Question about GE Profile JDP47 Electric Kitchen Range
Fc loclked door how do i fix this - GE Profile JDP47 Electric Kitchen Range
  • 55 Answers
If the oven has a clean cycle it might be that someone put it into the clean cycle. This means that it went to over 500 degrees to clean the oven. Let it cool overnight and the door should release. Do not try and force it-you will damage the door locking. This is a safety feature to prevent harm because of over 550 degrees.
Posted on Oct 19, 2013
GE RANGE DOOR LOCKED ON DISPLAY WITH FC ERROR
You might want to ask GE. They want customer satisfaction.
Nov 29, 2013 | Washing Machines
J SP420 NIBB GE oven Display reads FC locked door and oven will not work but stovetop works.
The "FC" error code means that there is a failure in the door lock circuit.
You may want to check the switches in the door latch first. Then check the wire harness from the door latch to the control board. If there is nothing wrong, replace the control board.
You may need to get an appliance repair person out.
Mar 18, 2011 | GE Ovens
Why FC show on ademco 6148 keypad,
FC is for faliure to communicate. Need to check systems connection to monitoring station. Did anyone work on your phone line(s) or did you change your phone company or service? GL.
Dec 07, 2010 | Ademco 10) Ademco 6148 Keypad Fixed...
How do you un-loclk a mobile phone
defualt security code is 12345 for all nokia cell phones
Aug 25, 2010 | Nokia 5310 Cellular Phone
Describe FC error in dawlance 1 ton AC
Its A filter clean indication that means your filters of air conditioner is full of dust and need to be clean.
To clear the FC message, open front panel of your ac and there will be a pinhole switch "Automatic" or "Reset". Keep it pressed for 5 seconds and FC will be removed.
PS: Dont panic if a/c is turned off instantly when you press the button as its normal. Hope it helps.
Aug 22, 2010 | LG LFX25975SW (247 cu ft) Bottom Freezer...
Alarm code FC and F7, everyting works but the alarm keep come back.
Hi There
I have found the code for you and hope help this helps out.
F7 - E1 Common switch wire is defective Common wire (+5VDC) to latch switch, and to door switch is shorted to chassis ground or neutral. A double oven will have two of each switch and one common wire.
1. Check connections at control and at the latch switch and door switch.
2. If all connections are good, then check the individual switches as outlined for the F5 failure. 2 Digit Failure CodesThank You for writing to Fix Ya.
Best Regards Richard
Feb 18, 2010 | Cooktops
How do I manually defrost the freezer of my FC 36RX?
simply unplug and let stand with doors open for 4 to 5 hrs
Mar 15, 2009 | Smeg FC36RX Bottom Freezer Refrigerator
"FC" display
It has detected the door lock motor didn't respond. Check wiring to the motor. If wiring is ok then replace the door lock motor.
Nov 09, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Open Questions:
See all GE Profile JDP47 Electric Kitchen Range Questions
GE Profile JDP47 Electric Kitchen Range Logo
85 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
