Question about New World Ovens
Broken spring door - New World Ovens
The oven door seems to have come unattached from the spring. How do I reattach if it actually comes undone? The door does not seem to spring up and seal tightly.
I have had this same thing happen a few times.
Usually it is a broken spring.
Sometimes it was a broken "place where the spring hooks to".
Someone will have to take this all apart to diagnose and fix it.
This is a really big job.
Depending on the age of the oven, you may be able to get parts and even a schematic if you type your model number in to "SearsPartsDirect" website.
God bless your efforts.
Dec 08, 2017 | Ovens
We've got a broken door spring on our Maytag CWE5800ACE Oven. We pulled off the top door and disassembled it when we realized the springs are inside the oven unit. OK....Can anybody can offer some...
My father-in-Law has the same issue and I found the spring as part of the hinge assembly. The link is "http://www.appliancepartspros.com/part_details.aspx?part_id=4092260&image=1" and the part number is Part Number: AP4092260
Made by WHIRLPOOL. Hope this helps!
Dec 01, 2010 | Maytag CWE4800A Electric Single Oven
Microwave door will not latch closed
I just had this problem with a Samsung microwave/hood combo. I pried/popped the inside molding out with a screwdriver. The little lip that the spring attached to had broken. I drilled a hole in the center of the door latch, reattached the spring, replaced in door, replaced inside decorative molding, and fixed in 5 minutes. Thank goodness because it's such a pain to replace these units.
Jun 30, 2010 | Neff B4540 Stainless Steel Electric Single...
Oven door not closing properly
If it is a drop down door with hinges on the bootom of the oven door, then it is likely to be weak door hinge springs, the usual solution is to replace both hinges.
If it is a swing open door, then the problem is related to a worn or broken door catch, or worn striker pin.
Apr 13, 2010 | Ovens
Door doesn't close tightly and sometimes the light stays on. Can I tighten the springs?
One of both of the springs are probably off or broken. Slide it out and inspect the hinges and springs which are at the bottom of the door. The springs hook to the hinge and the base of the oven farther back. You may have to remove the side cover.
Nov 27, 2009 | Jenn-Air Ovens
Moffatt double oven 4175 lower oven door springs broken
My problem was not with an Amana single oven but aMoffatt double oven ! However I have now decided to buy new.
Oct 31, 2009 | Amana AEW3530DD Electric Single Oven
I have an 1950s' O'Keefe & Merritt Gas Stove that has oven doors that will not completely close. Can you help or locate a manual? Thanks
if the springs are not broken , the hinges are bent down ( droping the door for 60 yrs). Its tricky to bend back the hinges back. Springs and parts are no longer avaliable but you may be able to match someting close for a spring if you have the old one.
Oct 30, 2009 | Ovens
Kleenmaid Stainless Steel oven door will not close properly.
The door hinge is probaly broken or could just be the spring. Open the door to the 45 degree position (halfway) and pull on the door. It should come off the hinge assembly. Slide out the oven a little to access the screws for the hinge to see what is broken or wore out.
Aug 10, 2009 | Ovens
Have an older Vulcan oven with double doors. The spring clip that holds the door shut has broken off. The spring loaded ball is okay just need the plate that fits on the door. This unit is probably 20 yhs...
found parts for vulcan ovens at a appliance store called Y.E.S. ( year end supply) out of New Mexico if I remember correctly. It has been about 12 years since I have had the pleasure of working on an older vulcan oven. Hope this helps. Good Luck
Dave
Jul 17, 2009 | Ovens
How do get access to the door hinge of my Maytag CWE4800ACB oven
In first, excuse my poor english if i make some mistake.
I hare repair the same problem. part broken in left side and the door fall.
You have to pull out the oven from the wall, use some objet to support the oven,small table or plastic box if you dont want to put down completely.
You have to unsecure the electric wire connection in back if you whant to pull out enough for remove the left cover. You have to remove some parts in front for acces to screws on the side cabinet.
In my case the hinge was broken, i have soldered and fix again.
If hard to replace the spring in the mecanism, you better to do this on the bench before put all in the side of the oven.
I think the maytag oven have the same problem.
Other problem also is the timer alarm sound in the night went you sleeping, prob whit switch sensitif pc board. Now i turn off the breaker in the back of oven all night, and i sleep good.
Bye..
Mar 24, 2009 | Maytag CWE4800A Electric Single Oven
Ovens Logo
11 people viewed this question
Top New World Ovens Experts
Paul Carew
ashburton
Are you a New World Oven Expert? Answer questions, earn points and help others
