Question about HTC Incredible S S710e
Network problems sim - HTC Incredible S S710e
My HTC wildfire s can not detect sim card I already tried restarting and factory reset
Try the SIM card in a friend's phone.
Try a friend's SIM card in your phone.
Feb 24, 2015 | HTC Wildfire S Smartphone
Tip
There is another Solution to get out sim card error / Invalid sim card from...
How to correct sim card error / insert sim card
Procedure to follow
Step 1: Check the sim tray or sim seater to see if it it broken, if it is, replace it
Step 2: If the sim seater/tray is not broken, clean the entire terminal.
Step 3: If the sim seater/tray is not directly on the board, trace the broken led and solder it, or you replace the broken led with another sim tray.
Step 4: If it is still not working, change the battery and put a new battery, because a virus infected battery will always give such problem.
Step 5: Finally, if the problem still persist, then check the sim card and replace with another sim card if the former is bad because a bad sim card will always display such message as insert sim card or sim card error.
on Dec 09, 2010 | Cell Phones
Why i'm having network problem
Hi what network problem are you facing with your mobile whether you phone is not accepting your network sim if it is displaying messages like sim invalid ,sim lock and so on once you insert your sim in it then it mean your phone is locked to some other network provider due to this it wont accept any other GSM sim until you unlock it .You can easily unlock the phone using sites like OnlineGSMUnlock.com here they are rendering network unlock code for all mobile models at reliable cost .You first check that whether the code is available for your mobile model ,country and network provider .If yes then pay for it and unlock the phone then freely use it with any GSM sim ...
Sep 09, 2014 | Cell Phones
Not recognize sim
Did you mean your phone doesn't recognize your sim card even your sim card present on your phone?
Yes,Means,There are three possibilites to get this type of issue.
1.There may be a problem in your Sim card so try another one.
2.Check your Sim whether it's properly inserted or not
3.Your mobile is locked to particular network provider.
If your problem persists,After trying first two ways means definitely Your mobile phone is restricted by some network so try to unlock your mobile phone.You can unlock your mobile phone using network unlock code.It's the best way to unlock your phone.If you need an unlock code for your phone visit SuperUnlockCodes.com I hope it will be very useful to you.
Jul 03, 2014 | Cell Phones
How to find the sim network unlock pin code for zte racer
You can get the Sim Network unlock pin for your ZTE Racer phone from Mobile-Unlocker.com here you need to specify your country,Network name to which it is locked,IMEI number of your phone.
Apr 03, 2014 | ZTE Racer Unlocked Gsm Phone
Insert sim card is found in low signal
First:
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Second:
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Jan 12, 2013 | Samsung GT C5130 Mobile
Sim card not supported
If the Sim card Not support means it may locked to network.You need to unlock it...You can get the network unlock code from the site Onlinegsmunlock.com/samsung/rs7wp8/ for SAMSUNG GSM Network locked Phones and unlock it from Network lock.You need to specify the Model?
ALSO check whether it not support only one Sim card,if that problem means it may CDMA Network,OR may Sim card problem.If it not support other Sim card and support only one Sim means it's Under Network lock,You need to find the network,country it locked now and unlock it using the Unlock code,Only GSM Network lock Phones can be unlocked,CDMA network locked Phones cannot be Unlocked from the Mobile Phone.
Dec 06, 2011 | Samsung SGH Cell Phones
My mobile nokia 1600 not detecting sim
Try code from service provider and Unlock it
Sep 18, 2011 | Nokia 1600 Cellular Phone
Hi , i am in problem please help me. i have nokia
Hello
This error usually occurs when you attempt to use a SIM card from a network other than the network from which the phone originated (e.g. your Nokia mobile phone originated from Orange UK and displays the 'Sim Card Not Valid' error when you attempt to use a T-Mobile UK SIM card). The 'Sim Card Not Valid' error usually means the phone has been restricted for use on one specific network and you would need to unlock the phone before alternative network SIM cards can be used.
could You test the new SIM on another phone? Could be the housing of SIM damage on phone - hardware problem - Nokia Service.
in any case you need to find out which network and ask them for the unlock code.
Only the original network to which it is locked can provide this code.
May 01, 2011 | Nokia N73 Cellular Phone
I have problems with a phone. It not works. I
it    is   software problem
Oct 21, 2009 | Cell Phones
HTC Incredible S S710e Logo
Top HTC Computers & Internet Experts
Tom Chichester
Jerry Kramer
Jerry Kramer
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
