Question about Splendide Washing Machines
Replacing circuit board - Splendide Washing Machines
I have an LG 55 inch tv (55LA6205-UA). I have sound, but my picture goes out. I did the flashlight test and can still see an image on the screen. I do not know which board to replace.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jan 16, 2017 | LG Televison & Video
What would cause a black screen on vizio LCD Tv? I have sound but no picture
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jan 14, 2017 | Vizio Televison & Video
LG tv 55GA6400 has sound but picture keeps going black after a minute or so.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jan 13, 2017 | LG Televison & Video
Vizio tv 37" picture started to get darker
Jan 11, 2017 | Vizio Televison & Video
Toshiba e 233 is error code C550 how to clear
Communication error has occurred between the RADF and the scanner.
(1) Check if the harness connecting the RADF board and SLG board is disconnected or open circuited.
(2) Check if the conductor pattern on the RADF board is short circuited or open circuited.
(3) Check if the conductor pattern on the SLG board is short circuited or open circuited.
(4) Replace the RADF board.
(5) Replace the SLG board.
Jul 16, 2016 | Toshiba Office Equipment & Supplies
I have a samsung tv un46eh500 with sound and a dark image...is it backlights?
May 10, 2016 | Samsung Televison & Video
Screen went black yesterday. Can I replace the circuit board?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.....
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board...
Apr 11, 2016 | Televison & Video
Braun QS3 Range Hood
The circuit board that we use to replace the old ones are a new generation of circuit boards. To this day i have never had to replace a circuit board that i had already replaced, and beleive me i replaced a fair share.
Jun 13, 2008 | Broan-NuTone Allure III QS330SS Kitchen...
Washing Machines Logo
Top Splendide Washing Machines Experts
Doug Adams
Doug Adams
isaac johny
isaac johny
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
