Question about Dual XDM6830 CD Player
Cd player not working it reads error02
The cd player worked fine and then it stopped working and it reads error02 and turns back to the radio
  • 1 more comment
  • Anonymous Nov 12, 2007
    car audio system periodically cuts out & displays ER 2. Shortly after it chages from radio to CD & back. seems fine for a while & then repeats - more frequent on rough roads.
  • gulwop Nov 29, 2007
    I used a cleaner.
  • Jo Mar 20, 2008
    My cd player is doing the same thing, except it doesn't switch to the rdio automatically, it just keeps flashing the error 2 message, it also on occasion reads error 1 as well, it seems to vary. at first it stopped playing burnt cd's now it doesn't even play store bought ones. I tried a cleaning disc but it won't even play that. any one have any ideas on how to fix it?
    Thanks
  • 3 Answers
This sounds like a wire has cum loose or ur cd player sensor has been damaged
Posted on Sep 27, 2007
SOURCE:
How to get the laser unit repaired/ replaced on my portable CD player?
Most likely cheaper to replace than repair. The labor cost for such a fiddly repair would be more than a new unit.
Jan 22, 2016 | Magnavox 45 Esp Jogproof Portable Cd...
How do I solve a problem CD Disc Player Model CD-1493 player stopped running any CD's-Model CD-1493?
The player mechanism may have failed even though everything else works.
Sep 23, 2014 | Cars & Trucks
How to fix the CD player 6 CDs in my escalade ext 2005. 2 days ago it was working fine, and it stop working, the lights from the numbers of the cd box turn off and it doesn't work anymore, the radio and...
If the number lights are out and the CD player is also dead it sounds like you lost power to the player. Check all your fuses as the radio and CD player may have separate fuses. Also check any visible wires to see if there is a possible disconnect.
Oct 20, 2013 | Cars & Trucks
Cd player reads err on display
internal problem in radio,you would have to take it to a dealer to send out for you,
Jan 01, 2010 | 2000 Chrysler 300M
2004 cadillac srx cd player jammed
I had the same problem. disconnect the battery cables. then reconnect them. this will reset the cd player and it should relaese all your cd player problems.
this happened twice to me and the above worked fine both times.
Jun 11, 2009 | 2004 Cadillac SRX
CD Changer spinning continually
i have the same exact problem with mine. what i did was manually pull open the cd deck, stop the disk carousel from spninning by holding it still, then push the deck closed. the cd deck will no longer work, but at least it stops spinning. the auxiliary works fine and so does the radio.
Feb 07, 2007 | RCA RS2652 5-CD BOOKSHELF SYSTEM Shelf...
Dual XDM6830 CD Player Logo
102 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
