Question about Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA 20536728
I am trying to remove an old schlage deadbolt but the allen screws just turn and turn and nothing seems to get looser or tighter. Any insight?
  • 3 Answers
SOURCE: how do you remove knob on schlage deadbolt so that
turn knob as usual, there should be a hole in the bottom after you turn it. push a small screwdriver and it will pop right off.
Posted on May 14, 2009
  • 384 Answers
SOURCE: new schlage deadbolt stuck in locked position
Make sure that the tang from the lock side actually engage the mechanism in other side of the door. If the tang is too short or not engaged the lock will not work. Also check that the two screws connecting the lock to the other side is actually tight.
Posted on Jun 24, 2009
  • 670 Answers
SOURCE: How do I unmount a schlage keyed deadbolt?
There should be two hole plugs on the face of the interior deadbolt housing, above the key slot. They must be pryed out to access the screws. Unless it is installed inside out, then the the plugs will be outside. Yes I have seen this before or I wouldn't have mentioned it.
Posted on Sep 27, 2009
  • 3 Answers
SOURCE: remove schlage deadbolt
Schlage B160 - need small screwdriver to insert at bottom of faceplate to pry cover off. Face plate appears flush, but with a penlight you can see the recess at the bottom to pop it off. Screws lie under the cover for disassembly. Seems to be a lock design improvement once you figure out how to remove the faceplate.
Posted on May 07, 2010
  • 760 Answers
SOURCE: how do remove a schlage deadbolt that is doubled
You didn't indicate what mode. The little pins you refer to should be little caps snapped into the end of the screws. A very small screwdriver or a pocket knife should be able to remove them. Then you should have a screw head to work with. I can't remember, but it might be a square bit not a phillips head. See web site and look at installation instructions.
http://consumer.schlage.com/products/Productdetail.asp?StyleID=34
Posted on Jul 10, 2010
How do i remove the plugs covering the screws on the schlage deadbolt?
Schlage FAQs Schlage
The double cylinder deadbolts are keyed on both sides. On the interior side of the home there are drive pins (sometimes called screw covers) covering up the screws. Recommended method: Indent the center of each drive pin with a nail punch. Then use a carbon tip drill bit (about the size of a pencil lead) and ONLY go down 1/8". The drive pin will disintegrate. The drive pins will need to be replaced as they are no longer usable.
Sep 16, 2014 | Schlage Deadbolt. Double Cylinder Deadbolt...
How to remove plugs from schlage deadbolt?
Thank you for your inquiry. These are small plastic plugs on your double cylinder deadbolt. These are just held in through friction. Just take a small screwdriver and pop them out. Factorylocks.com can help you with your Schlage hardware needs.
Mar 29, 2013 | Schlage BE365-PLY BE365PLY626 Satin...
I have a schlage deadbolt, keyed on both inside & outside but neither have any screws to remove. How do I remove the deadbolt?
There should be caps over two screws above and to both sides on the interior key cylinder. Carefully use a pointed tool to pry them out. This will expose the phillips head screws that hold the two halves of the lock together.
Sep 24, 2010 | Schlage B362 619 KA4 Dbl Cyl Deadbolt Per...
How do remove a schlage deadbolt that is doubled
Jul 09, 2010 | Schlage B362 619 KA4 Dbl Cyl Deadbolt Per...
Can't see any way to get lock off- two small holes on inside
Hasn't anyone solved this in over a year? I have the same problem. Can't Schlage provide service info on their products?
Apr 18, 2010 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
New schlage deadbolt stuck in locked position
Jun 24, 2009 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
How do you remove knob on schlage deadbolt so that you may remove faceplate to tighten screws ?
Apr 04, 2009 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
Remove schlage deadbolt
Feb 08, 2009 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA 20536728 Logo
29 people viewed this question
Top Schlage Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Schlage Measuring Tool and Sensor Expert? Answer questions, earn points and help others
