Question about Fargo Pro L ID Thermal Printer
ALWAYS SAYING CARD JAM - Fargo Pro L ID Thermal Printer
    Master:
  • 552 Answers
Blank cards not inserted properly - tray out of alignment
Posted on Oct 20, 2013
Why my canon printer is saying paper jam?
here is nothing wrong in saying, "paper jam issue in canon printer " one of the most irritating issue.
especially when you are going to print any import document and it got stuck in the middle of printing.
when we face paper jam issue with our printer. we always try to contact to a technical expert for fixing such kind issue. while most of us don't know, you can fix paper jam issue in canon printer by yourself without inviting any technical person at your home.
For More details check this
how to fix paper jam issue in canon printer by myself Fixotip
Jan 02, 2018 | Canon Office Equipment & Supplies
It says paper jam remove toner but there is no paper jam at all
Try power cycling the printer. Otherwise there is a paper jam or a sensor is dirty. Every time I hear someone say there is no paper jam I almost always find one. Use a flashlight they can be very very small.
Dec 18, 2012 | Office Equipment & Supplies
Card jam please clear printer
Hi Imran,
I realise you probably resolved this issue a long time ago, but this may help others with the same problem (Card Jam on Rio Pro / Enduro / Enduro+).
Immediately after the Card Jam - Please clear printer mechanism, there should be an error number. All card jam errors begin with 06:??. Most common would be Card Jam 06:05.
This error means that the rear card sensor has detected a card.
However, the card has not past through the sensor. This could indicate a failed card sensor (always on). This may sometimes be caused by static on the cards.
To confirm this, switch to 'Hand Feed Mode' (on the front panel: Menu -> Hand Feed Mode -> ON). Cards are then fed (when requested) from the hand-feed slot on the front of the printer. If the error changes from Card Jam 06:05, to General Error 24:08, this would suggest a faulty rear card sensor (very rare).
Try leaving the printer switched off, and with the DC power disconnected for a few hours. If the problem persists, you should contact Magicard Technical Support.
With Best Regards,
MC.
Apr 09, 2012 | Magicard Rio Card Printer
My printer is saying "Carriage Jam" and that I should remove Jam and press okay. I can not see a jam anywhere and have tried everything. Do you have any suggestions?
There are a number of things that can cause a carriage jam. To prevent it from recurring, one should keep in mind a number of things.
Always ensure that the paper tray is not overloaded as this might result in the paper being stuck inside.
Also the paper being used should be as per the manufacturer's recommendations.
Turn off the printer when removing bits of paper.
If there is a broken gear, do not repair it yourself. Call an expert technician to mend it. get more help for HP Carriage Jam .
Sep 20, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
Zebra P110 ID card printer card jam on yellow ribbon.
In the driver go to the tools section. In the command to send to the printer box type !SA then choose send the will calibrate all your sensors. As always make sure your clean the printer.
Mar 17, 2010 | Fargo DTC510 Card Printer
Says a front paper jam but no paper jammed any where
Your paper feder belt has ink on it and will not feed the paper. Remove the rubber belt and clean it good and clean and use compressed air on the printer tray area. If this does not work open the front feeder tray and set your computer to print from it. After about 500 copys it will normally have c leaned itself and be ready to feed from the main roller.
Feb 14, 2010 | OKI C5500n Printer
Card Jam 02:16 Error in Magicard Rio 2E Printer
Check the front rollers all turn when the cleaning button is pressed with the top open.
Check the front pinch rollers on the thin metal shafts are pulled down onto the cards by their springs. Check that the ends of the pinch roller shafts are retained in the plastic cam followers. The card is not being gripped to drive it back to print the Magenta panel.
Sep 23, 2009 | Magicard Avalon Duo Thermal Card Printer
Paper jam when printing onto my greeting cards
Hasn there is a roller which help the page or card to move into printer which if use frequently get so smooth that the page is not printed out instead get jam try getting printer service and replacing with New Roller.. if you don't understand any thing regarding ... ask me
Jun 23, 2009 | HP DeskJet 6540 InkJet Printer
E4 comes up on panel saying clear paper jam
With out knowing which stylus you have there error either refers to a paper jam or ink cartridge error. If it takes the beging of the paper but then stops it could be a matter of worn rollers that are not able to grip and move the whole page.
Nov 19, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Printer saying paper jam, checked it out, there is no paper in it
Always it is giving the same error are,sometimes after some print outs?
IF it is always then u need to open the printer.
Regards
T.Boopathy
Aug 06, 2008 | Samsung Office Equipment & Supplies
Fargo Pro L ID Thermal Printer Logo
48 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
