Question about Video Game Consoles & Games
I have a samsung syncmaster SA350 23" with one DVI and HDMI ports and my VGA card is ATI RadeonHD 4600 and i have an Xbox 360 slim so the problem now is when i turn my xbox it wouldnt start till i calibrate it with the screen by pushing the power button and hold for 10 sec then i turn up the resolution again to 1080p and i just changed the HDMI cable for a gold plated one from radioshack and the xbox insists to stay at 50Ghz and my VGA card has only 59 or 60Ghz so i cant now move from my xbox on the HDMI port to my computer on the DVI port smoothly :( dont know what to do
ctf1800
  • 4402 Answers
SOURCE: Xbox 360 HDMI Audio Analog
http://forums.xbox-scene.com/index.php?showtopic=415408
Posted on Jan 08, 2008
SOURCE: display resolution through dvi input HELP!
For the record I have a playstation 3 running to tx100 through hdmi to dvi adapter. It does all resolution no probs, including 720p,1080i and 1080p (which tx100 does do smoothly through dvi). My denon upscaling dvd player works fine too. In fact the tx100 looks totally awsome with PS3 games and Blu-ray.
Maybe your dvi lead is the wrong type (i think there are 2 types) or perhaps you could test with a differrent piece of DVI kit in case it's your pioneer causing probs? Hope this helps.
Posted on Mar 18, 2008
  • 3 Answers
SOURCE: xbox 360 sync problem - controllers will not connect
maybe the only way is take it a part and see if the sync button is not broken some how. therefore i advise you to buy a new controller maybe even a used 1 if you dont want to spend more than $20.
Posted on Mar 31, 2009
FixMyConsole
  • 174 Answers
SOURCE: Xbox 360 Pro System A/V Port
It is a problem with the Graphics chip[ on the main board.
We can repair it for you.
James
www.fixmyconsole.co.uk
Posted on May 05, 2009
techprogrami
  • 57 Answers
SOURCE: Xbox 360 nothing displayed on the screen
first make sure the switch on your cable is on "tv" not "high def"
Posted on Jun 01, 2009
I am having a Problem with my video card not letting me run an addition monitor off the vga output on the motherboard. I know it works because I can go to the bios and change it and it works but they want...
When using a PCI or PCI-E graphics card, it will disable your standard VGA output port because the up-dated graphics card and your factory VGA port require different display drivers. Usually, the drivers are conflicting and will make your system unstable and cause it to crash. In short, you can't use both at the same time. I have a Radeon HD 5450 graphics card installed on my PC and it too has disabled my standard VGA port. If you are trying to use more than one monitor, you have to install a graphics card that supports a multiple display output. The graphics card will either have 2 VGA ports, 2 DVI-D ports or 2 HDMI ports or even any combination of the 3. My card, for example, has 1 VGA, 1 DVI-D & 1 HDMI. I can run up to 3 monitors at a time via my graphics card, but I cannot run a 4th monitor from my factory VGA port. My graphics card uses ATI/AMD drivers while my VGA port requires the use of Nvidia drivers.
I hope that you find this useful.
Mar 26, 2015 | Lenovo ThinkCentre Computers & Internet
Xbox360 to pc monitor
HDMI to DVI works better than HDMI to VGA because VGA only uses simple RBG scheme.
Additionally the only way i see the Xbox getting connected to the extrenal speakers is if you get the speakers connected to the monitor/tv or whatever you are using directly. I havent tried or do not know of any way to connect the Xbox to speakers directly.
Dec 17, 2013 | Microsoft Xbox 360 Console
How to add second monitor on ECS RS482-M
Doesn't work that way Max.
You can use EITHER the OnBoard Graphics,
OR;
the Add-On Card graphics. (Graphics card)
BIOS will NOT support both at the same time.
If you wish to use dual monitors, get an AGP card that has more than one graphics port on it.
For example, although I'm using a graphics card based on the PCI Express technology, and not AGP technology; my card has a VGA port, DVI port, and HDMI port.
1) VGA Connector; http://en.wikipedia.org/wiki/VGA_Connector
http://en.wikipedia.org/wiki/File:Male_VGA_connector.jpg
2) DVI; http://en.wikipedia.org/wiki/Digital_Visual_Interface
http://en.wikipedia.org/wiki/File:Dvi-cable.jpg
http://en.wikipedia.org/wiki/Digital_Visual_Interface#Connector
3) HDMI; http://en.wikipedia.org/wiki/HDMI
I use the VGA port, and the DVI port.
RCA EN-V L26HD31, (26 inch HDTV) to the VGA port.
HP 2009M 20 inch Widescreen monitor to the DVI port.
Had to install drivers for HP 2009M.
Let's say I had two DVI ports on the graphics card.
(ATI Radeon HD5450 is the graphics card I have)
But I have a monitor with a VGA cable, and a monitor with a DVI cable.
I would (And have) use a VGA to DVI Adapter.
One example,
http://www.directron.com/dvi.html
Note that the DVI is Male, and the VGA is Female.
The graphics card DVI connector is Female.
The VGA Cable connector is Male.
So.............what is the manufacturer name, and model number of the graphics card; plus what type of monitors are you trying to use?
