Duoplus 300wr Need help,my connection stops intermittently when i am busy downloading a file. I am on a 1mbps telkom line with uncapped adsl, my firmware is 120.70.6 and can only find a update for 120.70.5. What can i do to stop my connection from timing out every time.
SOURCE: Router stops responding with red alert light turned on
Guys,
There is a new Firmware version 3.1 Beta release that is fixed lots of problems, though this version is unofficial and not yet released on 3Com website.
Download link: [url]http://aragostabbs.altervista.org/request.php?37[/url]
Enjoy!!!
Version & Build Date
3.1/ 2007/10/17
Modification
1. DSL code base update to 3.10.02.
2. ADSL phy driver version : A2pB022g.20H.
Bug Fixed
1. Java script error in Internet Setting page.
2. Dyndns and No-IP are Unworkable. Can not update server ip address.
3. Some gif link can not finish after added DDNS configuration.
4. RIP seems unworkable, Can not enable this function.
3.0/ 2007/9/24
Modification
Bug Fixed
1. ‘%’ issue in username and password.
2. DMZ cannot be removed.
3. Internet WAN add/modify UI error
4. IPSec unworkable. Can not to add and save IPSec Configuration.
5. Can not edit and cancel Port Mapping Configuration.
6. Change login timeout value, does not need check a password.
7. ALG Link unworkable(Removed).
8. Dyndns and No-IP are Unworkable. Can not update server ip address.
9. It does not arrive at the DDNS service which I set. Same issue in the TZO.
10. RIP seems unworkable, Can’t to enable this function.
11. If input ASCII value excluding 0-9 into year field, Current time will save and change to the “1970 0:00:00”.
12. “URL filter” Priority must higher than “PC Privileges”.
13. Content filter seems unworkable.
14. SIP Filter seems unworkable.
15. Some attack can’t be “Intrusion Detection” blocked. Ex: syn flood, ping flood, UDP flood.
16. At Internet Settings -> WAN page, if i enable the option "PPPoA" in Connection Parameters table, the IP Address field will display "undefir".
17. PPPoE does not work.
18. In WAP-PSK When the input value includes?’?, Encryption Function will crash.
19. A “Channel” item of Device Info information is not displayed normally.
20. Channel range is not correct.
21. Can not to disable “Radio” Function.
22. If DHCP lease table status is an “Expired”, a table will has some wrong.
2.9B_ A_SH_DATA_PUMP_20H/ 2007/9/13
Modification
Bug Fixed
1. Virtual server cannot be removed.
2. ROUTER ADSL PC Anywhere will not pass.
3. Java script error on E-mail alert function.
4. Java script error on Internet WAN setting function.
5. Java script error on WPA-Radius server function.
6. Add Jordan in country list.
2.9/ 2007/7/20
Bug Fixed
1. 3Com the 5th UI refine.
2. Support 3 more DDNS secrecies.
3. Support ‘-‘and ‘,’ for virtual server.
2.8b8/ 2007/6/8
Bug Fixed
1. debug firmware to dump memory information.
2.8b7/ 2007/5/15
Bug Fixed
1. failed to connect to device after unplug cable.
2.8b6/ 2007/6/5
Bug Fixed
1. DMZ entry Patch.
2.8b5/ 2007/5/15
Bug Fixed
2.8b4/ 2007/4/30
Bug Fixed
1. Support special characters for PPP username and password.
2. Support WPA-PSK with special characters.
2.8b1/ 2007/4/13
Bug Fixed
1. Fix UDP block port configuration lost problem.
2. support flexible schedule rule.
2.8b/ 2007/3/30
Bug Fixed
1. Fixed IPoA setting cause “out of memory” problem.
2. Add reboot log for debugging purpose.
3. Modify version name format.
2.8a/ 2006/12/22
Modification
Upgrade dsl driver.
2.8/ 2006/12/22
Bug Fixed
1. 3Com GUI refines. Modify schedule rule.
2.7d/ 2006/12/22
Bug Fixed
1. 3Com GUI refines. Please refer to SG GUI review pt 3.xls.
