I have a Kenmore dishwasher (model 655) that is not draining the water (during any part of a wash cycle).
I cannot find anything that appears to be blocked (took off the bottom spinning wash blade) and the water inlet switch appears to properly float to let water in. What do I do now?
-   Will not drain the water but wash. Is there a reset button for the pump?
-   teddy500
Dec 22, 2008
-   my dishwasher flashed 2 and stays full of water and it turns on and shuts off by it's self. We had the computer and touch panel replaced and it still does the same thing. -   csmacinnis
Dec 06, 2008
-   My dishwasher does not drain completely after completing all cycles.-   jlh5608
Nov 21, 2008
-   DISHWASHER NOT DRAINING-   Guest
Nov 02, 2008
-   It seems that the dishwasher filled with water the very first time after install, but does not empty and keeps using the same water for subsequent loads. How do I adjust the float if that is the problem? Thanks-   lthomp
when i attend dishwashers that have lost power to some part, i always check for broken wires inside the door skin, the wire harness inside the door skin gets hot and cracks with use when opening the door all the time
after that check the outlet pump which is often a separate part to the main motor, this pump could be faulty electrically
Gu1200lxtls3- film on dishes, feel gritty. Using cascade liquid.have ran vinegar through with no...
(More)
Gu1200lxtls3- film on dishes, feel gritty. Using cascade liquid.have ran vinegar through with no result and rinse aid is full.
The washing light continuously blinks. This problem started after the water would not drain . Finally got the water to drain after setting the water level sesor in the up position. But, the washing light continues to blink.
