Question about Electronics - Others
Istar x 20000
My reciever hang up
Engine cuts out occasionally. At low speed, medium speed, high speed. Some time it burps 2 or 3 times then won't do it the rest of the day. Another day it will miss every 5 minutes or so.
May be a bad ignition switch. Do not hang a bunch of trinkets and keys from your key ring. 2 keys at most. Perform an OBDII scan before doing any repairs. Let your scan print out be your guide to any parts replacement.
May 18, 2017 | GMC Cars & Trucks
Tip
Revert back to original settings done by the registry
paste following code in Notepad ans then save it with name “regdefault.reg” (including quotes). Then run the file and your settings will be reverted back to original:
Windows Registry Editor Version 5.00
[-HKEY_CLASSES_ROOT\AllFilesystemObjects\shellex\ContextMenuHandlers\Copy To]
[-HKEY_CLASSES_ROOT\AllFilesystemObjects\shellex\ContextMenuHandlers\Move To]
[-HKEY_CLASSES_ROOT\Directory\Shell\DosHere]
[-HKEY_CLASSES_ROOT\Drive\Shell\DosHere]
[HKEY_CURRENT_USER\Software\Microsoft\Notepad]
“StatusBar”=dword:00000000
“fWrap”=dword:00000000
[HKEY_CURRENT_USER\Control Panel\Desktop]
“AutoEndTasks”=”0′
“HungAppTimeout”=”20000′
“MenuShowDelay”=”400′
“WaitToKillAppTimeout”=”20000′
“LowLevelHooksTimeout”=”20000′
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer]
“NoLowDiskSpaceChecks”=dword:00000000
“ClearRecentDocsOnExit”=dword:00000000
“NoRecentDocsHistory”=hex:00,00,00,00
“LinkResolveIgnoreLinkInfo”=dword:00000000
“NoResolveSearch”=dword:00000000
“NoResolveTrack”=dword:00000000
“NoInternetOpenWith”=dword:00000000
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control]
“WaitToKillServiceTimeout”=”20000"
on Jun 03, 2008 | Compaq Presario 700 470024-192 Notebook
How many gallons of water is in 20000 liters water tank?
20000 liters is about 5283 US gallons or about 4399 imperial gallons.
Jul 03, 2014 | Computers & Internet
Istar korea x1500
I have the istar korea x1000 & x1500 and the ip tv channal is gone from list snd also need a user code iptv.how can i fix this problem.
Dec 28, 2013 | Electronics - Others
Removal iStar.exe application
Sounds like you encrypted the drive. Under Computer, right click the drive and format it. You will lose all your data and there is no way around this. Write your password down somewhere if you can't remember it.
Dec 21, 2012 | Electronics - Others
How to connect a maglock to a fire relay? I have to insure that maglock controlled doors release when the fire alarm is activated. I have a Ccure Istar panel and I think a apc pwr supply
On most fire alarm panels there are normally open and normally closed relays that will change state in the event of a fire. The negative power line can be ran through these relays to allow the maglock to be powered down in the event of a fire. The relay on the fire panel may need to be programmed to do this or it may come programmed by default which is usually the case. Hope this helps.
Sep 25, 2009 | I-Star PSU ISTAR|TC-550PA RETAIL (TC550PA)...
I can recieve text messages, but i am unable to send text message
go to settings ---> call barring ---> then click on Data calls ----> cancel .
this should enable sms send and recieve.
Jan 03, 2009 | Motorola Mobility RAZR V3
Panasonic kx-tc1282jxb no hang up
Some phones answer when picked up off the charger, but with some you must press the talk button to answer. Some have a green reciever on the button. And to hang up you must press the off button or the button with the red reciever.
Feb 02, 2008 | Panasonic KX-TG6021 Cordless Phone
Electronics - Others Logo
93 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
