Question about AT&T SIM Cards
Giffgaff coverage have I got to activate my new card to test signal coverage?
Yes, the SIM card must be activated in order to see the signal coverage. If it is not activated it will not communicate with the network.
Posted on Oct 20, 2013
How do i configure mms on nokia C3-01?
1. Press the Menu button 2. Highlight 'Messages', then press Select 3. Highlight 'Message settings', then press Select 4. Highlight 'Multimedia msgs.', then press Select 5. Check that 'Save sent messages' is set at 'No'. 6. Check that 'Delivery reports' is set at 'No'. 7. Check that 'Allow multimedia reception' is set at 'In home network'. 8. Check that 'Incoming multi-media messages' is set at 'Retrieve'. 9. Highlight 'Connection settings', then press Select 10. Highlight 'Active multimedia settings', then press Select 11. Highlight the next available Set (e.g. Set 1), then press Activate 12. Highlight 'Edit active multi-media settings', then press Select 13. Highlight 'Settings' name' and press Select (left softkey). Enter 'giffgaff MMS', then press OK 14. Highlight 'Homepage', then press Select (left softkey). Enter 'http://mmsc.mediamessaging.co.uk:8002' and press OK 15. Highlight 'Session mode', then press Select (left softkey). Highlight 'Permanent' and press Select 16. Highlight 'Data Bearer', then press Select (left softkey). Highlight 'GPRS' and press Select 17. Highlight 'GPRS access Point', then press Select (left softkey). Enter 'giffgaff.com' and press OK 18. Highlight 'IP Address', then press Select (left softkey). Enter '193.113.200.195' and press OK 20. Highlight 'Authentication type', then press Select (left softkey). Highlight 'Normal' and press Select 21. Highlight 'User name', then press Select (left softkey). Enter 'giffgaff' and press OK 22. Highlight 'Password', then press Select (left softkey). Enter 'password' and press OK 23. When asked to 'Verify new password' enter 'password' and then press OK 24. Press Back (right softkey) 6 times to return to the standby screen.
Aug 16, 2014 | Nokia C3 Touch and Type Cell Phone
How can this invalid sim issue be fixed?
Invalid sim means the sim card may no longer be active , faulty or the device is network locked , cheapest option is replace the card if still not functioning the issue is with the device , giffgaff will not use the same APN as O2 , that may have to be manually input
Jul 07, 2014 | Easy N388 Watch Phone Tri Band Single SIM...
Vodafone live postpade gprs setting w580i
The W580i has a central navigation button (Navi key) and two soft keys slightly above this.
1. Press 'Menu' (right softkey).
2. Highlight 'Settings' and press 'Select' (left softkey).
3. Scroll to the 'Connectivity' tab by pressing the Navi key to the right.
4. Scroll to 'Data communication' and press 'Select' (left softkey).
5. Highlight 'Data accounts' and press 'Select' (left softkey).
6. Highlight 'New account' and press 'Add' (left softkey).
7. On the 'Account type' screen, highlight 'PS data' and press 'Select' (left softkey).
8. On the 'Account Name' screen, enter 'giffgaff WAP GPRS', press 'Continue' (left softkey).
9. On the 'New PS data' screen, highlight 'APN' press 'Edit' (left softkey), enter 'giffgaff.com' and press 'OK' (left softkey).
10. Highlight 'Username' press 'Edit' (left softkey), enter 'giffgaff' and press 'OK' (left softkey).
11. Highlight 'Password' press 'Edit' (left softkey), enter 'password' and press 'OK' (left softkey).
12. Press 'Save' (right softkey).
13. Press the 'back' arrow key (key directly below left softkey) 2 times.
Activate GPRS settings:
14. Highlight 'Internet settings' and press 'Select' (left softkey).
15. Highlight 'Internet profiles' and press 'Select' (left softkey).
16. Highlight 'New profile' and press 'Add' (left softkey).
17. Highlight 'Name:' press 'Add' (left softkey), enter 'giffgaff WAP GPRS' and press 'OK' (left softkey).
18. Highlight 'Connect using' press 'Select' (left softkey), highlight 'giffgaff WAP GPRS' and press 'Select' (left softkey).
19. Press 'Save' (right softkey).
Change GPRS settings:
20. Highlight 'giffgaff WAP GPRS' and press 'More' (right softkey).
21. Highlight 'Settings' and press 'Select' (left softkey).
22. Ignore 'Connect using'
23. Highlight 'Use proxy:' press 'Select' (left softkey), highlight 'Yes' and 'Select' (left softkey).
24. Highlight 'Proxy address:' press 'Edit' (left softkey), enter '193.113.200.195' (to bring up the number press the number until it appears. Add the dots with the '1' key) and 'OK' (left softkey).
25. Highlight 'Port number:' press 'Edit' (left softkey), enter '8080' and press 'OK' (left softkey).
26. Highlight 'Username' press 'Edit' (left softkey), enter 'payandgo' and press OK (left softkey).
27. Highlight 'Password' press 'Edit' (left softkey), enter 'password' and press OK (left softkey).
28. Press 'Save' (right softkey).
Change Homepage:
29. Highlight 'giffgaff WAP GPRS' and press 'More' (right softkey).
30. Highlight 'Advanced' and press 'Select' (left softkey).
31. Highlight 'Change homepage' and press 'Select' (left softkey).
32. Highlight 'Name:' and press 'Edit' (left softkey). Hold the 'c' button (to the right of the Navikey) to clear any text in the field. Enter 'giffgaff ACTIVE' and press 'OK' (left softkey).