2. Disabled SIP ALG at default.
2.7c/ 2006/11/22
Bug Fixed
1. DHCP assign range problem.
2. DHCP fixed IP assign issue.
3. DHCP lease table not line up problem.
4. Turn one DNS proxy if NAT disabled.
5. Modify telnet session welcome message (BCM 96348 ADSL router to 3Com ADSL router).
2.7b/ 2006/10/27
Modification
1. Change system objects ID to 1.3.6.1.4.1.43.19.16/17.
Bug Fixed
1. LAN subnet mask shows up invalid error if set the correct value.
2. DHCP IP range assignment did not check weather is on the same subnet or not.
2.7a/ 2006/10/20
Bug Fixed
1. UI pop up warning message about DHCP IP range assignment.
2. LLC and VC/MUX display error.
3. Add DNS server to PPPoE and PPPoA.
4. Instability issue.
5. Login error while type correct password and press enter.
6. Upgrade countdown seconds is missing.
7. PC in different subnet unable to connect SNMP.
8. Lose System log settings after reboot.
9. Directly open file while saving configuration or log will cause open empty file.
2.7/ 2006/10/05
Modification
1. UI modification according 3com’s request.
Bug Fixed
2. Fixed Matis bugs. (Refer to mantis bug system)
2.6/ 2006/9/26
Modification
2. UI modification according 3com’s request.
Bug Fixed
3. Fixed Alert light on system hang problem.
2.5/ 2006/9/8
Modification
2.4a/ 2006/8/28
Modification
Bug Fixed
1. Set NAT default setting to enable.
2. Display URL block message.
3. Modified settings to apply right away. (only partial settings, some of settings still need reboot)
4. Wizard does not “pop up” after upgrade or reset to factory defaults
5. “OfficeConnect” banner in blue does not cover entire width of page.
6. Fixed channel in worldwide version.
Posted on Nov 14, 2007
  • 38 Answers
Is the actual router not responding or the internet?
(IE - can you still log into the router but the internet won't work, or will it not even connect to the router)
Posted on Feb 28, 2008
yboyandrei
  • 828 Answers
SOURCE: connection from billion 400g wireless adsl router to Fujitsu
please check your fujistu if there is wireless lan built-in...
Posted on Jun 16, 2009
SOURCE: firmware update for netgear router
I was having the same issues too. I followed the steps dotted all over the internet and was getting stuck in exactly the same place. No matter how hard I tried, I just kept getting the 'invalid filename' issue.
Eventually I figured it out - the way that Netgear/Virgin have blocked firmware updating is to break the filename checking page so it doesn't accept any files. What we need to do is bypass the filename checking code so that the firmware upgrade system can then handle the file, and we're going to do this by manipulating the web page using a tool called Firebug.
Here is the solution:
1) If you haven't already got it, install Mozilla Firefox 3 (there is good reason for this - I'm not just shamelessly plugging it! :P).
2) Install the 'Firebug' extension for Firefox from https://addons.mozilla.org/en-US/firefox/addon/1843 and restart your browser when requested.
3) Navigate to your router's admin page, and fill in your login details (if you don't know them, it's likely to be the one written on the bottom of your router).
4) Navigate to the router upgrade page (the one where you select the firmware to upload' and select the location of the firmware file, like you would normally. Now, instead of clicking the 'Upload' button, press F12. This should bring up Firebug in the bottom quarter of your screen.
5) Now, click the moz-screenshot.png2193448.jpgbutton at the top of the Firebug panel and then click on the 'Upload' button. This will bring up the code for the upload button, where it does the filename checking. It'll look like this:
6) It looks like Netgear have actually stripped out the real checking code so it can't be used, so we'll need to fool the page into thinking everything's fine and dandy with the filename so it can update the firmware. Click where it says "return checkData();" and replace it with "return true;".
7) Finally, click the upload button. The router should now accept the file and start updating.
And hey presto! You have a non-nargled wireless router with the latest firmware!
Posted on Sep 25, 2009
  • 177 Answers
SOURCE: WRT120N no .bin or .img file in firmware update download
Hi Friend
in order to upgrade the firmware please follow the steps:
1. Click the link (http://homesupport.cisco.com/en-us/wireless/linksys/)
2. Enter the model number of the router and hit enter.
3.Click Download Tab
4.Now enter the hardware version of the router (which you can find by turning the router upside down)
5.Now you can download the firmware which is a .bin file and save it to the desktop.
6.Open the router page and click Administration and click Firmware upgrade.
7.Select the file from the desktop by clicking Browse and start upgrade.
8.Turn off the router for 30 seconds after upgradation and turn it on..
i hope this will resolve the issue.
Regards
Chiranjeet
Posted on May 22, 2010
When will I receive this credit on my account?
We are FIXYA do com, we are NOT Telcom. Contact them direct.
Telkom
www.telkom.co.za/
This website uses cookies. By continuing to use this website you are giving consent to cookies being used. For information on cookies and how you can disable them visit our Privacy and cookies policy. Find out more about cookies here. Telkom For Me Telkom For My Business. Shop. Mobile · Home · Business ...
