Question about Hotpoint Ultima WF860 Front Load Washer
Wt741 machines drum
We have a Hotpoint Ultima WF7412. When we program the water fills but the drum doesn't turn. We have checked the belt and ensured the filter is clear. Please help
  • 3,961 Answers
It is possible the motor start capacitor has failed. Unless you know how to test it, call a service person.
Posted on Oct 20, 2013
  • 121 Answers
SOURCE: fault f10
the manual can tell you the problem you can get this here
http://www.hotpointservice.co.uk/hs/pages/manual/manualSearch.do
Posted on Mar 03, 2008
SOURCE: error message f-01 on hotpoint ultima wt741 washing machine
F01 is a motor faulty normally caused by the module,but sometimes thewiring to the motor plug that works loose as its to tight,give them alla good wiggle make sure there all in!
check this link for other error codes of hotpoint machines
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Posted on Dec 15, 2008
tborn6
  • 700 Answers
SOURCE: WMA54 Hotpoint Aquarius drum does not turn during wash or spin
sound like the contact points on the timer are probebly dirty or arched to where they are not making good contact. you can take and clean them with a piece of emery cloth if you are mechanically inclined and can take the timer apart. Also there's a set of contacts down by the motor ti check too.
Good Luck,
Posted on Jan 06, 2009
  • 100 Answers
SOURCE: Hotpoint WT741
turn the machine on while pressing the on annd stat buttons at the same time until dOFF appears.
Posted on Jan 28, 2009
barkencoa
  • 3463 Answers
SOURCE: hotpoint ultima F-05 errorr appears on machine
Error F05 indicates pressure switch jammed on full.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve the problem.
Posted on Jan 10, 2010
Hotpoint ultima wt741 f10 fault code
  • F10 - No cold fill. Check that the taps are on or if the drain hoses are kinked / blocked.
Apr 10, 2012 | Hotpoint Washing Machines
Hotpoint WF860 drum not turning. Belt checked all ok, no error codes it just fills with water and goes through the cycle filling and emptying when it should and the drum stays still. Can someone help?
ours did the same as this........ it needed a new control board after checking everything you have mentioned. it was a couple of years ago and at that time it was a hotpoint part only. but they can be picked up on ebay for around 30-40 quid.
Oct 18, 2011 | Hotpoint Ultima WF860 Front Load Washer
I have a hotpoint ultima WT741 flashing F-10 can you tell me the problem please
F10 is a pressure switch not sensing error. Basically its a filling problem.
What you need to do is make sure the fill hose isn't kinked up at the back stopping it from filling fast enough.
If the hose is OK then take off the fill hose and aim it into a bucket and turn the water tap on. Then from there see what the water pressure is like there.
If its weak then you need the water pressure sorting out.
If the pressure is fine then you will need a multimeter and test the water valves on top and see if any of them are faulty.
But the F10 error code is a filling issue.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 01, 2011 | Hotpoint Ultima WF860 Front Load Washer
I have a hotpoint ulitma wt741. my machine seems to overflow the water just filled the drum. i had to turn off the mini blue valve for cold water to stop the water overflowing. how can i fix this ?
To avoid confusion i`ll give you the senerios.Your washing machine was NOT in use and somehow it just fills with water over the day ,slowly filling up and never stops-this is the inlet valve u/s and water seeps,drip drip until the machine leaks-replace valve only answer.Or ,the machine is in use and water doesn`t stop filling up either on wash or rinses-can be valve not shutting off because valve is faulty,similar to above,this is rare but not unknown,or much more likely the air trap/filter is blocked up which is not telling the pressure switch to cut the power to the valve with the correct amount of water.IF the filter/air trap-a rubber hose with a large hose clip and a white looking chamber sprouting from the hoses r/h/side- is at the rear of the machine(to the right of the motor looking from the rear of the machine) this is where you should look first ,if your filter is at the front (r/h/s) i don`t know the answer to this part of the question.
Dec 29, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima F-05 errorr appears on machine
Jan 10, 2010 | Hotpoint Ultima WF860 Front Load Washer
Washing machine won't spin
Do you hear the motor spinning loud whirring noise,when drum is not,if so drum belt has come off or snapped,if no noise possible brushes on motor need replacing
Jan 18, 2009 | Hotpoint Ultima WD72 Front Load...
Error message f-01 on hotpoint ultima wt741 washing machine
Dec 15, 2008 | Hotpoint Ultima WD72 Front Load...
washing machine WT741 ultima all light are flashing and it won't do anything else
Nov 12, 2007 | Washing Machines
Hotpoint Ultima WT741
if it wont drain check the pump for any blockages and working condition
Sep 17, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
103 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
