Question about Samsung CLP620ND Colour Laser Duplex Printer
I need icc profile for Galaxy Dx5 printer - Samsung CLP620ND Colour Laser Duplex Printer
How do I get a ICC profile for this Xerox 6360DN printer ?
I don't believe there is an ICC profile for this printer.
It is considered a "Office Color printer" for printing word documents and spreadsheets and occasionally print pictures...it is not a graphics printer or something you would want to do color matching on.
Jan 10, 2014 | Xerox Phaser 6360DN Printer
Clp-620 icc profile
Dear
Pl. down load and install the samsung easy color manager and install it. Here you can control the color setting.
Printer Support SAMSUNG India
Thanks.
Feb 12, 2012 | Samsung CLP620ND Colour Laser Duplex...
I have a Samsung CLP-315 laser color printer. I'm trying to find out if there's a *.icc or *.icm color profile for it to use with Adobe Photoshop. Couldn't find anything yet via google or others. Would you...
I have just purchased a CLP 325 and have set it up to get excellent colour pictures using Adobe Photoshop and the icc profiles readily available.
Your current working icc profile could be either Adobe RGB (1998), sRGB, Profoto or another. I would suggest that for everyday work use sRGB, if you are a specialist use Adobe RGB (1998).
Firstly make these changes in Photoshop:
Edit / Assign Profile / ColourMatch RGB.
To print:
File / Print / printer profile should be Adobe RGB (1998)
Illustration attached
Aug 24, 2010 | Samsung CLP-315W Laser Color Printer
Colour Profiles for the Konica-Minolta BizHub C252P
For this type of colour output, such as InDesign you will really need a Fiery. This is professional colour running in Psotscript.
Without this you are going to have inconsistent results.
Depending on the Model will be how well it supports ICC profiles. the most recent "tuxedo line" comes with a profile downloader that works well with custom profiles.
Apr 03, 2009 | Konica Minolta Office Equipment & Supplies
Could not read the ICC profile. Saving image canceled.
ICC = International Color Consortium.
The ICC's should be installed in the default printer directory.
Also, you may want to check the printer profile. In printer properties under the "color management" tab check to see if automatic or manual is highlighted. If manual is highlighted, be sure the print profile matches that of the paper you are using. You can select any of the included profiles as the default or add your own from a third source. Such third-source profiles are most often specified by your software provider
Mar 24, 2009 | Epson RX595 Photo All-In-One Printer
Epson ICC profiles
Since there has been no interaction for a lot of months, I think we can call this one "Poster Solution"
Sep 01, 2008 | Epson Stylus C86 InkJet Printer
Error message
The ICC profiles on your printer are corrupted.. Click here to download new profiles.
Apr 16, 2008 | Epson RX595 Photo All-In-One Printer
Bizhub C250/252 ICC Color Profile
HI i am fron DPI Grafica SH and have made test of diferents ICC profiles.
I will tell you how is my system to get to correct colors an sharp texts.
First - i print fron Adobe Ilustrator or Adobe PDF Profesional. If you have your file in Corel Draw export it to pdf or Publish a PDF File.
Second - I select s"sRGB IEC6 1966-2.1" this profile prints acurate fonts and colors that match whit de monitor. Is a little bit desaturate if you compare with " COATED Foagra". This one prints blurry fonts and blur edges.
This is the best result that i can get after print tests with all de ICC profiles.
Greetings and i hope that you can solve this problem.
Nolasco.
Oct 12, 2007 | Konica Minolta bizhub C250 All-In-One...
Red printing
Hi... I have the same problem (Canon S500), however, I recongised that if one calibrates the screen and the printer with an external colour-measuring device in order to create icc-profiles, everything works a lot better. You can assign icc-profiles for devices in the Colour-Sync-Utility. However, you do not have to create the profiles yourself (it is better, but...); sometimes you can download them somewhere on the Internet. (quite hard to find though) Once you set up different profiles, the os translates colours a lot better between devices. Hope this was of any help...
Dec 11, 2005 | Brother MFC3820CN Print Server
Samsung CLP620ND Colour Laser Duplex Printer Logo
138 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
