Question about Panasonic NN-S252WF Microwave Oven
MY MICROWAVE WAS HIT BY A POWER SURGE. CAN IT BE FIXED?
  • 2,113 Answers
Always... but is a WalMart model cheaper than the repair.
Posted on Oct 21, 2013
Samsung Microwave Oven SMH7159 No Power
The power outage may have been accompanied with a power surge. That can happen with lightning strikes, or if a large inductor (electric motor or equivalent) happened to be on the same power line at the time of the outage. There's a good chance a surge took out the control panel.
Aug 06, 2016 | Samsung Microwave Ovens
House was hit by lighting and now my microwave wont work
It is likely your microwave was hit by a power surge associated with the lightning strike.
Jan 14, 2013 | Microwave Ovens
We have a Hotpoint RVM1435WJ01 above the range microwave. We lost our electricity one day due to an outside electric wire splitting - when the electric company fixed the wire, the power came back to...
A mains surge may have taken out the fuse. To find the fuse, remove it from the mains, remove the outer cover and follow where the power cable enters the case. There will be a PCBoard with a fuse on it.
Always replace the fuse with one of exactly the same type and value!
Mar 21, 2011 | Hotpoint RVM1435 Microwave Oven
Hello. My Panasonic NN-K153W microwave owen keypad does not responding, beside three keys- stop, clock and the one with symbol of microwave in the left upper corner. I can not setup the clock because no...
Other than a complete power off, I know of no reset switch on any microwave ovens. I own a panasonic myself.
I would leave it unplugged for a while, at least 15 minutes or so, and leave the door open, to turn on the inside light (which won't light if unplugged but) so it might discharge any capacitors holding residual power to the circuit.
If it wasn't power protected, it could have taken a hit.
If it is plugged into a surge protector, they wear out. You might be able to make a claim on it through the surge protector manufacturer, if it has a warranty, and you have receipt. Surge protectors do wear out, and most unless they're the cheapest, will have a warranty that covers equipment. The wear out because the varistor which provides the voltage clamping during a surge become conditioned. Initially they clamp around 150V to 180V, but as they age from repeated surges, their clamping voltage rises until it no longer protects the equipment. Often you can tell, if the surge protector LED is blinking or intermittent, the company will replace the surge device if you make a claim on the protector, if it fails while in use, they usually cover the equipment, unless the warranty has run out, but many give lifetime warranties.
The reason some keys may have been working is because after a small surge, the logic states can go indeterminate, which means some work, and some won't. If it's not damaged, a full power off for some time may restore it to initial conditions.
Hope this helps. They should build in surge protection, and I think mind does have some; but, if not, I hope it's in warranty for you.
Jul 04, 2017 | Panasonic NN-T888S Convection/Microwave...
Microwave not getting power
Unplug the microwave oven from the surge protector and plug it directly into a working outlet. If the microwave now works you will know that it is the surge protector that is not working. If the microwave still doesnt work you may want to trash it and just get a new one as they are now much cheaper, many around 50 dollars, and more efficiently use power.
May 12, 2009 | Microwave Ovens
Won't work
unplug your microwave; remove the top under the top you will see a small white cylinder
(a ceramic fuse) it looks like a glass fuse only made of white glass replace this they are sold at radio Shack
Apr 22, 2009 | Kenmore 63682 / 63684 / 63689 Microwave...
Will not turn on, clock & light do not work, breaker on
try unpluggin it for a few minutes then pluggin it back in, but it sounds like it has been hit by a power surge.
Dec 30, 2008 | Panasonic NN-T793SF Microwave Oven
Demo mode
I had the same problem trying to get rid of demo mode. Press the "clock" button 3 times in a row and problem fixed!
Jun 19, 2008 | GE XL1800 1100 Watts Microwave Oven
Possible power surge?
Sounds like you got a surge which damaged the control panel. This is the most likely thing. We regularly repair these control panels nationwide for $32.50. A fuse is designed protect against excessive current. But if you have excessive voltage (a surge or spike), it can be so fast that it gets past the fuse and damages the control panel without actually blowing it. While the panel does have surge protection to keep that surge from actually destroying the control panel, the panel is damaged and will have to be repaired. If any power line connections were broken or are suspect, I hope you have contacted the power company. Either way, I would test any affected outlets to be sure the neutral and ground are present so the voltage output is within the proper range.
Nov 16, 2006 | Samsung MW5351G Microwave Oven
Panasonic NN-S252WF Microwave Oven Logo
121 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
