Question about Philips HTS3400/37B System
I would like find out what is gt 903 stands for because the part burn out
My iphone 4s can not find my 903
Once you make your iphone discoverable, then put the Plantronics 903 headset into pairing mode by pressing the power button until it flashes red and blue. If it's not flashing red and blue, it's not in the pairing mode. Below is a link for the user guide which has the pairing instructions:
Plantronics BackBeat 903 Pairing Instructions
Good luck from Headsets Direct!
Nov 25, 2011 | Plantronics Backbeat 903 Bluetooth...
How do you pair the 903 headset with my ipod touch?
To pair the Plantronics BackBeat 903 with an iPod Touch:
On the 903 headset:
With the headset powered off, press and hold the "Power/Pairing" button until the LED indicator flashes blue and red. This will put the 903 headset into pairing mode.
Use the iPod Touch menu to search for the headset and select 9xxBackBeat.
(If prompted, enter 0000 for the PIN code/passkey. Some devices also require you to accept the connection. Headset is paired when LED flashes blue.)
On the iPod Touch:
In Settings, choose General, Bluetooth, and turn Bluetooth on.
Choose the device on iPod Touch, then enter the PIN/Passkey 0000 (4 zeros).
After pairing the 903 and iPod Touch, the headset model may appear on the screen when you are viewing the audio or video playback controls. (You can "tap" to switch to a different audio output, such as the internal speaker)
Aug 17, 2011 | Plantronics BackBeat 903 Bluetooth Headset
MPlantronics Backbeat 903 Bluetooth Wireless Stereo Headphones Headset red light flashing problems
The red flashing indicates a low (or check) battery. The instructions on page 4 in the link below for the Plantronics Backbeat 903/906 will show you how to charge it up. On page 8 you'll see how to power down and then up the headset to reset it.
Plantronics Backbeat 903/906 User's Guide
Aug 02, 2011 | Plantronics Backbeat 903 Bluetooth...
I cant sink with my iphone 4?
Once you make your iPhone discoverable, then put the Plantronics Backbeat 903 into pairing mode. With the headphones powered off, press and hold the Power / Pairing button until the LED Indicator flashes blue and red. Here is the link below for the Backbeat 903 user guide that has the pairing instructions as well.
Plantronics Backbeat 903 User's Guide
Jul 26, 2011 | Plantronics Backbeat 903 Bluetooth...
I am not able to connect the headset and my BB
Remember that newer phones are like small computers, so they may become corrupt over time and you may need to reset them every so often. Simply turn your phone off and remove the battery for a few seconds, then replace the battery and turn it back on again. If this does not resolve the issue, delete any pairing information for your BackBeat 903 headset and pair it again with your phone, carefully following the instructions on the link below for the Plantronics BackBeat 903.
Plantronics BackBeat 903 User's Guide
Mar 12, 2011 | Plantronics Backbeat 903 Bluetooth...
Will not fast forward a song and when i pause it it only mutes the music and keeps playing the song on my phone
Typically with the Plantronics Backbeat 903 Bluetooth headset, you should be able to move forward or backwards one track. Press and hold the volume/tracking/mute button forward or backwards for each track. You should hear a single low tone for each track change. Below is a link for the Backbeat 903 user guide.
Dec 26, 2010 | Plantronics Backbeat 903 Bluetooth...
Got a ge universal remote wont pick up code my emerson 19'' lcd tv says code is 0031
try those >
EMERSON
002 003 004 005 104 105 106 115 204 205 206 213 304 305 316 319
405 502 505 506 519 604 605 705 804 805 903 904 905 906
Fosg2000, Rate me !
Mar 16, 2010 | Emerson LC195EM9 19 in. LCD TV
903 SH Vodafone (Handset Code)
Hi,I have a problem with my phone 903 SH Vodafone,I forgot the HANDSET CODE I set to my phone,Can someone help to fix this...
Mar 07, 2008 | Sharp 903 SH Cellular Phone
Philips HTS3400/37B System Logo
20 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
