Question about HP Compaq nx6310 Notebook
Io chip bios - HP Compaq nx6310 Notebook
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 225 Answers
Explain the issue in detail
Posted on Oct 21, 2013
Which version of Award BIOS supports HT?
I suggest to visit the manufacturer's website. If manufacturer has changed BIOS or Update the BIOS, the patches or new BIOS will be available there.
Jan 25, 2016 | Intel Computers & Internet
Tip
Intel 845gvsr mainboard no display problem
this problem is normal because of the BIOS chip failure normally
symptoms:
when u get ram out and start computer it gives beeps and when u put back the ram and power on PC it gives no beep no display.
Fix the problem:
tools required:
1. hot air gun
2. 512kb fresh bios chip/ if the old chip is right then no need of newer one
3. p3 mainboard (with the BIOS socket) for reprogramming the chip
4. dos bootable hard disk
5. bios bin file.
have not the file ,
don't worry: this file can be made from the bios chip of a working mainboard using the bios flash utility.
flashing software: best is Uniflash.
Procedure:
1. with hot gun, get the bios chip out of the board,
2. reprogramme the chio with correct bin file.
3. put the bios back
Reprogramming:
copy the file in dos bootable hd
run the hdd on p-3 board
pull the bios out of running board (with slight care)
put the 845gvsr bios chip in place of p-3 bios
run uniflash and flash the bios
power of p-3 computer and get bios out
for how toprogramme bios chip : check the page
http://www.pcnineoneone.com/howto/biosflash1.html
on Jan 24, 2010 | Computers & Internet
Samsung polaris motherboard sound driver
Try briverbooster from IO-bit; it's free. It helped me with a few drivers I couldn't find. If nothing helps, because windows doesn't support this soundcard/chip anymore it is best to buy a new one. Don't forget to shut the one on your board off in your bios.
Feb 24, 2014 | Samsung Computers & Internet
Bios update failed.. Now all i get is 8 beeps and no display? Any solutions?
Hello,the only way to fix this problem is to prepare original bios file at your USB stick.But first you need to made this USB bootabile(put some universal BIOS fasher software from internet),than put the original file (bios)inside.when its finished try to find another PC (correct),pick up your BIOS chip,(the case of BIOS must be the same as another correct PC!!!!!!!!! IT IS VERY IMPORTANT),than turn on correct PC,run bios ,set USB stick as 1st bootabile device,save changes and restart PC,after that you will see universal Bios mask,you have choice to run bios file you already put on USB stick,DO NOT START FLASHING BIOS!!!!! PICK UP THIS BIOS CHIP FROM HIS CASE,THAN PUT YOUR BIOS CHIP (CHANGE CHIPS UNTIL THIS PC IS STILL WORKING)press enter and this PC will flash your BIOS with correct file.When its finished TURN OFF THIS PC(dont restart).Pick up your bios chip,and put it on your moterboard place for Bios,also put the bios chip from regular (correct)PC to its place,and you are finished.start PC you are using to fix problem ,just to check everything's OK,THAN TURN ON YOUR PC,IT MUST BE WORKING,9its look like risky job but dont worry its ok
I already fix lot of this problems,only check-dont short pins of chip,or turn chip at wrong direction,best luck :)
Dec 16, 2013 | HP Pavilion 1214 QW701AAR Refurbished...
My bios is corrupted how can i solve the problem
You can remove the battery to clear the BIOS - read the information from this link.
Although the link is about removing the password, the same things need to be done to reset BIOS to factory default.
Jan 05, 2011 | Foxconn (945G7MA-8KS2) Motherboard
No video/aud/io/sm bus/ethernet controler
thhis is a bios problem. locate your bios chip and right by it should be a battery. You need to remove the battery and leave it out for a couple of minutes, that way the built up charge dissapates. It should reset your bios to original factory settings with all ports enabled. then replace battery, plug back in and power up. You should go into your bios when you boot up and check each setting to ensure that it it turned on. after all the ports, and the bus is turned on, save and exit bios reboot and let the computer boot up normal. The OS should now recognize and install all those items that were disabled.
Dec 18, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Not able to enter the BIOS settings..plz help me
if u r not able to go to bios setting nd ur computer work properly its of bios setting problem remove the cmos battery nd left for 2-3 hours with no power then power on the system
in other case ur computer does not further proced from bios screen the problem of cpu or the io chip on board replace ur mother board or else processer
Jun 29, 2010 | Intel Motherboard
I have a sony vaio VGN-N250E laptop that I need a ONE TIME PASSWORD to unlock the ios......please help
Unlike desktop computers, they rarely make it so that you can delete or reset your BIOS password in a laptop. To do this usually requires an IC chip to be removed from your motherboard and then replaced. If you can find someone to do this, then it will most likely cost $150 or more. There are some who claim to have a Break or Work-around for removing bios passwords. I've very rarely had this work for me. Here's a link to a web page that puts it into steps to follow that you could try. Click here.
Mar 17, 2010 | Sony VAIO VGN-FZ470E/B Laptop
MBd BIOS reqd as BIOS wrongly flashed and computer is not booting
BIOS information is needed to boot the computer, you must replace your BIOS chip. You can call the manufacturer of the motherboard and ask for a new BIOS chip.
Apr 26, 2009 | Computers & Internet
HP Compaq nx6310 Notebook Logo
15 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
