APC SmartUps SU1000I NET After we hit the power (I
APC SmartUps SU1000I NET After we hit the power (I - test) button, during or after completing the self-test UPS drops the load immediately (or sometimes between 1-45 minutes, does not go on battery, instead all the 6 LEDs around the middle start flashing without any beep (not the graph LEDs). It still can go online on battery mode and at times even from the mains supply also - until the load is dropped.
  • 1 more comment
  • Adnaan Baig
    Adnaan Baig Oct 22, 2013
    Replacing elays, RY5 & RY3 made the fault less frequent
  • Adnaan Baig
    It suddenly stops supplying the load when mains supply is present, works fine on inverter.
  • Adnaan Baig
    Adnaan Baig Oct 26, 2013
    1400VA capacity. Replacing RLY 5 & RLY 3 improved the problem by about 50% only . Re-soldering all the pins of all the relays solved the problem.
    New Friend:
  • 42 Answers
The possibility of changing UPS code, so its capacity is smaller, the solution must first be returned to its original settings on PC via Hyper term,
or the relay damage, or overload
Posted on Oct 22, 2013
  • Dean Arhafidzia
    Dean Arhafidzia Oct 26, 2013
    check again replace the relay of the same type, be careful there are broken lines (two layer truehole) trying to use APC power chute detected what 1000VA capacity?
  • Adnaan Baig
    1400VA capacity. Thanks for the help.
2 Suggested Answers
SOURCE: After powering on, all non-graph LEDs keep blinking
That meens that UPS dont have battery power for minimum time (2min). Unplug some devices so UPS load need to drop below 25% and lets UPS recharge battery
Posted on Jun 08, 2008
I am looking for the battery wiring diagram for APC smartUPS 2200 Rackmount
Check out the link below. He claims that the PCB schematic for the 1400XL appears to be the same as the 2200 because he owned one. It's worth the explore. I have attached the schematic for the 1400 XL that when you go to the site, you can click on and enlarge then download
http://techno-fandom.org/~hobbit/power/dumbups/
Feb 07, 2015 | APC Computers & Internet
Why does an APC Smartups 30kva have high battery temperature alarm?
UPS should be located in an environment where the temp should not exceed 25 degrees Centigrade, or you may have a damaged fan (inside the UPS, or the temperature sensor is defective.
Jun 09, 2014 | APC SmartUPS VT 30kVA Rackmountable UPS ...
Apc smartups will not power up
have you check the battery, SURT UPS will not on if the battery is totally drain.
Dec 05, 2012 | APC Smart-UPS RT 5000VA (SURTD5000XLI) UPS...
Apc 3kva ups is not working at 260 volts
try to do some calibration, but my question is why you need to plug the UPS on a 260 Volts??? which country you're from???
Nov 27, 2012 | APC SmartUPS RT 3kVA Rackmountable UPS ...
APC SmartUPS 3000VA
APC do not release cct diags and these are not easy to repair, if the battery fuse was open and there is some board damage, the thing is toast. Even if you get it going the battery will not be able to be calibrated, unless there the board/processor is 100%, I know this as we have a similar model on the bench right now with new batts in and the unit will not recalibrate, so even though the batts are new, as soon as the mains is dropped it goes to very low battery and shuts down in 2 mins.
Buy a new UPS save yourself a lot of time. Hope this helps
Thanks for using FixYA
Aug 02, 2010 | APC Smart-UPS 3000VA UPS System
My APC SmartUPS 1000 wont turn on, I've moved the battery into another one to test that it's fine and that works. I've also put a known good battery inside it, just nothing is happening when I press the...
It sounds like a relay inside. I found that if I bump the UPS like pick up the front or back & dropping it about 2" or tipping it and letting if fall back level it'll finally kick back in. This makes me feel the relay has gone out. Maybe during it's test procedure.
Dec 04, 2009 | APC Smart-UPS 1000VA UPS System
APC SMARTUPS 1500VA Battery Problem When Replaced
You are correct. The APC Smart line has a partial charge when it's new. Similar to cordless phones, the work right away, but you're still supposed to charge them before use for best results.
Just leave it plugged in with no load for a couple hours and it will be fine.
Sep 02, 2009 | APC Computers & Internet
Problem with SmartUPS SU5000I
Before trying to replace an IC, make sure that the battery is capable of holding a charge. If there is more than 1 battery, check all. If it (they) are bad, it will probably be less expensive to replace the unit.
Jul 24, 2009 | APC (SUA3000I) UPS System
Computers & Internet Logo
138 people viewed this question
David Payne
David Payne
