Question about Dell OptiPlex GX270 PC Desktop
My pc dell gx270 2.6gh hardisk and room not installed
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 131 Answers
It sounds like you need a bigger hard drive, try remove other program that you can install back in again, backup the computer install a bigger hard drive and restore the backup file. I recommend using Acrois software for the backup. You can also download from Cnet a free verison on mini partition to resized the drive once you restore the backup.
Posted on Oct 19, 2013
I changed the hardisk of my dell dimension 2400 PC desktop. the sound card will not work and everything seem not to work properly.
if the drivers are installed properly then download the bios and flash it.download it from dell support website under drivers and downloads.
Oct 24, 2010 | Dell Dimension 2400 PC Desktop
I got my motherboard changed in October and my computer won't boot up "disk boot failure 0" could I have the same problem again? I don't have a disk - dell dimension C521
The motherboard is not the problem.
Your hardisk is the problem.
See if your hardisk is detected during boot up procedure.
If it does... Run again your Windows XP CD installer and repair your operating system.
Having "Disk Boot Failure" error means the boot system of you operating system is corrupted.
If your hardisk is not detected... you better check if the power supply connector on your hardisk is secured and not loose..
If still not detected.. your hardisk crashed and need to be replace.
May 19, 2010 | Computers & Internet
My Dell Desktop cannot start in Safe Mode
hi there,
you mention you have change your hardisk,you have to check if your hardisk was configure in cmos and bios set up, first whaen you start your computer press F2 then bios set up appear,check your device if
was connected on your system.on main menu check your ram if it was connectd,then press arrow right to advanced menu check your hardisk from IDE configuration if both hardisk and memory was installed or cofigured by your system.go to boot menu to set your device, on boot menu,scroll it from boot device priority
if you assure there is windows installed already on your hardisk,priority your hardisk,second your cd room,third floopy etc.press F10 to save and restart your computer,If no sytem was appears you must reinstalled your windows but you should change again
the boot set by priority the cd room instead of hardisk in order to put windows on your computer.press F10 again to save and restart your computer
to install your windows
insert windows cd on cd room
wait to configure your computer by the cd windows
then ff the windows installation procedure
until windows installation was finish.have a nice day don't forget to rate me please.thank you
Feb 21, 2010 | Dell Dimension 3100 PC Desktop
My pc shuts down and i cannot open it anymore..wahat would be the possible problem? but the cpu lights on..
hi there,
several factors are considered most common factor are basically on hardware problem.try to check windows by disconnecting i.d.e of hardisk and cd room run our computer,if still black out replace video card or memory card then run again if the windows open put back connection on hardisk and cd room and run again.have a nice day
Oct 18, 2009 | Computers & Internet
My Dell Dimension would not Boot when I try to Boot the power light jush flashes if I remove the yellow and black cable from the power surploy you can here it booting but there is no video
hi there,
well,unplug your pc, try to put back cable supply,try to configure your hardisk on cmos/bios set up,if the hardisk have detected by your cpu,refresh your hardisk,disconnect hardisk ide cable from motherboard and put it back.then try to run again.if windows does not
come out,reinstall your windows again on your cd installer you can fix from repair your system.have a nice day
Jul 06, 2009 | Dell Dimension 1100 PC Desktop
How to setup my computer to go to windows?
hi! there,
if power supply of your pc is fine,the fan is running and the light in the front of your pc is on.lets us go work about this.
first, you have to configure your cd room and hardisk in your pc,doing this at start press F2 or delete depend on your pc how cmos bios set up appear,take note on start menu left bottom corner
then on cmos feature check your hardisk if it was configure,if not set to auto let your system find it out for you.if there's your hardisk esc. then go to bios set up,on boot sequence
ist priority cd room
2nd hardisk
3rd floopy
etc...
press F10 save and exit.upon restart open cd room insert your cd installer e.g..xp,linux,vista
your pc will reboot automatically and configuration set up will initialize, just wait take coffe break
then follow what ever the installer want to do
there are question that you will anwer, if the windows detect that you have previous OS in your system remove,there are some instructions to follow, its good to have one OS is operating on your system,then follow some instruction again on on your new setting,do not selec on quick format its better on normal only.so until you finish installing just follow properly.this time i'll take also my coffe break,cheers and have a nice day,don't forget to rate me after you finish. thank's
Apr 08, 2009 | Computers & Internet
Vista boot manager missing
Your hard drive is bad. It will keep crashing until you replace it.
Mar 25, 2009 | Dell Inspiron 1420 Notebook
LOST PICTURE ON FLAT SCREEN
If you buy new PCI video card there is alway CD software attached on this,you should claim for this because it was the driver for your new video card ,without it your PC will have an abrormal operation .Are you sure it was your video card?you can consider also your memory card,Wiht out hardisk,CD room,floopy your computer will run it can open your monitor configuring the cmos and bios.Try on this one disconnect hardisk,cd room,floopy then detouched your memory card clean using pencil eraser the sloted terminal of your memory card,also your video card try to clean terminal by pencil eraser.Then put back memory and video card again if the monitor work.If ok put back again the cdroom,hardisk, and floopy.If not ok Isolate checking the memory and video card also the processor.
Mar 14, 2009 | Dell Dimension 2400 PC Desktop
Dell b130 restarting all the time
hi buddy!
1. Go to bios setup look if the computer see the hardisk and you setup the first boot priority is hardisk.if you encounter the same problem.
2. Maybe your operating system have corrupt then you try to reprogram the hardisk. if they same problem apear
3. Your hardisk have a problem you try to change a new one
bochard_20
May 16, 2008 | Dell Inspiron B130 Notebook
Dell OptiPlex GX270 PC Desktop Logo
29 people viewed this question
Alun Cox
