Question about Electrical Supplies
99 gmc plug wires
After a month or two the wires oham out at 2 or 3 (third set)
3 Suggested Answers
  • 5603 Answers
SOURCE: what ohams input do i use. i got a 4/12 cab with
If you put four 16 ohm speakers in parallel on your amp you should set it to 4 ohm. You calculate that as 16 ohm/4 = 4 ohms because they are in parallel.
When you put speakers in series then you add the impedance of each. You can ONLY series speakers if they are identical AND in identical cabinets.
Posted on Sep 27, 2009
Testimonial: "thanks for your help. this was what i was looking for. very helpful indeed."
  • 17 Answers
SOURCE: I have a 99 GMC suburban it has set for a few
Just changed out my friends fuel pump last week . Took a large rubber mallet as he was cranking away and pound on the fuel cell with in, three seconds the pump started to grind away and it started. Note don't stop the truck until you park it where you want to do the job it may never start again
Posted on Apr 02, 2015
Cylinder 3 misfiring on a 97 gmc jimmy 4wd. Did a tune up about 2 months ago (ignition, wires, coil, spark plugs), replaced fuel pump last week, used fuel injector cleaner, still no luck...any ideas?
go back and check all the plugs, wires and the total tune up. check your firing order, and timing. put a timing lite on the plug wires and if the plug is bad it will show with the light. lol.
Oct 05, 2015 | GMC Cars & Trucks
Cylinder 3 location on a 2004 gmc envoy
The coil pack will be numbered. Find coil #3 and follow the spark plug wire to the spark plug.
Jun 15, 2014 | 2003 GMC Envoy
Hi all, my 99 sub.350,300k,missfire #2
Have you checked the distr cap for cracks??
If plug is oily looking on brand new plug I would suspect worn rings, which would also explain the high PSI. (Motor job in the wind) Especially for 300K.
Dec 03, 2009 | 1999 GMC Suburban
I have a 99 GMC Jimmy with the 4 wheel drive. I
check fuse and relay to switch if power to switch retest switch new doesnt mean not defective if no power check connections and wiring for damage or breaks
Dec 02, 2009 | 1999 GMC Jimmy
Why is 99 mercury cougar getting bad gas milage"It seems to be getting worse.Less milage than my 99 ranger4x4.new plugs,oil change about 2 months ago.would a new O2 sensor help?
Try new plugs, wires, fuel filter, air filter, pcv valve, and if its still not too
good,, do the 02 sensors..
Have a good day !
Oct 24, 2009 | 1999 Mercury Cougar
What ohams input do i use. i got a 4/12 cab with
Sep 26, 2009 | Marshall Mg50dfx 50-Watt Combo Guitar...
Rough idle
Yes bad o2 sensor,check for vacuum leaks also.do you cross your plug wires?
Jun 26, 2009 | 1999 GMC Sierra
Sputtering
Check the fuel pressure regulator. Mine was doing the same thing and the pressure regulator was the problem.
Feb 10, 2009 | 1999 GMC Sierra
Electrical Supplies Logo
202 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
