Question about Samsung DualView TL205 Digital Camera
My TL205 screen gets completely dark when i want to take pictures but i can see other things on it. I need help !
    Master:
  • 118 Answers
Reset camera Settings by the below procedure.
-Press the MENU button
-Use the left or right arrow keys to select the Settings menu (its icon looks like a wrench and hammer)
-Use the up or down arrow keys to scroll to the choice that says "Reset ALL..."
-Press the "Func./Set" button to confirm your choice.
Posted on Jan 27, 2014
I have a samsung TL205 and it wont come on.
This is Battery Issue, Charge the battery fully.
Also Wipe the contacts on the Battery and inside the Camera battery slot
It should work fine
Regards,
Suhail
May 20, 2012 | Samsung DualView TL205 Digital Camera
Can I get a print-out manual for the Samsung TL205/PL100 Digital Camera
You may download the manual here. You can print it out yourself, or most office-supply stores can print and bind it for you.
Jan 24, 2012 | Samsung Cameras
When turned on green light flashes and no picture
Check the Lamp if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 2X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Check the ballast if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 3X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Dec 24, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Getting dark picture.. is there such a thing as
yes it is noy pixal oil it is CRT coolant there are several companies on-line that sell complete collant replacement tvrepairkits not to hard to do with the directions given and a lot of times the sets look as good as it did when it was mnew!!!!!! Good Luck
Larry Dillon
Aug 27, 2009 | Televison & Video
Picture is dark
sitnlisten - yes it does appear your pix tube is getting weak,but we may be able to turn up the flyback alittle to brighten up the picture.If you take the back off you will see the flyback-large black unit with a wire going to the round rubber cap on the back of the pix tube.Look at the flyback there are usually 2 adjusters one marked focus the other screen,just turn up the screen a little bit at a time.If you turn this up too much you will wind up with retrace lines on the screen.You may also want to check the pcboard ass'y for a sub bright adjust,and same thing small adjustments.If this don't help your pix tube may be too far gone.I hope this helps. cooltek Feb.1/08
Feb 14, 2008 | Zenith C27A24T 27" TV
Dark picture
I think you have a regulation problem and all the voltage supplies are lower than what they should be,the fact that the picture gets distorted is one thing it lead me to believe that is the problem.This can be caused by a loose conection in the power supply ,I would suggest not to use it until it gets repaired or it might become worst and more expensive.Be careful if you remove the back and try to repair it yourself.
Oct 02, 2006 | Panasonic PT-61G54 61" Rear Projection...
Dark LCD
Is it possible that you've gone into M (manual) mode and the shutter speed is fast and a small aperture (large number) been selected? Or has the Exposure compensation been adjusted to be -2? Does it do the same thing in fully automatic mode? It certainly sounds like some setting has been adjusted incorrectly.
Aug 31, 2005 | Canon PowerShot A70 Digital Camera
Samsung DualView TL205 Digital Camera Logo
54 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
