I have a mf4350d canon printer/fax/copy, noting works on it, the display is on but does not show anything, also my pc is not able to recognize it, even the copy does not work?
    New Friend:
Just sell it
Posted on Oct 19, 2013
tom19511
  • 1601 Answers
SOURCE: SCAN,COPY,FAX PROBLEM
Issue An 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved. If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.     Here is a manual if you dont already have one.   http://h10032.www1.hp.com/ctg/Manual/c00486336.pdf
Posted on Nov 01, 2007
SOURCE: Error code 6A00, alarm light flashing, no copy, print or fax function working
I tried everything. I unplugged the machine and moved the printer cartridges to the far left and cleaned and pressed down the spring loaded sponge on the right, over and over again. I also moved the springloaded thing (w/white plastic) forward and backward. Another suggestion was to move the print cartridge holder back and forth sideways. None of these things helped. And there was nothing visibly out of place. I was stumped. Then I found a thread that suggested Windex!!! Even though the error seemed to correlate with a paper jam that had occurred, I was ready to try anything. I got paper towels and windex (I didn't have an eye dropper). I sprayed the paper and cleaned where the cartridges normally sit. Nothing. In desperation I sprayed each pad below the cartridge in the middle area and I sprayed the "sponge" thingy to the right. Really soaked it. Cycled the on/off about 3 times and IT WORKS! (Fingers are black but that's a minor issue compared to unhooking and transporting and waiting and paying for service...) When you cycle the Windex through it soaks up the sticky dried up ink and cleans things up. Don't use other cleaners--use Windex or water.
Bonni
Posted on Feb 26, 2009
old marine
  • 2153 Answers
SOURCE: I use a Canon ImageCLASS MF4350d Laser All-in-One
I think that error code means a problem with the scanner/lamp. Any type of Exxx code means the machine needs (repair) service. This is a fairly new product and should still be in warranty, so I recommend you contact your regional Canon service agency.
Posted on Nov 11, 2009
leethedeuce
  • 4472 Answers
SOURCE: Canon Pixma ip5200 under Windows 7 - not responding
Did you download the latest drivers from the website? It looks like they were posted this month. I would report the issue. It is quite likely there is a compatibility issue. Have you contacted canon at all about this problem? Once I have more information I can try and assist you further.
Thank you,
Lee
Also check out my tip on how to save money using less ink:
http://www.fixya.com/support/r3954871-save_money_using_less_ink_when_printing
Posted on Jan 27, 2010
SOURCE: Have Canon MF3200 (priner, fax, scanner) PC will
go to Control Panel\All Control Panel Items\Devices and Printers and right click and look at menu. click on start scan.
Posted on May 13, 2010
Memory full when faxing
Sir, there is an error i.e system error e225 in display my canon mf 4350d machine please help me shut out this
Oct 15, 2013 | Canon ImageCLASS MF4350d Laser All-in-One ...
My Canon MF4350d does not send faxes. All of the cords are connected properly. My phone that is connectedto my fax machine works fine, but I get no dial tone for my fax.
Does it dial the fax, but not send it? check which place you have the phone and line plugged into the fax machine. There are two plugs on the machine. One says line or wall, the other phone or handset. make sure the wall is plugged into the right one. that is the first thing to check, if not, reply and we can walk through setup.
Peace,
Mar 05, 2010 | Canon ImageCLASS MF4350d Laser All-in-One ...
I use a Canon ImageCLASS MF4350d Laser All-in-One (2711B001AA) Printer. When i want to photo copy, it shows system error -E225. What does that mean?
Nov 11, 2009 | Canon ImageCLASS MF4350d Laser All-in-One ...
k24674
jasbo
jasbo
