Question about Whirlpool Washing Machines
HOW DO I REPLACE THE DRAIN HOSE ON LG WM3360H*CA?
    Sergeant:
    Champion:
  • 257 Answers
You need go to the back of the washer, open the cover then you will see the drain hose underneath of the drum. It is hard to replace it if you do it first time. Be aware of cutting yourself, protect your hand with gloves.
Posted on Oct 22, 2013
3 Suggested Answers
  • 353 Answers
SOURCE: LG front load washing machine - need to replace drain hose
It's jusy one clip go in from the bottom
Posted on Mar 20, 2010
pjhislay1
  • 822 Answers
SOURCE: Model - LG F1480FD. Need
underneath......
drag maching to outside door and let old hose hang outside
this will drain alot of water out of machine then upend it to replace old hose with new 1
cheers
Posted on Mar 27, 2011
How to fix drain hose on LG WM2487H M
The following are a number of things to check for the OE (drain error) indication.
If the washer does not drain then the drain pump may be clogged, damaged, or defective.
Sometimes, socks and other small articles of clothing can get into the drain system and clog the pump hose or the pump itself. Open the drain pump filter tray at the lower left of the machine and check whether it is clean, check also that the pump impeller spins freely. Remove the hoses from the pump and check for any obstructions.
First, check the drain hose to determine if it is kinked, twisted, or bent. If the drain hose is bent, straighten it out. In addition, remove the drain hose and check it for obstructions. If the drain hose has any obstructions, try to remove them. If necessary, replace the drain hose.
Check the machine's water level frequency by pressing the WASH/RINSE + DELAY WASH buttons simultaneously. Check the reading on the display, if it is below 260 (26 Khz) then have someone measure the resistance of the pump motor coil.
It should be between 10-20 Ohms resistance, if too high or too low, replace the pump assembly as it cannot be repaired.
Mar 08, 2016 | LG Washing Machines
Lg d/washer about 8yrs old Oe code. Checked grey wire thiery. Cleaned hose filter etc. Was working fine moved house.Whats next.
A drainage problem causes "OE" to be displayed on the digital display panel. The drain hose is likely kinked, clogged or frozen. Inspect the hose and remove kinks. Unclog the hose, if needed. Replace the hose if the problem is not resolved. If the dishwasher still does not drain,
Feb 23, 2015 | LG Washing Machines
Model - LG F1480FD. Need to replace drain hose. Please advise best way to get in to replace drain hose (? from bottom side etc.)
underneath......
cheers
Mar 27, 2011 | LG WM-1480FHD Front Load Washer
How do I install a new drain hose in my LG dishwasher the original cracked and flooded my floor
You will have to completely uninstall the dishwasher to replace the drain hose assembly.
Part# AEM69493803.
Once the unit is out of the cabinet drain hose replacement is fairly easy.
Jan 14, 2010 | LG Dishwashers
Dishwasher sounds like it is straining LG LD-2040WH
E1 leakage error
The excessive RPM of Washing Motor happened during Wash cycle due to water leakage.
Water leakage in Hose connections. Water is leaked by damages. The Motor Water Seal leakage of Sump assembly. The height of Drain Hose connection (sink-Drain Hose) is not over 20 . Impeller of the Washing Pump is worn away.
Replace the connections of Hose. Check the point of damages and repair or replace the related parts.
Replace the Impeller of the Washing Pump.
Aug 30, 2009 | LG Dishwashers
For LG WM2233HW, Error Code OE. Already check drain hose and filter, all clean. Try different cycles, TUB CLEAN, SPEED WASH. Same error code. No drain.
Replace the water pump. Because the water can not pump out, the machine idles for a while then stops with the error code OE. The technician said, the drain hose should be hang high before curse down to the drainage so air can not go to the hose.
Jun 19, 2009 | LG WM-2277HW Front Load Washer
LG dishwasher drain hose
You will have to remove the dishwasher from the cabinet, lay it on it's side, and remove the bottom access cover to get to the end of the hose. (it's usually not as bad as it sounds)
Mar 18, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
LG washer/dryer combo will not drain water
easy first unplug unit..take back remove phillips head screws...now the pump drain hose is the other side of the filter in front just take a pliers remove clamp,,replace hose..close unit plug back in
Aug 18, 2008 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
LG Dishwasher - drain hose replacement
Hello, I have just installed a similar model, and took the side panel off to see how it was put together ;)
The drain hose goes in the back of the dishwasher, then loops up the right side (as you are looking at the front)(this is to act as a "trap" to keep sewer gases from coming back into your washer, I assume), and then connects to the drain pump under the washer.
In order the change the hose, you will need to remove the left side panel, and the bottom panel, and this will give you access to the entire hose....
Hope this helps!
Nov 26, 2007 | LG LDF8812 Stainless Steel Built-in...
Washing Machines Logo
48 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