That is, what type of monitor cables do they have?
Know this;
My HDTV I'm using as a monitor is Digital. However I'm using a VGA cable on it. Best quality would be achieved if I got off my lazy rear, and attached a DVI Cable to it. It uses both.
VGA is Analog. A computer however puts out a digital video signal.
The computer has to convert the digital video signal to an Analog one. This slows the video signal down, and the quality is not as good.
Best to use a digital monitor. (Or a digital monitor WITH a digital cable. DVI Cable. Such as I need to do)
You are also using a PCI Express graphics card, NOT an AGP graphics card.
I'm wrong? OK.
In the meantime turn the computer off, unplug from power, and yank that AGP card out of the slot you put it in.
Tell me what expansion slot on the motherboard you put it in.
The Orange expansion slot on the motherboard, is a PCI-Express x16 slot. Uses a PCI Express graphics card -> ONLY
The white expansions slots are PCI.
Can use a PCI graphics card. CANNOT use an AGP graphics card.
Post back in a Comment.
Regards,
joecoolvette
http://www.newegg.com/Product/Product.aspx?Item=N82E16814131338
Feb 18, 2013 | DFI 661GX-MLV SIS661GX CHIPSET SOCKET775...
Hdmi port
maybe your xbox is beginning to give out
if its a slim : try disconnecting and connecting back
if its a phat : you will get RROD soon :)
Jan 23, 2013 | Microsoft Xbox 360 Console
Can i connect my xbox 360 using Dvi D to Hdmi in the dvi slot and also my tower to the vga slot on my eMachines E19T6W
I am not an xbox person, but as far as hooking it up, it should work as long as the other device is NOT powered up. That being said you will still have to provide audio from the xbox another way as dvi only carries a video signal, unlike the hdmi which carries both audio and video.
Dec 12, 2011 | eMachines E19T6W 19" Monitor
+I have a dell 4600, it came with a geforce fx5200 graphic card, i need a vga and a hdmi coneection, my monitor is vga and i want to hook up a tv monitor with hdmi
Dear civetscat,
Hello and welcome to FixYa!
I have research these converters/adapters before that can convert from the DVI port on the video card to an HDMI source. They are very exspensive for the type that truely work, and the cheap ones provide terrible graphics. Your best bet, is to research both the adapter and a replacement video card for your PC that will have the HDMI and VGA outputs you seek.
I have provided links to both below, from a site call newegg.com
Adapter/Converter: http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=DVI+to+HDMI+converter
Replacement video card: http://www.newegg.com/Product/Product.aspx?Item=N82E16814161308
Happy hunting and have a great day!
Sep 01, 2011 | Nvidia GeForce FX 5200 Video Card Graphic
I have sapphire ati radeon 5570 graphics card. i have aoc 912sw+ 19 inch lcd monitor. how to connect hdmi port of graphics card with monitor?
the HDMI port is for connecting video and sound to a home theatre / surround sound system. I understand that this monitor only has a VGA connector.
The sapphire ati radeon 5570 graphics card has the following ports on the back to connect to a display: DVI (white), VGA (blue) and DisplayPort (the thin slot in the middle). You can use an ordinary VGA cable to connect the card to your monitor.
Unfortunately you cannot connect this card directly to your monitor using the DisplayPort.
Hope this helps
Tom
Jul 21, 2011 | AOC 912SW-4 Monitor
I have a syncmaster 400p i need a new graphic processor can u reccomend a compatible one
Good day,
If your screen has a VGA, DVI, or HDMI port, most of the new graphics cards will be compatible with your screen. Most graphics cards come standard with DVI ports and include a vga adapter for the screen cable. Some of the new graphics cards come with HDMI and DVI ports or a HDMI converter if you want to use HDMI.
I would recommend a Nvidia graphics card. Depending on what your primary use is going to be they have an extensive range to cater for your requirements and price range.
Hope this helps!
Regards
Nov 28, 2010 | Samsung SyncMaster 400 T 40 in. Flat Panel...
What is the cost of Radeon HD 5450 1GB DDR2 PCIE HDMI and .......
Amazon show a XFX ATI Radeon HD5450 1 GB DDR3 VGA/DVI/HDMI Low Profile PCI-Express Video Card HD545XZCH2
For $34
Amazon com XFX ATI Radeon HD5450 1 GB DDR3 VGA DVI HDMI Low Profile PCI...
eBay shows one USED for $19
XFX ATI Radeon HD 5450 HD 545X ZQH2 HD545XZQH2 778656056176 eBay
GOOD LUCK getting a seller to ship to India! Have a friend in the US buy one and let THEM ship to you!
Anthony
Jan 07, 2018 | ASUS Computers & Internet
Monitor screen shuts off and on while in DVI mode
First, try updating the ATI drivers. The DVI connection transfers information about screen state back and forth (it's a full two-way connection). If there's some bug in how the SyncMaster and ATI card do this communication (which sounds like the problem) then hopefully the newer drivers will fix it. Otherwise try it out on a RGB cable.
Jan 18, 2009 | ATI RADEON 9250, (256 MB) PCI Graphic...
Video Game Consoles & Games Logo
53 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
