Need a manual to assemble the heater - Heating & Cooling
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 83 Answers
Mary there are probably 20,000 heaters in the world there is no way to tell you how to assemble it .
Why is it dis assembled is it new and came that way, was it taken apart to be fixed/repaired, did it fall and come apart
Was it taken apart because it is dangerous
Take the brand and model number and see if you can locate the mfg . By putting the mfg name in a search engine
Posted on Oct 20, 2013
Replacing heater core in 2006 sazuki forenza
Heater Core Removal and Installation
Removal
1. Disconnect the negative battery cable.
2. Remove the instrument panel.
3. Recover the refrigerant.
4. Remove the heater/air distributor case assembly.
5. Remove the wiring harness and electrical connectors from the heater/air distributor case assembly.
6. Remove the screws that connect the heater core housing and the evaporator housing.
7. Separate the sponge from heater/air distributor case assembly.
8. Remove the heater core cover screws from the heater core housing.
9. Remove the heater core.
Installation
1. Install the heater core into the case.
2. Install the screws on the heater core housing.
Tighten: Tighten the heater core cover screws to 1.2 Nm (11 in. lbs.).
Jan 10, 2017 | 2006 Suzuki Forenza
Change bulb in heater controls
you need to remove center dash assembly to unscrew the heater control assembly once you pull out the heater control assembly you should have access to the rear where the tiny bulb is and you will need the number marked on it or in your owners manual in specs lights some auto parts dont have the same size since there are many models and sizes you might have to buy from dealer and they have to order so look around to find one
Aug 05, 2014 | 2004 Peugeot 206 SW
Need a manual for my Dyna Glo kerosene heater RMC-95-C2. This heater has never been used. The wire guards are attached but the heater is not assembled.
SERVICEMANUALS @ COST www.mauritron.com Manuals at free download: homeappliance.manualsonline.com/manuals/.../lg_air_conditioner_product_list.html Helpful?
Dec 24, 2010 | Heating & Cooling
I am wanting to change the heater core in my 2004 Suziki Forenza myself. I am looking for a maintenance manual for this model vehicle or someone with the knowledge of how the dash comes off.
you can go to any auto parts store and buy a haynes manual for your specific vehicle. they are based on a complete teardown of vehicle. the manuals are only about 20 to 25 dollars. have a good day !! ( then you will have it just in case something else goes wrong !!)
Dec 19, 2010 | Suzuki Forenza Cars & Trucks
Need to replace heater core
Very very big job. Only do this if you really really love your car. Here is the 100ft overview:
*Disconnect the heater hoses at the heater core inside the engine compartment. (recommend cutting the hoses and replacing with new ones)
*Disconnect the heater valve cable from the heater valve
*Remove dashboard (involves removing steering wheel/column, radio, glove comp, etc)
*Remove the heater assembly (big black plastic box behind the radio)
The core is inside the heater assembly.
Again, this is a big job, and it will probably be very frustrating at times (I know from experience). If you do not have a repair manual for the car and you think you want to try this...get the manual first!
Dec 06, 2010 | 1992 Honda Accord
CE error code on hayward pool heater
CE= Communication Error between Control Module
and Display Interface Assembly
1. Disconnect and then reconnect power to heater.
2. Check for faulty wiring or connection.
Inspect Display Interface Wiring. Ensure Display Interface Plug is securely attached to Control Module. .
3. Control Module and/or Display Interface Assembly
are defective.Replace Control Module and/or Display Interface Assembly.
Here is a linkt oH aywardmanuals:
http://www.haywardnet.com/inground/products/manuals.cfm
Jul 04, 2010 | Hayward 250kbtu Ng Pool Heater - Inground
Need owners/instruction manual for Desa blower model # PP100
link to manual: http://www.desatech.com/manuals/Vent-Free%20Heaters/HDR16PT.pdf
Oct 26, 2009 | Desa International Blower Glow Warm Wall...
LG Dishwasher LD-2050WH with HE error code
This is a heater error. The cause is either a bad heating element or bad thermistor (the thermistor is part of the heater assembly). The heater assembly will need to be replaced.
Jan 14, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Need Owners Manual/Assembly Instructions for WindChaser PHS Patio Heater
I have the exact same problem. No owners or assembly manual. Can get no response from company?
Nov 04, 2008 | Windchaser Stainless Steel Patio Heater...
Heating & Cooling Logo
48 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
