Question about Optimus F-1660 Fan
Will not power on and I've had it for only 4 months
  • 29 Answers
Most of time this problems are caused due to damaged power cord or when somebody plugs the 110v apparel in a 220v source. If none of this criteria match your problem, the best thing to do is search for help in the authorized assistence.
Posted on Oct 19, 2013
Stopped Working All Together
Hi, bring to your nearest service center to repair it.
May 18, 2013 | FUJIFILM Instax 210 Film Camera
My Bernina 210 Activa won't power up. I had it tuned up by a Bernina tech a few months ago and this is the first time I've pulled it out. No power/nothing. Seems like I'm just missing som
seems silly, but did you remember to plug it in? If you used a power strip, did you remember to make sure the strip is turned on?
Make sure the connection is plugged into the machine.
Good luck
Jan 23, 2013 | Sewing Machines
My WD External Hard Drive for Mac will not power up? Is there anything I can do without paying for Data Recovery? I've only had it about 4 months.
you can purchased an external usb case from newegg.com I would first take the hard drive out so you can identify whether you need a SATA to usb hard drive or IDE to usb harddrive. Connect the hard drive in and see if it will power up.
Feb 18, 2012 | Computers & Internet
Lg_tv_standby_mode
If your TV wont turn on using the power button key on the remote control and on the front panel, this is an indication of fault either on the power supply board or the main board. This kind of symptoms is not a DIY and needs to attend by a qualified Technician to troubleshoot the said boards and isolate the faulty parts.
You have mentioned that you've only used it for 4 months, then your unit is still under warranty period. Don't attempt to open the back cover because it will void the warranty, avail it because the manufacturer will fix it for free or replaced it with a new one.
Nov 08, 2011 | LG 42LC2D 42 in. LCD HDTV
Hi, I've got a automatic tag aquaracer watch that loses about 4 mins every month (about 4 yrs old). Common problem? Can this be fixed ? Or is it a lemon of a watch? Any advice welcome. Cheers.
If it's automatic and 4 years old, it's probably time for a watch overhaul. Auotmatic watches need overhauled about once every 4-5 years. It's normal for it to lose time, but 4 minutes per month may be a little extreme. So, get the watch overhauled. I would recommend Tag Heuer to overhaul it.
Sep 09, 2011 | Tag Heuer WAF2110.BA0806 Aquaracer...
My Toshiba BDX 2500ku won't turn on...Ive used it before...now it won't even open...please help....its only about 4 months old and we've only watched about 2 movies....
check the back of the player to see if the power cord has come loose, some units have a removable cord and it can get pulled.
Jun 20, 2011 | Toshiba BDX2000 Blu-Ray Player
Bush tv frequently turning itself off
make sure you have not accidentaly scheduled a power off and on if yes torn off/disable them if not check that your power cable is secure
Dec 21, 2009 | Televison & Video
HTC S710 - Battery issue
Hi guys
if u buy new battery for around 35$... its creepy thing that it again sucks within
6 month
so follow these procedure that i really got good response
1)Buy the new battery from any other dealers (u can use Nokia (std) or LG, Micromax, Onida... etc)
having same specifications as 1050mAh Lion-POLYMER 3.7v and having equivalent Size that fit into the case.
2)Now open ur dead battery, remove the sticker slowly, u wil get the polythene bag carrying the charge sheets
3)Please note that dont not disturb this polythene bag... (cutting, drilling or pinning), else it starts burning.
4)U will see a circuit above the polyhthene bag having two poles (+ve n -ve) just cut the poles of bag from the circuit and keep the bag aside
5)Now do the same procedure with new batt and remove the polythene bag.. and soilder with
the dead battery circuit. (check the +ve n -ve by multimeter)
5)Re-assemble with insulation tape and recondition it perfectly.
now check poles bofore starting.
Note : i got good result from this and i m getting 18-19hrs standby and 11-15hrs usage. Do it on ur own risk...and i m not responsable for ny harm)
Jun 02, 2009 | HTC S710 Smartphone
My 4 month old Samsung Le32R87BDX television has recently developed a problem where it keeps on cycling down through the channels automatically. When this happens the only button on the remote control that...
Since the set is only 4 months old, it should still be under warranty. DO NOT open up the set as that will void the warranty. Call for warranty service and indicate that this is an intermittant problem. If you can report any pattern about when this behavior occurs, that info will be helpful in resolving the problem.
Keep us posted.
Dan
Jun 09, 2008 | Samsung Televison & Video
Dryers Logo
65 people viewed this question
Top Optimus Dryers Experts
Pranavendra Pranav
Pranavendra Pranav
Level 1 Expert
Tom Chichester
Mister Danger
Are you an Optimus Dryer Expert? Answer questions, earn points and help others
