Question about HTC Incredible S S710e
Network ic sim - HTC Incredible S S710e
Vodafone sim
firstly check up with other operator......i.e. airtel etc. ....if network appears with other operator sim inserted, then it is hardware problem.....to confirm this.....insert voda sim....switch on the phone ...then go to menu>settings>phone settings>network selection>and select manual.....now your phone will start searching network......and network list (so called service provider list (or SP list))will appear.....on the top it should be Vodafone........if Vodafone appears then select it....it done......if Vodafone does not appear then its hardware problem.... solution depends on phone model....pl. mention it....older phones develop this this fault when a IC called PFO/PF/PA/or Duplexer develops fault........later phones have a IC called FEM ic in place of duplexer. in latest models its network ic.....this has to be replaced......some new phones have no solution for this
May 02, 2014 | Nokia Cell Phones
My sonyxperia u has no signal its not the sim
Hello Dear:::::::
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Jan 18, 2013 | Sony Xperia U ST25I Android OS v2.3...
Htc salsa no net work covery on sim
Hello My Dear:::::"""::
First Option:
Secend Option:
Jan 17, 2013 | HTC Cell Phones
Insert sim card is found in low signal
First:
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Second:
First Option:
Secend Option:
Jan 12, 2013 | Samsung GT C5130 Mobile
My cell 1650 not show signal
First Option:
Please Phone in the Other Sim and check the phone Network Signal If Network Signal Problem Not Solved For Other Sim So
Secend Option:
And Network Signal Problem will Solved Quickly
Jan 04, 2011 | Nokia 1650 Cell Phone
Not a network shown n not hear sound so pls give me coustmer care in udaipur rajasthan india
First Option:
Secend Option:
And Network Problem will Solved Quickly
Dec 29, 2010 | Motorola Mobility ROKR E8 Cellular Phone
Lost the network usually
First Option:
Secend Option:
Dec 29, 2010 | Samsung SGH-F500 Cellular Phone
No network
First Option:
Secend Option:
Dec 29, 2010 | Nokia 2600
Sir i am using nokia 5300xprssmusic. i am network problem .signals come but aftersometime they totally vanish for all sims
First Option:
Please change Phone in the Other Sim and check the Phone Network if Network Same Problem So
Secned Option:
Aug 15, 2010 | Nokia Lands Phones
HTC Incredible S S710e Logo
18 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
