Replacement of head light blub 2004 lexus es 330
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 131 Answers
Need to replaced the DRL bulb on a 2004 Lexus ES 330
Yes I thought the whole assembly is easy to remove.
Jan 29, 2014 | 2004 Lexus ES 330
2005 Replace high mounted stoplight lexus es 330
It is not as complicated as you think. You just reach the light housing from the rear seats and squeeze the housing to release it from the rear panel. Once it is out, you can unplug the cable and replace the bulb. Good luck!
Jun 17, 2011 | 2004 Lexus ES 330
How do i change the transmission fluid and transmission filter in a 2004 lexus es 330
You need to remove the transmission pan to both drain the fluid and replace the filter...the filter kit should also come with a replacement gasket...you will need to check the operators manual or call the dealer to see how much trans fluid you will need to replace
Jan 22, 2011 | 2004 Lexus ES 330
I have a 2004 Lexus Es 330 and the maintenance req light is on it has 51,540 miles
This should be reset when the oil is changed [ you may be due for service ]. to reset make sure the odometer is set on total miles, make sure the key is off, push on the reset button, turn on igntion key keeping your finger on the button- the mileage numbers will be replaced by a groupe of dashes, they will go out from left to right. Once all are out you should hear a chime- it's reset.
Jan 10, 2011 | 2004 Lexus ES 330
Can I replace the tail light Blub my self on my Lexus 2004 ES330 if not how much does is normally cost?
I have not worked on a LEXUS, but every car tail light I have seen was accessible from the trunk. You usually have to pull out some panels to get to it, but once you get your hand on the socket, it usually twists out CCW (about 20-30 degrees twist) but may just pull straight out. Take out the old bulb, replace, and reinstall the socket in the lens.
Aug 25, 2010 | 2004 Lexus ES 330
Ecu head light where is it located for a 2004 lexus 330
I am not sure,but look behind each head light ***,there will be a flat box,called a inverter,it is most likely the problem.
Jan 21, 2010 | 2004 Lexus ES 330
Where is the starter is on an '04 Lexus ES 330?
it could still be the battery. there may be enough power to turn on lights etc. but not enough to engage starter. try boosting before condemning the starter, and these cars are not known for starter issues.
Dec 28, 2009 | 2004 Lexus ES 330
TRAC OFF, VSC, and check engine lights are on in my 2004 Lexus ES 330
Often caused by a loose gas cap or fouled or failed air fuel O2 sensor. Check your gas cap is fully ratcheted, Drive a day or two. If lights don't clear you will need a code reader attached to the car to diagnose.
Dec 18, 2009 | 2004 Lexus ES 330
Lexus ES 330 2004 At what mileage does the radiator need to be serviced? Also, does it have an internal timing chain that needs to be serviced?
the coolant needs to be serviced @ 60k according to lexus reccomendation. theres a timing belt that needs to be changed @ 90k miles. I usually just change the coolant with the timing belt because you have to take the water pump off anyway and replace the engine coolant.
Nov 11, 2009 | 2004 Lexus ES 330
107 people viewed this question
k24674
jasbo
jasbo
