Question about Electrolux EPWD15KG LuxuryGlide Touch2Open Pedestal Kelly Green
Epwd15kg gas dryer will not power on - Electrolux EPWD15KG LuxuryGlide Touch2Open Pedestal Kelly Green
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 101 Answers
Check door switch @ belt @ power volt...
Posted on Nov 11, 2013
I have a gas dryer is it also electric dryer also
Up to my knowledge, GAS dryers work with gas
Sep 11, 2015 | Dryers
My matag gas dryer wont heat on any setting.
On a gas dryer the exhaust duct fuse mounted right next to the control T-stat kills the power to the gas assembly if the blower is restricted or worn out. A common problem with these dryers. If power is indeed getting to the gas assembly I would first check for continuity of the flame sensor switch mounted on the side of the burner area. It's job is to allow the ignitor to fire up when power is delivered to the gas assembly from the control t-stat on that blower housing. The flame sensor has to open when the ignitor reaches 1800f. At that point in time the ignitor becomes a thermocouple even with no power going to it it allows continuity through the coils so that they will get energy enough to yank open the gas valve. While the ignitor is glowing it is hogging all that power and the coils simply cannot pull the valve open. Sometimes a gas dryer will work a little then quit. that would be thos coils on the gas valve are weak. They get hot and fail. To get into the dryer you must first remove the door so that you can next get the front panel off. That will revieal the top holdown clips you remove. Then you can get the shroud off and remove the drum. I bet you would like a service manual for this beast:
Slope front Dryer Service Manual
Sep 29, 2012 | Maytag Atlantis MDG7400AW Gas Dryer
Ge Dryer 4 years old model DBVH512EF0WW no heat power is good to dryer heater ok thermostats ok PROCESS OF ELIMINATION LEADS ME TO a power board above drum, diagram says it has some relays on the...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;
Sep 10, 2011 | GE DCVH515EFWW Electric Dryer
I have a gas powered kenmore dryer but my new home does not have an gas outlet instead the new home has only an electrical power 220 outlet I want to use my new dryer in my new home. How do I convert from...
You cannot convert a gas dryer to electric. Do you a natural gas line for your furnace? A plumber can easily T into the mainline and run a drop for your dryer. This would be cheaper than buying a new dryer. If you do not have natural gas in your house you will need to buy a new dryer.
Jun 30, 2011 | Dryers
Re order 295269 no heat Continental Girbay Model drh55cg gas dryer not a range i checked several things no power to gas valve no power to a small transformer.i really need a diagram
heatman101;;
Jun 13, 2011 | Dryers
No heat. Elec. power OK. 12 years old
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 19, 2010 | Whirlpool WGD5200TQ Gas Dryer
GE Profile gas dryer won't ignite
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 01, 2010 | GE Profile DPXH46EAWW Gas Dryer
Igniter won't glow
I am assuming that everything works OK except you have no heat?
When you turn on dryer listen for gas valve to click(this may take a few seconds).If you don't have a click then the gas valve my be bad or it is not getting power.
Dryer has to be running to check for power only experienced persons should perform machine running power tests.
Let me know If I can do anything else to help.
Mar 20, 2010 | Whirlpool LGR5636L Gas Dryer
Roper gas dryer does not heat.
If the ignitor is not powering , go to the switch. That has to send power to the ignitor, then on to the gas valve.
Jul 22, 2009 | Roper RGX4634KQ Gas Dryer
Kenmore gas dryer model 75291. The gas dodes not start
first, check to make sure gas present to unit, and power to the ignitor. if no power, replace timer, if power, check the ignitor for continuity, if open, replace. If ok, check to make sure none of the thermostats are open, if they are, replace. If ok, check gas valve solonoids, they should not appear melted or stuck, if so replace. If still no function, replace gas valve.
Jun 30, 2009 | Dryers
Electrolux EPWD15KG LuxuryGlide Touch2Open Pedestal Kelly Green Logo
51 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
