Question about DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine
Close door light does not go off. Machine do nothing if this switch is not active. Did try to put in a woodpiece to activate the switch with no luck. Pleas help
    Habit-Forming:
  • DeLonghi Expert
  • 130 Answers
Need to change the switch on the door.
Posted on Nov 04, 2013
Machine shows E 61 when switch on.
E61 I think this a door lock error code. When you close, the door it activates a switch which will allow the machine to start a wash programme. Conversely the first thing the selected programme does is activate a solenoid, to stop you opening the door before the machine is ready. Think spinning drums, small children and cats, or flooded floors. I digress, if that little switch stops working or the mechanism has moved slightly and isn't activated, the machine assumes the door is open.
Maybe not a great help but we have narrowed things down.
H
Apr 03, 2016 | Washing Machines
What causes doors to lock and unlock while driving ?
Hi there: Please check the door switchs, Ford use in certain models the interior lights to activated the lock doors after you close the door and lights go off. I'm suspecting that you have a damaged door switch with a loose cable or wire; this wire is making "ground contact" and activating the locks with the movement. With a pothole or vibration, you can hear the locks activation. Please check those switchs and let me know. I'll think about it to give you more ideas. Good lock.
Jul 18, 2014 | 2003 Ford Windstar
When hitting start button, it sometimes buzzes, but fails to start. Can sometimes wait for a little while and try again, and it starts. When it buzzes, it will only buzz for a few seconds and then nothing.
it is either the door switch or start switch, this website will show you how to test both, Good Luck Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Apr 16, 2011 | Whirlpool LER4634J Electric Dryer
Flase door open reading on my aficio 350. The door is shut. The machine is showing that the door is open but it not. It close as it should be.
when the door closed it actually activates the switch. see on the door if any plastic piece from the frame is broken or not and locate where in the machine does the front cover activates switch. it will be easy to find the broken part.
Sep 23, 2010 | Ricoh Aficio MP 161 Black and White Copier
GE 1800 XL not heating, no power, except fan works and clock also
Hello :
It could be bad door switch or loose door switch mount . There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
or it could be problem with the control panel .
good luck .
please rate !
Mar 29, 2010 | GE XL1800 1100 Watts Microwave Oven
Door open fault light flashing with doors closed,can put an upward pressure on door and light will go off.
Sounds like the switch that is activated when the door is closed is either damaged or out of position. Try activating the switch with your finger. If it's out of position, shim it a bit with something to make it contact the door better.
Oct 15, 2009 | Refrigerators
Tecnik Built In Dishwasher SE6TIE1GB/17
You can try reseting the machine buy holging down outside two cycle buttons for 3 seconds, then release. After a minute the end light should come on. Then use as normal. If this fails pull the unit out, then take of the side panels (screws to the front in the seal) & check the red anti-flood float on the left side of the machine, to make sure it is not up activating the cut out switch. This may be due to the machine leaking somewhere and the float raises and activates the switch, or as in my case a build up of limscale has raised it up enough to activate it.
Hope this helps
Mar 06, 2009 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Oven door that wont come unlocked
sounds like you have a latch/lock issue. the unit seems to think the door is still currently locked, preventing proper operation, i would try to see if you can locate the door/light switch and manually trip it with your hand(turning off light). then while keeping depressed activate the self clean mode again, the machine will try to engage the lock/latch, as soon as it does then cancel it and it will return back to a normal resting location. you must keep the light switched pushed in order for this to work correctly
Oct 07, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Front load washer doesn't turn itself on when door closed and cycle picked
First check the door if it is still properly aligned try to tightened first the two screw of the door sometimes it is loose align it, reset your machine, if it is still the same, now take a look on the rubber gasket attached to the shell cabinet, there is a big plastic clamp or a rounded wire with spring on the other end it is the gasket lock, pull it u can return it by reinserting it back, wire lock-just stretch it and put it back,after doing that-pull the gasket slowly,to your right the door lock is located, check if it is misaligned-difinitely no problem with your door lock it is a matter of alignment - happy washing
Apr 06, 2008 | Washing Machines
DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine Logo
64 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
