Question about Garden
Replacing pull cord and recoil spring on MTD Black 139cc OHV Push mower
  • 4 Answers
SOURCE: I have a cub cadet lawn mower broken pull cord
just rewind the spring starting with the outer end and fill it back into unit. I always have the rope extended and rewind it back in and reinstall
Posted on Jun 07, 2009
MNfisherman
  • 11896 Answers
SOURCE: Yard man mower 139cc OHV spark plug
You can purchase a boot puller or take a pliers and grab exactly on top of spark plug and pull off. Some do stick on harder than others.
Posted on Aug 17, 2009
  • 143 Answers
SOURCE: Lawnmower won't start
Remove the bowl from the carb. and blow it out with air.
Posted on May 07, 2010
  • 61 Answers
SOURCE: lawn mower pull cord
This works best with two people. Remove cover and pull cord will be inside cover. If your handle on pull cord is attatched to a metal ring up on the handle, you will need 8 foot of new pull cord.
With all the old cord removed, wind cord pulley 6 revolunations, now, have someone hold the pulley, while you string the new cord thru pulley and out the cord hole on cover. Be sure to put a knot on the end going thru pulley. Draw cord all the way thru and out of the cover. Attatch the handle and let it rewind. You will have extra cord, this will be used up going from engine up the handle. I hope this helps
Posted on May 09, 2010
hunter19_46m
  • 7482 Answers
SOURCE: My 2 year old Yard Machine 21in 139cc MTD engine
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
Posted on Jun 03, 2010
How do I replace the starter pull cord on a Yard Machine 21 inch rear bag mower
New "powermore" engine? recoil rewind starter comes as a complete assy. If the spring is broken this is your only option
Oct 28, 2012 | Yard Machines 11A54MC006 21Inch 139cc MTD...
Gas is flooding out through the muffler in my push mower
sounds like the needle valve in the carb is not seating replace them and the oil
Jul 05, 2012 | Yard Machines 11A54MC006 21Inch 139cc MTD...
I replaced the pull cord on an mtd mower. and now it won't rewind the cord?
You have to tension the spring before installing the cord. Remove the cord. Put the recoil assembly in a vise. Prepare the ends of the cord so they can be threaded into place. Spin the pulley in the proper direction until it is tight. Align the hole in the housing with the hole in the pulley. Thread the rope in and knot it and pull tight. Slowly let the spring tension retract the rope. Cut the rope to length, install handle, knot and test.
Gary
Aug 27, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Brand new and cant pull recoil
You say brand new so I assume that your pull cord has tangled up somehow. Things happen sometimes for no reason. To fix and check, remove the top cover to your mower and any attachments. The recoil is in the top cover. Look at it closely and try to loosen the cord. . Replace top cover and your ready to go. GOOD LUCK.
Jun 29, 2011 | Yard Machines 11A54MC006 21Inch 139cc MTD...
Crazy question but where is the primer button on the yard machine 139cc 21" lawn mower???????
The primer button is usually on the carburator of your machine. Most of the time on the side of the carburator , but sometimes on the front of the carburator. GOOD LUCK.
May 29, 2011 | Yard Machines 11A54MC006 21Inch 139cc MTD...
Where to find the spark pug on my 21inch 139cc mtd ohv lawn mower
It should be under a rubber boot between the valve cover *(stamped OHV or OHC) and the muffler.
Good luck and be careful. Dont pull that boot when the engine is hot!
Jul 07, 2010 | Yard Machines 11A54MC006 21Inch 139cc MTD...
Pull string won;t recoil
The recoil spring has broken. These are available at any lawn mower parts supply store. The process of changing the spring is tedious but can be done by anyone with average mechanical ability. If you removed the recoil assy (and air shroud if it is riveted on) and took the assembly to a Lawn Mower Repair shop usually they will change out the spring while you wait. If you can't get the recoil assy off take the mower with you to the repair shop. Again most shops will fix it while you if wait but if they are very busy usually they are serviced within 24 hours.
If you do attempt this yourself check in the tips section of FixYa on how to change the recoil stater rope after replacement of the spring.
I highly recommend you replace the pull rope at the time of the recoil spring replacement.
One final note... there is a possibility that the pull rope spool has been damaged where the spring attaches.
Thanks for using FixYa,
Kelly
Apr 28, 2010 | Mtd 22" Yard Machine Push Mower
Garden Logo
67 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
