Question about Kenmore Elite HE4 Electric Dryer
Control panel it will not allow me to change cycles
  • fixyafixme Nov 26, 2007
    can not change cycles unless I hold another option down while pressing the start button... check lint screen stays lit all the time. Dryer ~1 year old
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 62 Answers
Unplug for 5-10mins. check vent and venting
Posted on Jan 02, 2008
Whirlpool duet dreyer control lock On --can't program dreyer
try unplugging for a couple of minutes and it should reset to factory settings.
Mar 07, 2018 | Whirlpool Washing Machines
Reset button maytag dishwasher
  • 1 Open and close the dooricon1.png of your Maytag dishwasher.
  • 2 Locate the "Rinse" button on the dishwasher control panel. Press and release the button five times in quickicon1.png succession.
  • 3 Press and release the adjacent "Drain/Off" button on the control panel two times; this will deactivate the dishwasher's demo mode and reset your dishwasher.
  • If you need to restart your dishwasher or forgot some dishes and want to open it during a cycle and restart it
  • 1 Press the "Cancel Drain" button on the display. Allow about 2 minutes for the dishwasher to completely drain.
  • 2 Choose a cycle under "Cycles" on the panel.
  • 3 Select an option or options under "Options" on the panel.
  • 4 Push the "Start Resume" button.
  • Oct 24, 2013 | Dishwashers
    Whirlpool RS385PXBQ0 slide in range/oven won't work after self-cleaning cycle.
    Check the wiring on the door lock. If that looks good you need to replace the door lock but that part is no longer available.
    Oct 22, 2013 | Kitchen Ranges
    Calypso washer display is freaking out.. It
    change the panel. buttons are shorted wool button
    Feb 01, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
    Samsung washing machine F1245 control panel stuck??
    I have Samsung/korea-SW905Washer.When power is switched on the Fault-'1E' appears. what could be the reason.( narrate list of control component failure).
    Bought in the year 1996 at India ( voltas mega washer top loading-7.5kg) and working till last month.
    after few wash cycles the machine stopped at aforesaid indication and it is not functioning due to above fault indication'1E'
    provide me remedial measures or electronic control board circuit.
    May 29, 2009 | Samsung WE356A5W Washer/Dryer Laundry...
    Dishwasher does not start
    I have the same problem. I've tried everything;even took apart the control panel and checked for corosion. I ended up changing the control board-$130 down the drain- The only other thing I can figure is the button panel has some sort of short- also ~$130-. good luck. Now I use the sink (wife's not happy) Tech sheet is behind kick plate.
    Dec 13, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
    Kenmore Elite Oasis Model# 110.27087603
    I had a very similar problem with my Oasis He Washer 110.27087603. The machine was randomly cycling through different water temperature indication lights. It would repeatedly beep and not allow a wash cycle to complete. Fixya.com alerted me to the "upgrade" to the electronic control W10112112 to W10189966. My machine was scheduled service and a Sears tech replaced that board. My problem with random cycling continued and the tech stated the touch panel electronics; part # 8564392 would fix the problem. He said one of the microswitches on the panel was probably stuck and not allowing the machine to enter a wash cycle. I found the 8564392 panel at http://www.prosupplyco.com/search.aspx?find=8564392 for a very reasonable price. Realize that Whirlpool parts are Whirlpool parts and Sears doesn't hold the only key to them.
    Oct 29, 2008 | Washing Machines
    Can not change Cycle setting
    I wonder if it's the control board that needs replacing ??? found a note on www.managemyhome.com saying...(part no 134207700 according to my parts list). Is there anything unique/special in replacing the control board... here are the instructions for it...if you try this, pelase let me know...
    Replacing the control board is just a matter of removing wires from the old control board and installing them on the new one. It is an electronic board and can be damaged by static electricity so you have to touch some ground points with you hands before touching the control board.
    To access the control board remove the top panel from the washer. There are 2 screws in the rear of the washer holding the top on.
    With the top removed you will see three screws going down from the top holding the control panel to the cabinet of the washer; remove them.
    Lift the control panel up and it will come loose. The control is mounted to the control panel with some screws.
    Oct 07, 2008 | Kenmore 44072 Front Load Washer
    Whirlpool Duet GEW9250 Dryer; Only Running in Delicate Cycle
    im going to try to help you for free did you not get the tech sheet when you changed out the control board
    Feb 15, 2008 | Whirlpool GEW9250 Electric Dryer
    Kenmore Elite HE4 Electric Dryer Logo
    43 people viewed this question
    Top Kenmore Dryers Experts
    Sal De
    Marvin
    Marvin
    jimorris77
    Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
