Question about Electronics - Others
I have a LG HT353SD-AD home theater.but now not coming video to tv.please give me a solution.
Boggsj
  • 20 Answers
SOURCE: Can i send video from Nintendo Wii through my home theater to my projector?
A few things to consider; what type of connection is your Wii using? Composite, component, s-video, coax? Most home theater setups are made to route multiple video signals, usually of the Composite (RCA Red Yellow White) variety, and should be clearly labeled Video In. If it doesn't have extra inputs, you might want to consider buying a media switchbox- http://www.cyberguys.com/templates/searchdetail.asp?sk=MC71730&productID=7663 A switch like the one linked above allows you to hook multiple audio and video sources into it and easily switch between them by pressing a button on the front.
Posted on May 23, 2007
  • 3 Answers
SOURCE: home theater system connections
Hi
I have the same tv but my dvd surround is a toshiba, that shouldn't matter though. When I watch a dvd I go to component 2 which is where I have my dvd connected on the input of the tv when I watch tv and want the surround on I go to component 1 which is the tv input then on my dvd player I go to auxillary and I can watch tv in surround. I don't know the LG home theatre system but you should be able to select your inputs like between dvd, tuner, aux. Flip between them and you should get sound. hope this helps.
Posted on Jan 19, 2008
SOURCE: LG Home Theater System LHT754 no sound
All you are currently doing is getting sound OUT from the LG HT system. If you want sound from your cable or satellite, you have to run a seperate audio cable into the back of the LG system. If you are running a cable line straight into the TV you need to run an audio cable OUT of the TV so you get sound via the LG system.
Posted on Jun 19, 2008
VOTIT
  • 2071 Answers
SOURCE: Progressive scan on LG Home theater LH-T550SB
Just click below;
hope this may help;
Regards,
VOTIT
Posted on Aug 21, 2008
SOURCE: Apple TV and Bose Home Theater
I had the same problem.
I could not get HDMI to HDMI to work.
i fixed it (work around), by connecting ATV HDMI to DVD HDMI port on V30, i then connect L&R to AUX.  I set the Bose remote for controlling ATV to AUX.
so to use ATV with Bose remote i know press DVD, this gives me the correct display but not audio, i then press AUX and this gives me ATV control and audio.
interesting, when i first set this up (trial and error), it didn't work.  I was doing some cable management clean up, when i got a fright and the thing started working...but i have a ghost in my house so that is probably a more plausible reason why its working now.
it feels like this product is only 90% finished
Posted on May 26, 2009
Philips hts 3265
hi,lg lh d6230a home theater player display show the dvd error but not opening cd room .why this wrong please help me.send me reply
Jan 15, 2014 | Audio Players & Recorders
I don't know how to hook up my LG lht854 to my time warner cable box so that it plays the tv audio. please help
Treat the Cable Box like any other audio device.
IF the cable Box has optical digital output, run it to the LG. Run the analog audio output of the Cable Box to the TV so you can watch lo-fi shows without the LG turned on.
The best Cable Box Video should go directly to the TV.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/LG-LHT854-Home-Theater-Systems-manual/id/19697ci566/t/2/
Mar 19, 2011 | LG LHT854 Theater System
I need tuner user manual to programme radio stations
Heres The manual from the LG Site: English
From: http://www.lg.com/us/tv-audio-video/home-theater-systems/LG-home-theater-system-LHT854.jsp
Jun 19, 2010 | LG LHT854 Theater System
I have an LG home theatre HT353SD, the problem is that the disc tray says LOCKED and won't open, although everything else work perfectly, tried the menu, the remote but nothing to solve this, I think it...
hello,
you do not need a code, all you need is open the cover of the system and check for the rubber attached to the motor of the mechanism if it is slack or cut .
but if it does not have a rubber , the problem is from the mechanism.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The following website sells the drives mechanism and does installs:
store.richsxparts.com
hope this will help....
May 26, 2010 | Philips MCD288/37 DVD Micro Theater System...
I have and lg tv and a samsung home theater
optical audio cable from home theater to tv. can be purchased on line for a few bucks.
Dec 21, 2009 | LG LHT854 Theater System
I can only get 2.1 sound from my Playstation3
optical cable connection in tv is only input and same in receiver it is both inputs.you need to find the right encoding in your receiver mode/set-up
Apr 21, 2009 | Sony DAV-HDX500 System
No sound though home theater when watching tv
There is an orange button on the remote, half way down in the middle. I belive it has orange lettering and says something like "TV-?" press that, and the sound should start to come through your speaker system. You can then use the original remote that came with your TV and turn the sound off on the TV to use just the theatre system. I noticed that if you use the TV speakers in conjunction with the theatre system, that it echo's.
Nov 23, 2008 | LG LHT854 Theater System
LG HT353SD?
open tray
0 0 0
then appears a screen asking for region, put 0 for free region, then press pause.
done
Aug 23, 2008 | Philips MCD288/37 DVD Micro Theater System...
Electronics - Others Logo
27 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
