Question about Toro 110-6892 Timecutter Z5000, Z5020, Z5040, Z5060
Toro z5000 bogs to almost stalling out with minimal load
    Novelist:
  • 212 Answers
I would purchase a compression tester from auto parts store and check compression.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Posted on Oct 22, 2013
I have a toro Timecutter z5000. when I pull the handle to turn right it does not respond. what could be causing the problem,
linkage could be off, brake could be stuck on, belt could be off, hydro pump could be bad. take a pick.
Nov 22, 2016 | Toro Garden
Toro clutch removal
PTO clutch removal.
remove the crankshaft bolt and be prepared for the clutch to fall
if it doesn't get a soft faced mallet and tap on it
no, get some pb blaster and let is soak for a day or two
then tap a little harder
if still no you will need an air hammer
Aug 14, 2014 | Toro 110-6892 Timecutter Z5000, Z5020,...
Toro troubleshooting
I have a toro timecutter z5000, after disengaging the drive in order to hand push the mower it doesn't go back into drive mode. what can the problem be?
Jan 02, 2014 | Garden
Toro z5000 fuel pump not working
replace it ...how to check if it is working pull the gas line going to the carb and turn the engine over if it shoots fuel out its ok
Sep 18, 2013 | Toro 60'' Com Zero Turn Lawn Mower 27hp...
Toro Z5000 won't move
did the belt break or fall off? are the trans release levers pulled out ?the ones you release to push it around
Apr 14, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
TORO Z5000 zero turn mower. right side
it should hold hydralic fluid there should be a resirvour somewhere on the back along with the pump you should be able to check the level there and if you don't get the leak stopped it will lock up the whole drive system.
Aug 23, 2009 | Garden
I have a toro commercial self propelled, engine stops when I engage the self propelled. I t runs until then. What can I do to solve this problem?
Regularly check the wheel-drive belt on a self-propelled mower for wear and tightness .... "Affected engines may run rough, stall or bog down under load,"
Jul 22, 2009 | Toro Lawn Mower With Toro Power Tools
Toro 110-6892 Timecutter Z5000, Z5020, Z5040, Z5060 Logo
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
