Question about Cameras
How to facilitate the black and white? - Cameras
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
What make and model camera?
In general you're better off shooting in color and converting after you get the pictures onto your computer. A photo editing program on a computer gives you much more control over the conversion.
Posted on Oct 19, 2013
WHAT DO YOU NEED TO GET FUEL LINE OFF THE TUBES ON THE FUEL TANK. I REMOVED WHITE CLIP ON HOSE BUT THE HOSE WONT COME OFF.
If this is a rubber hose that was held on by the white clamp only.. will the hose turn(rotate) on the nozzle?.. try turning the hose(break it loose)..this will have to happen to facilitate removal...once it will turn on the nozzle.. it should pull off.. you may have to use pliers to CAREFULLY pull it off...
.. as a last resort.. you may have to slice the hose..(LAST RESORT!) as you will (may) have to replace the entire hose afterwards...
Aug 01, 2017 | Cars & Trucks
How to change a starter drive on a 1995 herritage softail
Hi Anonymous, here is the short version: Disconnect battery ground cable, drain primary and remove primary cover, remove starter jack shaft bolt while holding the pinion gear, remove rear exhaust pipe, remove all wires, cables, and bracket from starter, remove the 2 starter bolts, now for the fun part, if the Harley Gods are wearing white suits you may be able to wiggle out starter while sticking out your tounge at a 37 degree angle, if they are wearing black well you might have to either loosen or remove some oil tank mounts to facilitate extraction. Good luck
Apr 15, 2014 | 1993 Harley Davidson FLSTF Fat boy
Google com
try to print it white and black or what ever you print make it black and white or white and black and i have a question black and white is color or not?
Nov 16, 2013 | Computers & Internet
Want to attach a harbor breeze light kit to an existing hunter fan. switch housing has 3 white wires hooked together with a blue connector cap and a single black and white wire(labeled for light). there...
White to white ( single white ) & blue from light kit to Black with white stripe. Also make sure the black with white stripe coming out of TOP of fan is connected to the hot wire.
Aug 26, 2013 | Hunter 52" Ceiling Fan With Light And...
Does Computer-Assisted-Instruction facilitate Individualized Instruction?
Does Computer-Assisted-Instruction facilitate individualized instruction
Oct 14, 2010 | Apple Primary Curriculum Connections...
Wiring instructions are terrible. Ceiling wires = Red, Black, White, Copper. Fan wires = Black, White, Copper. Remote wires = Neutral in(Black), Live In(Black), Light out(White), Fan out(White),...
That is dificult to follow .. here is the usual wiring plan for ceiling fans .. green to green or bare and mounting bracket ... ceiling black and red are live from the switches, fan and light.with a remote you really only need one of these , so cap off the red and use the black as your input to the remote .. the neutral to the remote should be the white .. there are only 3 wires from the fan so I am assuming that there is no light , or the light will be activated from the remote .. the black for the fan and the black for the lights connect to marked wires on the remote. .. lights out, fan out
or looking at your description .. ((Remote wires = Neutral in(Black) white ceiling wire, Live In(Black) blaxck ceiling wire, Light out(White) blue Fan/Light wire, Fan out(White) black fan/light wire, Common(White) white ceiling and white fan/light wires.
May 21, 2010 | Hunter 27148 Remote Control
Need diagram for hunter fan with light kit. Three
Black to black. from fan
Blue to Black and white. from fan
White to white. from fan
The input is from ceiling supply
the black wire from fan is for motor.
the black and white is for the light.
Jan 02, 2010 | Hunter 52" Ceiling Fan With Light And...
Need to know how to convert the three prong cord to a four prong cord
You will find a black, a red, a white and a green or copper wire in your new cord. You will find a place for a red, a black and a white wire on the terminal block in your machine. The green/copper goes to the frame of your machine. If there is no place to fasten it, drill a hole in the body and fasten the green/copper ground to the body with a 10/24 or equal nut and bolt with washer. It should be about 1 inch long to facilitate your installation process.
I trust this will help you solve your trouble
Thanks for considering FixYa.com
please vote
tghanks
Dec 04, 2009 | KitchenAid KEYS700LQ Electric Dryer
Cameras Logo
15 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
