Question about Splendide Washing Machines
Not drying, no heat - Splendide Washing Machines
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 113 Answers
Replace element.
Posted on Dec 29, 2013
Why is heated dry blinking?
FIXED Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry ...
www.applianceblog.com/.../40588-Kenmore-dishwasher-lights-flashing-...
Aug 26, 2013 - 10 posts - ‎3 authors
Thread: Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry" ... A few months ago, we had a brief power outage and the next morning, noticed the "Hi Temp" and "Heat Dry" lights were flashing. ... Well since then, the dishwasher intermittently stops mid-cycle and these same lights ... Thread: GE Eterna QuietPower 2 Normal and Heated Dry ...
Feb 24, 2012
Kenmore Elist 665 dishwasher Smart Wash red light ...
Dec 23, 2011
Heated dry blinking +17 times - ApplianceBlog
Nov 14, 2010
Heated Dry light blinking
Nov 7, 2010
More results from www.applianceblog.com
Why won't my dishwasher start and why does the "Heated Dry"
www.shopyourway.com > Manage My Life > Questions
Nov 16, 2009 - When I hold down the Heated Dry button to turn the control lock on it ...my dishwasher start and why does the "Heated Dry" light keep blinking ...
Dec 01, 2015 | Dishwashers
How to reset Kenmore Elite 665-16572202 Dishwasher...clean light blinks 7 times pauses then repeats. My model does not have a Heated Dry button it has an Air Dry button.
Here's the key sequence(s) to use, depending on how your keys are labeled:
Heated Dry - Normal - Heated Dry - Normal; or
High Temp - Air Dry - High Temp - Air Dry; or
Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry.
This will start the diagnostic cycle. Let the dishwasher run for a few minutes, and then press Cancel to stop the dioagnostic cycle and clear the error. Please note, that this clears the error, but if you haven't found the cause (water-not-heating error), the condition will come right back the next time you run the dishwasher.
Jan 19, 2015 | Kenmore Dishwashers
What is the sequence to reset kenmore dishwasher 665.16719000? The buttons from left to right are pots/pans, normal wash, water miser, china gentle, quick rinse, high temp, air dry, delay wash, start
Press "high temp wash, heated dry, High temp wash, heated dry, high temp wash, heated dry, high temp wash, heated dry, high temp wash"
All the lights will go solid at which point you press cancel to reset the board.
**NOTE** if you don't have a "heated dry" button, use the "air dry" or "energy saver dry" button instead.
Apr 03, 2014 | Kenmore 24 in. 16052 Built-in Dishwasher
Kenmore Dishwasher Model 665.16719000 pushpad buttons lights flashing and won't work.
Apr 03, 2014 | Kenmore Dishwashers
Reset kenmore dishwasher
The most common "reset" key sequences are:
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry).
On some of the newer Whirlpool, Kenmore, KitchenAid dishwashers, you start the diagnostic cycle by rapidly pressing the 3 left-most keys in the following sequence: 1 2 3, 1 2 3, 1 2 3.
Jun 15, 2012 | Kenmore 24 in. 17482 / 17484 / 17489...
Light is on for heat dry but won't allow me to run a cyle or turn on
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Daniel
Apr 17, 2011 | Frigidaire Professional Series 24 in....
Normal light blinks
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry,Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Daniel
Apr 17, 2011 | Whirlpool Dishwashers
Drying problems
Check the front control panel for a AIR DRY / HEAT DRY switch. Perhaps the switch is in the AIR DRY position. If so and you really want to HEAT DRY your dishes, set the switch for HEAT DRY.
Second, it is not a bad thing to let your dishes AIR DRY. It saves money! Just open the Dish Washer door after the last rinse cycle has finished and let the dishes AIR DRY manually. In a hour or so they can usually be put away.
You can also check for the heating element.Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element. Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it.
Thank you!
May 14, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
When i turn dishwasher on it goes to 1 and just stays there.one time a tech reset my old one by pressing three of the buttons but i cant remmember which ones. its a queit partner 1v
Normal-Heated Dry, Normal-Heated Dry, Normal-Heated Dry, Normal-Heated Dry.
OR (depending on the model)
Hi-Temp-Heat Dry, Hi Temp-Heat Dry, Hi Temp-Heat Dry.
Hope that work`s. Keep in mind there is a underlying problem to cause the "1" to appear in the display repeatedly, so this is only a short term cheat.
Good luck.
macmarkus :)
Dec 08, 2009 | Whirlpool Dishwashers
Indesit DI620UK Dishwasher fault
If the dry cycle has a problem, check these:
Heating element
Drying fan
Thermostat
Heating element Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element.
Drying fan Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it.
Thermostat Some dishwashers have a thermostat that monitors the drying temperature. If the thermostat is defective, the heating element may not cycle on or off properly. If that's the problem, you need to replace the thermostat
Jul 19, 2008 | Dishwashers
Washing Machines Logo
44 people viewed this question
Top Splendide Washing Machines Experts
Doug Adams
Doug Adams
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
