Question about Whirlpool Monochromatic Stainless Steel French Door Refrigerator - WRX735SDBM
I have a whirlpool Monochromatic Stainless Steel French Door Refrigerator - WRX735SDBM that is giving me an error code cooling off and is now dripping water how can I fix it
  • 198 Answers
SOURCE: Water Dispensor leak on Whirlpool Refridgerator
The solenoid valve needs replacing, located at the back of the refrigerator. If you have well water you will need to install a filter on the supply line.
Posted on Jan 05, 2009
SOURCE: WATER DRIPS DOWN FROM INSIDE TOP REFRIGERATOR BELOW FREEZER
Not an original solution - but a good one. Remove panels at the back of the freezer compartment to expose the heater unit or heater wire that defrosts the freezer coils and wrap a solid copper wire gently around the heater/ heater wire and place the loose end in the drain. This will conduct heat to the freezer drain and help keep it open. I did see a manufactured part in one of the appliance parts websites but it did not match my unit.
Posted on Jun 09, 2009
  • 105 Answers
SOURCE: in-door water dispenser drips water
replace water filling valve as it probable has dirt between valve seat
Posted on Nov 21, 2009
localwonder
  • 6784 Answers
SOURCE: Whirlpool refrigerator water dispenser won't stop
Hi. This will usually be the fault of the water inlet valve. The solenoid based valve may have debris building up, thus, causing the valve not to close properly, after usage. Kindly, follow the procedure below to confirm the damage, replace the valve, if needed.
The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source (typically under the sink). Disconnect the supply line. Remove the screws that secure the inlet valve in place.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors
Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush, or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multimeter should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
Posted on Nov 25, 2009
  • 246 Answers
SOURCE: rust on stainless steel
Check out this site
www.applianceart.com
these guys sell covers for your fridge and ones to match your other appliances. They even have stainless steel. Instead of scrubbing away-- just reface your appliances. They have vinyl and magnetic covers that are so easy to install and protect your appliances.
Posted on Aug 25, 2011
Samsung refrigerator has 21 E code flashing
Freezer fan error. Most likely the fan in your freezer has stopped working completely
Jul 05, 2016 | Samsung RF260BEAESR 25.5 cu. ft. French...
Ice forming under the freezer drawer & on drain tube water pooling in floor Cleared drain tube, what else?
Whirlpool corp., whom made this unit, had a bad design for the defrost drain tube by the compressor. Order part W10619951 and install. This is a kit to change out the current drain tube to a better one. You still have to defrost the frozen defrost drain tube but this will fix it for good.
Aug 01, 2015 | Maytag MFI2269VEM Monochromatic Stainless...
Whirlpool refrigerator gi5fsaxvy00 not working
A non-operational refrigerator is usually caused by a faulty start/overload relay that is attached to the compressor. The unit will have to be pulled away from the wall to be worked on. Before pulling the unit out protect any wood floor with cardboard so you don't ruin the floor. Remove the cover at on the back at the bottom to remove the plastic housing covering the relay and replace the relays. A bad relay will have a rattling sound when it is shaken.
The relays are used to protect the compressor from overheating. Dust and especially pet hair is almost always the cause of overheating. Refrigerator brushes should be used to clean the condenser from the bottom front. Do not be forceful when cleaning because the condenser connections can be loosened to cause leaks in the sealed system.
Sep 01, 2014 | Whirlpool Gold GI5FSAXVY 24.9 Cu. Ft....
STAINLESS SIDE PANEL
Go to any Home Depot store and check the appliance section for technical specs on the Whirlpool models. A salesperson can easily obtain that info for you because they have that info right there.
Most stainless steel refrigerators come in 22 gauge and have various color finishes to choose from.
Yours came in several finishes (including two types of black and white finishes) but if your finish is stainless steel, then most likely you have either the Monochromatic Satina or Monochromatic Steel. You can tell by looking at the surface. The "Satina" has a more refined and smoother look to it than the other one listed.
Hope this helps!
Pen
P.S. They're no longer making that model with that finish.
Aug 14, 2014 | Whirlpool WRF989SDAM 29 cu. ft. French...
Ice maker not working just changed the filter water works but ice maker not working
Check the plastic lever on the door. It usually moves closed when the door is shut to turn ice maker on. The lever can freeze and stop the ice maker.
Sep 23, 2013 | Whirlpool Gold GI6FARXXF 25.5 cu. ft....
Water dispenser not working
have to connect to plumbing first. then if the filter is clogged no water can get through. new install could have some air in line. just have to hold lever on. The valve has to be turned on to allow water to pass.
Mar 27, 2013 | KitchenAid Architect II KFIS27CXMS 26.6...
My freezer is freezing with ice just started when clean it it start right back
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 28, 2010 | Whirlpool GI5FSAXVY Stainless Steel ...
Whirlpool Monochromatic Stainless Steel French Door Refrigerator - WRX735SDBM Logo
35 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
