IR sensors for the fault described.
Mar 10, 2011 | Toshiba M784 VCR
Video tape wont stay in ?
This indicates there is either something stuck/jammed in the cassette loading mechanism, or a fault in the same mechanism.
Unplug it from the mains and gently insert your fingers in to the loading slot - feel and look for anything obvious that shouldnt be there. If you've got kids in the house, all sorts of things will fit in the slot !
Nothing ? Next take the top cover off - normally secured with 2 or 4 screws on the sides, and 1 or 2 screws on the back. Again, carefully look for anything that shouldnt be there - if you've never looked in a VCR before, it all looks strange but soemthing like a sweet, toy, or broken off piece of a cassette is normally failrly obvious. Do not to touch the video head (biggish round thing with a small circuit board on top) as it is very easily damaged by fingerprints, etc.
Still no joy ? Well, the loading mechanism in a VCR is a very clever and complex set of interlinked motors, switches and levers, and requires a lot of knowledge and specail tools to repair it properly. Take it to a repair shop for a quote, and then decide if it's worth it.
Nov 03, 2009 | Panasonic NV-SJ205 VHS VCR
Cannot load tape. keeps ejecting tape when trying to load.
Remove the top cover from the VCR. If you have children in the house, look for any object lying in the mechanism. If this is clear, insert a tape slowly into the carriage & watch carefully if the cassette tape flap raises up & allows the tape to be lowered down into the mechanism, if not the flap lever at the side of the carriage may be broken. If the tape does lower into position, look to see if the tape is being pulled out by the guide arms, (normally 2 white poles) one of these may be broken. Check the half loading arm is also not obstructing the tape. If any of these parts are broken a new deck mechanism would be required.
Jul 06, 2009 | Mitsubishi HS-U530 VHS VCR
Vcr tape does not complete loading cycle-stops about 2/3 complete
Your load motor belt is worn or your load gear lubricant had hardened and needs to be cleaned and relubricated.
I had the same problem with my Emerson VCR.
Mar 10, 2009 | GE VG2050 VHS VCR
Loads then unloads the tape
could be a sensor problem. look at bottom side of videotape. in the center towards the top is a round hole, above a screw. then insode the vcr (take top cover off) theres a prism or led sticking up that goes into that hole in the tape, when the tape is loaded. try wrapping masking or electrical tape around it (only a temporary fix)
Feb 20, 2009 | Sharp VC-A410U VCR
Sanyo dvw 6000 dvd/vcr player
DVD loading mechanism doesn't load completely that's why opens after attempt of loading.
You need to open top cover of unit and inspect loading belt might be lose, tray timing can be out of phase, some wire got stuck with tray while loading etc.
Oct 02, 2008 | Sanyo DVW-6100 DVD Player/VCR
Toshiba VCR
Check this link it has some solutions that you can try in removing the tape inside the VCR http://www.fixer.com/no-eject.html
Hope that helps...........
Sep 12, 2008 | Televison & Video
Keep saying loading than just ejects the dvd all types of them
It has problem in dvd loading mechanism which is not load completely and mean while system control IC waits for complete loading signal and than produce eject command.
You need to open top cover and check closely its DVD Loading Mechanism, might be loading belt slips.
Aug 17, 2008 | Sony RDR-VX525 DVD Recorder/VCR
VCR kicks out cassettes
Sounds as if something got bent in the loading mechanism when you freed the stuck tape. Careful examination of the loading operation with the cover off may reveal the problem, but you may require a service shop, as there are hazardous voltages present inside, even when switched off.
Jul 13, 2007 | Toshiba MW24F52 24" TV/VCR/DVD Combo
Tape Ejects Immediately
There are normally 2 causes. One is some obstruction in the tape path. Please open the cover of the VCR and shake and see for foriegn objects. Nothing??? Then there is one more possibility - Belts are loose.. Check the Tape Loading motor belt.Is it slack? This can happen over time.Change the belt.
Feb 04, 2007 | Panasonic NV-HD680 VCR
Televison & Video Logo
Top Televison & Video Experts
