Question about Apollo 1500 Single Swing Gate Operator / Gate Opener
My Apollo gate is erratic. Some times it stops at the adjusted open stop, other times it bypasses the open stop and keeps opening till it can open no further, it still automatically closes.
3 Suggested Answers
SOURCE: I have an Apollo 636
Correct, that board is toast. The is the one thing that any circuit board can not handle is lightning strikes. Buy a new one.
Posted on Oct 26, 2011
benmdavid
Apollo slide gate opener closes when remote is pressed, but does not open when remote is pressed again. I think it's a 7100 series. I think it needs a reset, but vacant find any reset button on the board
Posted on Dec 11, 2013
Gemini gate motor
Check if it has stops anywhere in the system, usually there are micro switches that are activated by arms, etc that tell it how far to open and close. You may need to adjust them.
Aug 20, 2014 | Cars & Trucks
My gate starts to open but then stops
Need more information.
Firstly, engage the manual release inside your motor and then operate gate by hand. Pay attention to any spots that are hard to push, this would indicate some sort of mechanical obstruction causing the motor to stop. Try remove obstruction.
Secondly, measure the voltage on your battery while trying to operate the gate. If your battery drops below 11.5V the control board will shut down. If so, replace battery.
Feb 04, 2012 | Apollo 7000etl Slide Gate Opener Plus 2...
When in park hard to move shift stick out of park
Moving the shifter out of park is sometime diffucult if the vehicle is parked on an incline or decline?
Aug 15, 2010 | 1993 Honda Accord
Replacing the brake light swith
n all probability the brake sensor on the pedal is starting to work erratically. This sensor sends a signal to the shifter gate, and the gate will not open unless the brake pedal is depressed. I had it happen to me, and the only solution until i replaced the sensor was to hit the brake over and over until the stop light worked. If the stop lights work, the shifter gate should allow the shifter to move out of park. This sensor/ switch is located about 3 inches above the brake pedal, and it is easily recognizable by the cable attached to it.
Aug 11, 2010 | 1998 Honda Accord
Stop light brake switch
Honda transmission stuck in park
In all probability the brake sensor on the pedal is starting to work erratically. This sensor sends a signal to the shifter gate, and the gate will not open unless the brake pedal is depressed. I had it happen to me, and the only solution until i replaced the sensor was to hit the brake over and over until the stop light worked. If the stop lights work, the shifter gate should allow the shifter to move out of park. This sensor/ switch is located about 3 inches above the brake pedal, and it is easily recognizable by the cable attached to it.
Jul 07, 2010 | 1998 Honda Accord
The outgoing gate has a positive stop on it, but
Well it seems that their could be a limit switch problem. also if someone has replaced the limit switch they could have not connected the wires back up correctly. if your wiring and switch are correct than you have a bad circuit board. my opinion is to not even fix it and replace the whole opener with a gto-pto gp sl50 They are the most reliable opener out so far and come with all the features that elite charges extra for like a battery backup for instance.
Oct 24, 2009 | Elite Sl 3000 Ul Sliding Gate Operator
Apollo 1500 Single Swing Gate Operator / Gate Opener Logo
74 people viewed this question
Top Apollo Home Security Experts
Lawrence Oravetz
Are you an Apollo Home Security Expert? Answer questions, earn points and help others
