Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Can't get the vent to come on - Jenn-Air SVE47100 Slide-In Electric Kitchen Range
    Top Expert:
  • Jenn-Air Master
  • 9,472 Answers
You will need to replace the blower motor. Here is that part to order.
Posted on Oct 26, 2013
Does a Maytag gas stove model # CRG9700BAL have to be vented. Im replaceing a stove that quit working with this one and it has no vent, but my old one did.
Old gas stoves were designed to be vented out. the newer stoves vent out the top at the back of the top panel. You may still need to have some kind of vent in the kitchen either a ceiling vent van or a range hood. At the very least a window in the kitchen. You may want to check with the local building codes about how to vent the stove and the requirements.
Oct 01, 2014 | Maytag Kitchen Ranges
Thermador CVS36R Cook'n'vent vent won't go down and fan stopped workin
You probably will find that the vent is clogged with grease. A switch device works with the vent so the fan operates only when the vent is open and does not operate when the vent is closed. Things should get back to normal after a thorough cleaning unless the fan is defective and won't operate at all.
Sep 03, 2012 | Thermador CVS236 36" Cook 'n' Vent System...
Clicking noise when in the vent when I put the vent on the feet area and past that towards windshield vent. There is no noise when the vent is toward you and you/floor vent.
The Vent Mode Actuator and its gear that operates the directional door is making the noise. Either the gear is stripped or the door is stuck or the actuator is defective. These parts are hard to get to and will require a mechanic to diagnose.
Jun 27, 2012 | 2004 GMC Envoy
AC will not blow out of the dash vents, only the defroster vents or heater vents. Can I access the vent door underneath the dash?vents
Under neath the venting system behind console there is a venting housing that can be removed. Likely the air flow directional vent flap is stuck or the motor that moves the vent is faulty.
Jun 06, 2012 | 1991 Chevrolet Silverado 2500
The proper name of the AC Vents
Try Duct Vents, Ductwork Vents, or Dash Vents. Then Dash Outlet Vent, A/C Outlet Vent, Dash Panel Vent.
You may be able to find something in a Salvage Yard. The other problem you may be having is the Dash Panels are 1 component so there may be no separate sales for just parts on the panel. Say Lear makes the Dash panels for Ford; they come to the Assembly plant already assembled.
You may need to take off the Dash panel anyway to be able to pry out the old vents if you can get replacements. You would help yourself alot by going to a Salvage yard and seeing how stuff comes apart so you don't break your parts.
Now that you know the name of the parts, try a Dealer and ask if they can get new vents or not.
Jun 27, 2010 | 2001 Ford Mustang
MY DRYER GETS HOT ON TOP OF THE DRYER (KENMORE) COULD IT BE THE VENT?
start dryer, go outside and see if vent is blowing hot air. If not then vent is clogged with lint, esp if vent has a curve or elbow in it. unhook vent at dryer or os vent and run a vacumn hose in as far as you can. easy way to determine if vent is to unhook at dryer and see if dryer blows air, could be just inside at vent opening
Jul 11, 2009 | Kenmore Dryers
Can I Use Existing Venting from Old Water Heater?
The only thing is I think the vent pipe foe the tankless is smaller than 5".I think the one I install was a three inch.
Mar 17, 2009 | Rheem RTG74DVN Direct Vent Natural Gas...
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
47 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
