Question about Water Heaters
Rheem Water Heater Manual 71-408b - Water Heaters
  • 14 Answers
SOURCE: Rheem water heater, will start but flame lasts 10 seconds
Is the vent fan working well and can you feel unobstructed air out the termination fitting outside?
Posted on Apr 05, 2009
  • 252 Answers
SOURCE: cant locate anode rod on rheem gaas water heater
It looks like a plug screwed into the top of the water heater (it IS plugging the hole so turn off water and release pressure b4 removing)
Posted on Oct 01, 2009
  • 244 Answers
SOURCE: Rheem water heater turns off by its self
Flashing code 76 is lost communication between the remote and the burner control assembly CCA (circuit card assembly). The CCA is still under warranty if purchased within the last 3 yrs. Contact Rheem customer service and have your Mod. and S/N available....explain to the agent you are recieving - flashing code 76...they'll walk you through the process.
Posted on Nov 01, 2009
  • 68 Answers
SOURCE: rheem gas tankless water heater with error code c4 13
problem is inside burner compartment o2 sensor dirty or block..need to have a qualify technician clean it.
Posted on Jul 31, 2010
SOURCE: RHEEM 40 GAL ELEC TALL Water Heater 6YR SC 82VH402: my rheem 81sv40d water heater quit heating water. ...
I have the same problem about every 3-4 months. Mine is also about 10 or 11. It is usually the sediment at the bottom that causes this. Once the plumber flushes it, it works again. My problem is that I dont know how he did it and the vavle is at the floor level. I am never home when it is repaired. Regular maintenance (flushing) is how you avoid this from reoccurring. That is, if that is the cause of your issue.
Posted on Feb 04, 2011
How can I find the manual to a rheem 21vp50-1 gas water heater? It does not seem available.
For troubleshoot and installation:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Rheem manuals are generic, and contain no service information, or other useful information that would be unavailable from downloading current gas water heater manual.
One site posts talks about 21vp50 but posts generic American water heater manual instead of Rheem
http://homeappliance.manualsonline.com/mdownloads/f918341a-6e8e-41b4-85be-5cde688317b9.pdf
Go to Rheem website, click on power vent, then click tab for Specs/Docs ... and click link for manual and then call Rheem and ask why they do not post service bulletins that match the required maintenance shown in product manual:
http://www.rheem.com/products/tank_water_heaters/gas_water_heaters/
Mar 20, 2013 | Water Heaters
Bought a rheem rete 13 off ebay
Question posted under Rheem tankless water heater:
Call Rheem at 800 432 8373
They will need serial number located on label on side of unit.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Usually I recommend that people tear out their tankless water heater and sell it on ebay, and then install tank-type heater from different manufacturer:
I would be very reluctant to connect used gas appliance without a product manual, and service manual.
http://waterheatertimer.org/images/Exploded-house3.jpg
Mar 19, 2013 | Rheem Tankless Hot Water Heater...
Richmond tankless water heater will not clear error code
Why is it always Rheem problems?
Every water heater problem at fixya is Rheem.
And Rheem doesn't post any service manuals, like the other two big manufacturers, AO Smith-American, and Bradford White.
Rheem 2012 manual says if error 13 still displays, then contact installer or service technician. Mo Money buddy.
This is about oxygen sensor, poor combustion, bad venting, inadequate air supply, failed sensors, etc.
Get more fresh air to unit and see if that solves problem. The call service technician, and get out wallet.
Copy following link for Rheem-richmond tankless troubleshoot.
Maintain water heater according to instructions in manual to avoid common error codes. Of course this means you have to service the unit each month, and each year, without guarantee the thing will work correctly.
Sep 06, 2012 | Rheem Tankless Hot Water Heater...
My Richmond tankless water heater is flashing the error code 76 and C8
Richmond is Rheem.
Following links are meant to assist resourceful do-it-yourselfer solve long term maintenance issues that tankless pose.
Error 76 is communication fault with remote control.
Check following links for Paloma 'Rheem" error codes:
http://www.palomastore.com/paloma_error_codes.html
http://www.palomatankless.com/owners/homeowner+trouble.lasso
Best place to start is your manual. Following link show typical Rheem manual with the words troubleshoot and maintenance throughout manual.
Read manual several times before buying product to see yearly maintenance requirement and complexity of tankless water heaters.
http://waterheatertimer.org/pdf/Rheem-RTG74IndoorOutdoor_owners.pdf
Rheem offers on-line chat, which you rarely see for typical tank-type water heater
http://www.rheem.com/products/tankless_water_heaters/customer_support/
Contact Rheem: they will usually kick you back to local service technician.
http://www.rheem.com/Contact.aspx
Check following link for recall list:
http://www.tankless-recall.com/tanklessSearch.aspx
Rheem website is not easiest to navigate, but manuals appear for current models.
Read other Rheem questions at fixya to gain wider experience with potential problems and solutions.
http://www.fixya.com/tags/rtg_74pvn
Install DIY tank-type gas water heater and avoid the whole headache
Post question on pro water heater forum: This is where I go to catch up on latest info in fast-evolving water heater industry.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Pay for answer at fixya:
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 17, 2011 | Rheem Tankless Hot Water Heater...
21vp50-1 rheem water heater, the ignitor is not working
1) Rheem does not show that exact model number, since they list current products only.
2) Rheem serial number shows year of manufacture on second 2 digits. So C06 was made in 2006.
Today's manual might not have troubleshoot steps that match older product.
3) 21vp50 is 50 gallon power vent water heater.
Open following link to identify product.
New models have Honeywell electronic gas valve with LCD flashing error codes.
http://www.rheem.com/product.aspx?id=C24E3F52-A6A4-4BC7-AF5B-0DF23A7A0263
http://waterheatertimer.org/gas-water-heater-timers.html#Rheem
4) Sample manual for newer power vent models shows error codes and troubleshoot steps:
http://globalimageserver.com/fetchDocument.aspx?id=a92c7d0e-8a95-48ba-8810-cd714f33d47a
5) Earlier Fixya answer suggests where to buy ignitor for 21vp50:
PART #HSI51409A
http://www.fixya.com/support/t3641891-rheem_21vp50_1_igniter_stopped
6) Your manual should show troubleshoot steps and expanded parts list.
Always save manuals like gold, and save searching later for a manual at Fixya.
If we can't find the manual, then our answers are limited to suggestions and guesses, since we're not on-site and can't perform troubleshoot steps for you.
7) Post your question on professional water heater forum
8) Call Rheem and they can possibly suggest which local service technician will work on that model:
2600 Gunter Park Drive East
Montgomery, Alabama 36109-1413
Phone: 1-800-432-8373.
9) Call a local plumber.
10) Install inexpensive home-center brand gas water heater yourself:
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Feb 03, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
I am have a error code 72 C4 on a Rheem tankless water heater
Error 72 is Flame sensing Device fault.
Flame rod could need replacement or be out of line, or tankless needs to be cleaned using maintenance outlined in manual.
Read manual.
Open following link for Rheem tankless troubleshoot resources including error codes, parts links, typical manuals:
Oct 25, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Water Heaters Logo
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
