My uk,now tv box when connected via hdmi,cannot be seen on my sharp lc-32SH130k TV.sorry about non subject video.
According to sharp technical support I should use the latest 1.4a hdmi cable.would you agree with this step?Before I send off for cable.On the net,advice says hdmi 1.4a is a type of connection not cable,can you enlarge on this statement/theory?
  • Michael Wiseman
    Michael Wiseman Oct 19, 2013
    now tv box has been proven ok,tried both hdmi ports ,result no picture.So iam at a loss,according to shrp technician I shoul try a 1.4 cable ,so that is my next step trying a 1.4 cable ,now i will have to buy a cable.
  • 2,184 Answers
Have you tried another hdmi source like a games system on the cable and tv hdmi socket to rule out a faulty now tv box
if other source still not sending picture try another cheap cable to rule out cable fault (borrow would be a good idea)try one of the other hdmi sockets on the tv to find the item that is the problem hdmi 1.4a is for 4k picture support as the cable needs a higher bandwidth to send the larger info stream
Posted on Oct 19, 2013
  • Michael Wiseman
    Of course,trying a games system on the hdmi cable will prove if cable is at fault.next step finding a game system!will let you know , thanks
4 Suggested Answers
swami nathan
  • 208 Answers
SOURCE: Sharp Aquos LC-37P50E connected to computer with HDMI cable
I got the chat , but some how it got disconnected.
But i would like to help you in this aspect.
HDMI stands for High Definition Multimedia Interface, and supports transmission of both audio and video in high fidelity.
First make sure these things,
Both your computer and your TV will need to support HDMI interface.
It's quite a recent thing in PC graphics cards, so you may have to resort to S-Video, DVI or VGA for the video, plus a 3.5mm stereo cable (or the optical TOSLINK equivalent) for the sound.
Let know your comments and i will follow up with the suggestions.
Thanx for using fixya,
Good luck.
Posted on Sep 28, 2008
gymhasafit
  • 31 Answers
SOURCE: Sharp Aquos LC-46d65U HDMI connect
First off a little tip that manufacturers don't tell you is that you HAVE to TURN OFF the POWER to ANY UNITS that you are Connecting to via HDMI!!!!!!! If not you can short out the Inputs!!!!!!!! HDMI is usually Automatic, But sometimes you need to go into the Menus on all Devices to the HDMI section and write down their settings and compare them. Any definition that you are not sure of check the Manual or Google it! Match all the Settings (there won't be Much!) Hopefully the Inputs were not Damaged it only takes one time to short it out and then the Repairman makes a few bucks! Good Luck!
Posted on Apr 29, 2009
  • 57 Answers
SOURCE: Insignia TV no audio on non HD channels via HDMI cable.
have you tried to change the audio settings to HDMI on tv? when u have HDMI hookd up u have to change the audio to HDMI also
Posted on May 31, 2009
Where is the HDMI connection on my Sharp LC-46SB57? I installed X1 and cannot get picture. Sharp Input 1,2&3 are grayed out but Inputs 5Roku & 6blue ray work.
The X1 box acts like a set-top cable box. The HDMI output can be connected to any HDMI connector. There are three HDMI connections on the rear of the set. You have the Blu-Ray connected to one of them, Input 6. You should have no issues with connecting the X1 to either Input 7 or Input 8. There is no specific "TV" HDMI connection. You simply use the remote to select the HDMI port that the X1 is connected to.
Nov 18, 2015 | Sharp Televison & Video
Sharp LC-32sb24u hdmi not working
You have to tell the TV which HDMI input to use. ie you should be able to press a button on your remote to do this. On my tv we can choose between 4 different HDMI inputs via the remote.
Dec 23, 2013 | Televison & Video
Sharp TV problem LC-40E77UN Sharp Blu Ray
PLEASE place your question in the appropriate forum/section under TELEVISIONS, because this is the VACUUM section. That way, someone knowledgeable about your problem can help you.
Oct 19, 2013 | Televison & Video
No picture
It sounds like the Bluray player may be outputting the signal at a higher resolution than the TV supports. If the Bluray player has a scart or composite connection, connect with those first, and adjust its settings to output a lower resolution. Then reconnect the HDMI. Hope this works for you.
Jul 17, 2010 | Sharp LC-32SB23U 32 in. LCD TV
My sharp LC-19DV22U Will not connect to my PS3
well alex welcome to fixya technical support online.i just read your problems. there is an option to your problem you can use another cables with RCA inputs capable in your PS3 that can works on videos and also you can buy video converter. thanks!
Aug 14, 2009 | Sharp LC19DV22U 19 in. LCD Television
Sharp Aquos 46" HDMI problem
I have a similar problem. The Sharp TV aquos appears to be shutting down my blue ray player and dvd recorder when connected via HDMI. They work fine and never close down when I connect them via the rca cables either single video connection or a composite 3 cable rca lead. I have 3 HDMI inputs on the tv and the problem occurs on all 3. Any suggestions?
Jun 16, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I want to make conection betwen tv.sharplc-42d62u topc
To my knowledge, the Sharp LC-42D62U do not have a VGA or DVI inputs. While they lack dedicated PC inputs, you can make use of one of the HDMI inputs, use a DVI-to-HDMI adapter and connect to a computer that has a DVI output.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 11, 2008 | Computers & Internet
Good luck.
Sep 28, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
1,198 people viewed this question
Top Televison & Video Experts
Electro Med Services...