My Telkom
Telkom is Africa's largest integrated communications ...
Telkom UNLIMITEDhome ...
This website uses cookies. By continuing to use this website ...
Telkom SA SOC Limited
Welcome to My Telkom. We have given your self-service portal a ...
LTE Deals
SmartBroadband Wireless · SmartBroadband Wireless ...
Get Help
Let's fix it. Troubleshoot using our self-service tools, read our ...
Shop by plans
Go mobile with Telkom by browsing our range of personal ...More results from telkom.co.za »
May 06, 2018 | Internet Computers & Internet
Complaint telephone number for Telkom?
Talk To Us - Get Help - Telkom Web Site
www.telkom.co.za/today/help/personal/
  1. Cached
  2. Similar
Landline. Check faults, move line, calculate call cost. Support & Downloads ... An authorised Financial Services Provider - FSP no. 46037. Top Feedback?
Telkom Customer Service, Complaints and Reviews - Complaints Board
www.complaintsboard.com/telkom-b119777
  1. Cached
  2. Similar
Telkom complaints and reviews. Contact information. Phone number: +27 12 311 2186. Submit your complaint or review on Telkom.
Telkom call centre number! - Contacts details in One Place
www.contact-us.co.za > company > Telkom
  1. Cached
  2. Similar
Contact us business directory offer you access to Telkom customer care and call centre contact details (VAS rates apply, free minutes don't apply)
Telkom Customer Care Number- Toll Free Complaints Helpline ...
customer-carenumber.com/telecommunication/telkom-customer-care-number/
  1. Cached
  2. Similar
Feb 9, 2016 - The customers in case of inconvenience could dial Telkom Customer Care Number to get in touch with the customer care of the co. we would ...
Telkom Complaints Department - MyBroadband
mybroadband.co.za > ... > ADSL and VDSL Discussions
  1. Cached
  2. Similar
Sep 6, 2005 - 15 posts - ‎12 authors Hi, I just had an unintelligible phone call from a lady named Mpumi, claiming to ... I asked for her employee number, and she started shouting at me. ... Does anyone know of a Telkom complaints department (I cannot find one ... Telkom customer care contact number ? 10 posts 29 May 2013 Telkom 24-Hour Support Number 6 posts 26 Sep 2011 Contact NUmber for someone big from Telkom 8 posts 28 Nov 2008 Vodacom call centre number for contract customers? 9 posts 10 Nov 2006 More results from mybroadband.co.za
Complaint telephone number for Telkom Google Search
Oct 28, 2016 | Computers & Internet
Service complaints
set wifi mac address phone c375
Dec 15, 2013 | Health & Beauty
My ADSL duo plus 300wr does not connect even after 5 phone calls to your 0800500200 number. Please help as I am desperate to contact my children in Australia.
I have had problems with different DuoPlus 300WR modem that do not synchronize or only after 3 hours. Best advice I have is to exchange it for another make like D-Link, Netgear or Billion.
Jan 19, 2011 | Computers & Internet
Connection from billion 400g wireless adsl router to Fujitsu
Jun 16, 2009 | NetGear DG834G 802.11G Wireless ADSL...
No Line on US Robotics ADSL Wireless Gateway
Initially what I suspect is that your USR's connection to your ISP is intermittent but with that of the USB modem is consistent. This is clearly an ISP issue and should be resolved by them.
One thing you can try is to verify the integrity of the line splitter that is commonly used to split the 2-wire signal to the telephone and to the modem/router. You can actually remove the splitter and connect the telephone line straight to the WAN/ADSL input of the USR 9106 Wireless Gateway and check if their is an improvement or if your ADSL and WAN IP will light up consistently.
Alternately, if your ISP is too busy to attend to your concern, you can try mimicking the USR's WAN settings to that of the USB modem's. While still using the USB (provided by your ISP) determine its WAN IP settings. This would be IP address, Subnet Mask, Default Gateway and DNS. You need to access the USB modem to get this data. Should you need detailed instructions, pls post back the make/model of the ISP provided USB modem. If you were able to gather the information. Connect your USR 9106 Wireless Gateway (Ethernet 1~4) to your PC using a LAN cable and enter its configuration page. In its WAN/ADSL settings, use the numbers gathered from the USB modem. You may need to do a full hard reset on the router (rear panel) prior to putting in the numbers.
Hope this be of initial help/idea. If problem persists, pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 06, 2008 | Computers & Internet
Computers & Internet Logo
265 people viewed this question
David Payne
David Payne