33. Highlight 'Address:' and press 'Edit' (left softkey). Hold the 'c' button (to the right of the Navikey) to clear any text in the field. Enter 'http://giffgaff.com/mobile' and press 'OK' (left softkey).
34. Press 'Save' (right softkey).
35. Press the backward arrow key (key directly below left hand soft key).
36. Highlight 'giffgaff WAP GPRS' and press 'Select' (left softkey).
37. Press the 'back' button (to left of Navi key) 3 times to return to the standby screen.
The GPRS WAP settings are now complete.
Sony Ericsson W580i MMS
You'll need to complete all steps for this to work.
Please also ensure the GPRS WAP settings have been entered prior to entering the MMS settings.
2. Highlight 'Messaging' and press 'Select' (left softkey).
3. Scroll to 'Settings' and press 'Select' (left softkey).
4. Highlight 'Picture message' and press 'Select' (left softkey).
5. Highlight 'Validity period' and press 'Edit' (left softkey), highlight 'Network maximum' and 'Select' (left softkey).
6. Highlight 'Read report' and press 'Edit' (left softkey), highlight 'Off' and 'Select' (left softkey).
7. Highlight 'Delivery report' and press 'Edit' (left softkey), highlight 'Off' and 'Select' (left softkey).
8. Highlight 'Signature' and press 'Edit', highlight 'No signature' and 'Select' (left softkey).
9. Highlight 'Creation mode' and press 'Edit' (left softkey), Highlight 'Unlimited' and 'Select' (left softkey).
10. Highlight 'Picture scaling' and press 'Edit' (left softkey), highlight 'Off' and 'Select' (left softkey).
11. Highlight 'Auto download' and press 'Edit' (left softkey), highlight 'Ask in roaming' and 'Select' (left softkey).
12. Highlight 'Accept messages' and press 'Edit' (left softkey), if not already ticked highlight 'Advertisements' and press the left hand soft key 'Mark'. If already ticked leave. Ignore 'Anonymous' Press 'Save' (right softkey).
13. Highlight 'MMS profile' and press 'Edit' (left softkey).
14. Highlight 'New profile' and press 'Add' (left softkey).
15. Highlight 'MMS profile name:' and press 'Edit' (left softkey), enter 'giffgaff MMS', select 'OK' (left softkey).
16. Highlight 'Message server' and press 'Edit' (left softkey), enter http://mmsc.mediamessaging.co.uk:8002' and press 'OK' (left softkey).
17. Highlight 'Internet profile' and press 'Edit' (left softkey), highlight 'giffgaff WAP GPRS' and press 'Select' (left softkey).
18. Select 'Save' (right softkey).
19. Highlight 'giffgaff MMS' and select (left softkey).
20. Press 'back arrow' (key to left of navi key) 5 times, to return to standby screen.
The MMS settings are now complete.
Feb 19, 2013 | Sony Ericsson w580i Cellular Phone
How setup internet settings
The phone has a 4-way directional 'Navi' key and 2 soft keys on either side of this. The Navi key can also be pressed in to select options.
1. Press the 'i' button (press navi key).
2. Highlight 'Browser' and press 'Select' (left softkey).
3. Highlight 'Browser settings' and press 'Select' (left softkey).
4. Press 'Options' (left softkey) , highlight 'Add new connection' and 'Select' (left softkey).
5. Highlight 'Profile Name' and enter 'giffgaff GPRS WAP'
6. Highlight 'Homepage URL' and enter 'http://giffgaff.com/mobile'.
7. Check that 'Proxy' is ticked (press Navi key to tick/untick).
8. Highlight 'IP Address' and enter '193.113.200.195'.
9. Highlight 'Port' and enter '8080'
10. Ignore 'Linger time' (this is preset at 90).
11. Check that 'DNS' is unticked (press Navi key to tick/untick).
12. Highlight 'Bearer' and select 'GPRS' by pressing the Navi key right or left.
13. Highlight 'Advanced settings' and select using center Navi key.
14. Highlight 'APN' and enter 'giffgaff.com'.
15. Highlight 'Login ID' and enter 'giffgaff'.
16. Highlight 'Password' and enter 'password'.
17. Press 'Save' twice (left softkey).
18. Highlight 'giffgaff GPRS WAP' and press 'Options' (left softkey)
19. Highlight 'Activate' and 'Select' (left softkey).
20. Press 'Back' (right softkey) 3 times to return to the main screen.
Dec 21, 2010 | Samsung SGH-J600 Cellular Phone
No network coverage
Phone is not receiving any radio signal / received signal is too weak:
Confirm that network coverage is available where you are by contacting your service provider.
SIM card is not working properly:
Insert your SIM card into another phone
Note: Contact your service provider if you get the same message again.
Phone is not working properly:
Insert your SIM card into another phone. If the second phone works with the inserted SIM card, then
the problem is probably with the first instrument.
Note: In this case, contact your nearest Sony Ericsson service center regarding your phone problem.
May 30, 2010 | Sony Ericsson Walkman® W995 Cell Phone
Nokia 2600 is not showing network
in nokia 2600, sim active but no signal and no network coverage.
Apr 26, 2009 | Nokia 2600
Sim card wont register
You SIM card is inactive. You have to make at least 1 paid call every 6 months otherwise your sim is deactivated. If it's new sim has to be activated.
Rate me if helped.Thanks.
Apr 14, 2009 | Nokia N91 Cellular Phone
No signal
call the sim provider, either no network coverage or sim has not been activated.
Dec 22, 2007 | Nokia 1100
AT&T SIM Cards Logo
32 people viewed this question
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
